Technical Help loosening a taillight screw
Discussion in 'Traditional Customs' started by spillaneswillys, Jan 6, 2024.
  1. Ebbsspeed
    Ebbsspeed
    2 minutes with a propane torch? Really?
    2OLD2FAST likes this.
  2. deuce1932
    deuce1932
    from Australia
    4 pages of posts to get a f'n screw out... ! jeez...
    The new age of hot rodders I guess !
  3. Ziggster
    Ziggster
    Time for a Project Farm vid…
  4. swade41
    swade41
    from Buffalo,NY
    You can doooooo it !
    Stogy and Bob Lowry like this.
  5. I have to agree with Deuce 1932. If it takes that long to figure out the best way to get the screw out, how long will it take to finish the build.?
    rockable, SS327, SuperKONR and 2 others like this.
  6. 96 now :oops: .The very helpfull thread " little tips and tricks for garage hobbyists " has 1763 posts so maybe there is a future for this thread.
  7. 1971BB427
    1971BB427
    from Oregon
    If you can lay this on a piece of wood and screw down some blocks on either side to keep it from moving, then use some clamps with padded jaws to hold it down so you have your hands free. Then you can get a screwdriver tip that fits the slot as close as possible, and push down while turning.
    I've even put a vise-grip plier on the shank or handle of my screwdriver so I get good leverage while pressing down firmly. If the screw snaps it's no big deal. It will allow you to get the lens and trim off, and then you can drill and tap the broken screw for a new screw.
  8. 283john
    283john
    I heard this thread has made the Associated Press wires. As the world waits for news on this screw......
    RDR, SuperKONR, loudbang and 2 others like this.
  9. MCjim
    MCjim
    from soCal
  10. noboD
    noboD
    What fun would that be. And what would we talk about?
    vtx1800, Bob Lowry and Driver50x like this.
  11. Nailhead Jason
    Nailhead Jason
    ok maybe 3 min, the material is so thin it takes no time to heat it up, it works great with propane or MAPP gas.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is that a sheet metal screw vs a machine one?
    Stogy likes this.
  13. BJR
    BJR
    On the 4th page and the 102nd post the screw is out. Yea :D Now back to our regular programing. :p
  14. It is a machine screw. Little specs of rust popped out as I turned it out
    1971BB427 and Bob Lowry like this.
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Viola >>>
    >>>Is that a sheet metal screw>>>
    Looks more like a busted sheet metal screw than a viola.
  16. 41 GMC K-18
    41 GMC K-18
    Perfection ( In this case "Extraction" ) cannot be rushed!
    I think we all deserve to see some pictures of the tail light assembly taken apart, to see what else is questionable.
    Congratulations on not breaking anything so far!
    Stogy likes this.
  17. pirate
    pirate
    from Alabama
    Put a screwdriver in slot, make sure it’s perpendicular to the taillight then give the screwdriver handle a good rap with a hammer. Then try to “tighten” the screw to see if it budges at all, if so try to loosen. Repeat Repeat. Sometime you get dissimilar metal corrosion especially with zink/aluminum die cast alloys and a sharp rap will sometimes break the corrosion loose. Your milage may vary!
  18. Bob Lowry
    Bob Lowry
    Now......PLEEZE don't drop the lense.....and, no, I don't care about getting the last post....ha, ha...
  19. Upon magnification it is not a machine screw
    Stogy likes this.
    Stogy, SS327, 41 GMC K-18 and 2 others like this.
  21. MCjim
    MCjim
    from soCal
  22. nrgwizard
    nrgwizard
    from Minn. uSA
    "Anticipation, it's makin' me Wait..." :D .
    Marcus...
  23. dirt car
    dirt car
    from nebraska
    Yes, it may have involved four postings to get the screw dilemma resolved, but then again, it seems at least a few postings in the not-too-distant past were the subject matter of guys toying with mockups for months on end, but let's give them credit for seeking opinions before screwing up a good part or project!.
    Stogy and The37Kid like this.
  24. I will soon start a build thread on my 39 Plymouth coupe. An old time mechanic as finished the 354 Hemi and chassis and I will start on the rest.
    Stogy and slayer like this.
  25. swade41
    swade41
    from Buffalo,NY
    So which of the 2,000 suggestions worked, how did you get it out ?
    Stogy, INVISIBLEKID and 1935ply like this.
  26. Greg Rogers
    Greg Rogers
    Whew... boy I can sleep again... Yuk Yuk.....
  27. speedster t
    speedster t
    A proper screw bit and muscles
    Stogy likes this.
  28. SS327
    SS327
    Now can we have a thread on the proper way to wash a barn find again?
    '28phonebooth and Jack E/NJ like this.
