Hot Rods Another Deuce Five Window Gets my Attention
Discussion in 'The Hokey Ass Message Board' started by ct1932ford, Nov 1, 2023.
  1. swifty
    swifty
    That's right Ted, make him do the prep then you can shoot the paint.
    Stogy, tb33anda3rd and ct1932ford like this.
  2. tb33anda3rd
    tb33anda3rd
    builds muscles:D
    loudbang, Stogy and swifty like this.
  3. ct1932ford
    ct1932ford
    In my fingers?:p
    I’m back in CT. In the garage tomorrow :cool::)
    Joe Troilo, loudbang and Stogy like this.
  4. swifty
    swifty
    Tomorrow is New Years Day and it's a holiday. You're supposed to take your wife out for the day. You're retired, you can work during the week LOL
    After saying that I'll be in the shed tomorrow working on my 32-5 window coupe. Took the wife out last night to a local event so I've earned my Brownie points.
  5. ct1932ford
    ct1932ford
    Got the rear spring all cut and smoothed. All sanded and primed today. Paint next, then reassembly. IMG_5716.jpeg IMG_5714.jpeg IMG_5742.jpeg
  6. ct1932ford
    ct1932ford
    TFoch, Stogy, simplestone and 7 others like this.
  7. ct1932ford
    ct1932ford
    Spent some time at Cousin Ted’s shop today and got some coupe stuff ready for paint.:cool: IMG_5782.jpeg IMG_5780.jpeg
    TFoch, Stogy, Paul B and 9 others like this.
  8. Project looks great. Needs a Rajo headed banger though. Hehe.
    ct1932ford likes this.
  9. ct1932ford
    ct1932ford
    I’ll pass:oops:
    Stogy, swifty and chryslerfan55 like this.
  10. ct1932ford
    ct1932ford
    Wired up the taillights and picked up painted parts from Ted’s . Install gas tank next. IMG_5812.jpeg IMG_5811.jpeg IMG_5810.jpeg
    TFoch, Ron Funkhouser, Stogy and 11 others like this.
  11. GordonC
    GordonC
    Looking good!
    Stogy and ct1932ford like this.
  12. Nobey
    Nobey
    I can't imagine what you got done in the time it took me to read this whole thread. Great work CT.....
    Stogy, chryslerfan55 and ct1932ford like this.
  13. 383deuce
    383deuce
    Nice work I really like the brake shoe machine. Very cool
    ct1932ford and Stogy like this.
  14. ct1932ford
    ct1932ford
    That belongs to my cousin Ted. If it’s not in his barn it doesn’t exist ;)
    I was there today to pick up my hood sides and check out some projects. Like this cool trailer. IMG_5814.jpeg IMG_5815.jpeg
  15. ct1932ford
    ct1932ford
    Finished getting tank in, taillights and crossbar. Just need to strap up some wiring.
  16. ct1932ford
    ct1932ford
  17. ct1932ford
    ct1932ford
    Started the headlight****embly and installation. Wiring completed, new guide tags on and parking / signal sockets installed.
    Also finished and painted floor cover to clear fuel tank line and vent. Common issues with Tanks tank.
    IMG_5810.jpeg IMG_5818.jpeg IMG_5819.jpeg IMG_5820.jpeg IMG_5822.jpeg IMG_5823.jpeg
  18. ne'erdowell
    ne'erdowell
    The coupe is becoming a beauty. Can’t believe how fast you rip through each part of the build, more please.
  19. 60 Special
    60 Special
    from Omaha Ne.
    Could you clarify on your statement "Also finished and painted floor cover to clear fuel tank line and vent. Common issues with Tanks tank." 60 Special
  20. pprather
    pprather
    Mark, thanks for taking along on another build.
  21. ct1932ford
    ct1932ford
    When using a Tanks 32 gas tank in a deuce , the fuel line and vent line are unlike the stock arrangement . They interfere with the floor so you need to enlarge the access hole and then a cover is usually installed over the lines.
    See This! https://www.jalopyjournal.com/forum/posts/14172901/
    60 Special, Stogy and loudbang like this.
  22. swifty
    swifty
    Has your Tanks tank got the triangular stiffening brackets fitted like the originals? The Vintique tanks have them as standard but there mounting holes don't match an original chassis so they need to be modified to correct that problem. I've never used a Tanks tank so not familiar with them.
  23. ct1932ford
    ct1932ford
    No I could have added them but decided it looks cleaner with out them.
    Stogy likes this.
  24. ct1932ford
    ct1932ford
    Finished headlights , actually all light now finished. Put some gas in it today and started it up.
    Will move to hood sides next. Even though the top is in primer. It will all come apart for complete paint at some point. Probably after this summer. I want to ring out any issues before I pull motor etc. for paint.
    I also finished up the trunk area and cover over fuel tank fittings. IMG_5825.jpeg IMG_5830.jpeg IMG_5829.jpeg IMG_5831.jpeg IMG_5832.jpeg
    TFoch, Stogy, Bandit Billy and 7 others like this.
  25. ct1932ford
    ct1932ford
  26. Duke
    Duke
    What did you use for headlight bulbs?
    Stogy likes this.
  27. ct1932ford
    ct1932ford
    I’m using Napa sealed beams. Do you need number?
    Stogy likes this.
  28. Duke
    Duke
    That would be great, I seem to need part numbers to get anything that does not come off a Honda.
    Stogy likes this.
  29. brady1929
    brady1929
    Mark,
    Where did you get those top bulb sockets for the Guide 682-C lights? And what bulb is used? Thanks.
    Stogy likes this.
  30. ct1932ford
    ct1932ford
    TFoch and Stogy like this.
