Customs Finally starting on the wife’s 56
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jan 5, 2019.
  1. 57 Fargo
    57 Fargo
    Is it done yet?:)
    Stogy and Sharpone like this.
  2. Sky Six
    Sky Six
    from Arizona
    A craftsman uses a contour gauge. The work looks great.
    Me, being akin to a blacksmith, just beats the metal into submission.
  3. Fine line between craftsman and just a stubborn guy with some hammers.
    So far I haven’t used a hatchet.
    Contour gauge was a Christmas present from the wife. Kinda ironic.
  4. SS327
    SS327
    Or was she trying to tell you something?
  5. Tacked in place. Still a good bit of dolly work ahead. Better than 1/2 inch of bondo, cracks and br***.
  6. Didn’t want to post but
    lot of undercut in the weld. All ****ed up fine.
    My biggest mistake was welding some of it yesterday in the shop in the 20s.
    2nd I got in a hurry and didn’t tack weld enough.
    3rd was I didn’t clean the back side thoroughly like I normally do. The edge against the door had surface rust underneath that made the weld porous.
    4th. Vision through my helmet sux. My regular helmet died and I’m using a HF backup. It’s fine for MIG but not near as good for TIG
    It’s 90% user error. Lack of discipline on tack welds and cleaning.
    I’ll do better next time.
  7. Sharpone
    Sharpone
    Hope my patches come out half as good.
    Dan
  8. chevy57dude
    chevy57dude
    Your ''mistakes'' outcl*** some of my ''looks good'' work lol. You could have bought a fender, but the rest of us wouldn't have learned so much! Well, I'm still in the learning stage, anyway..
  9. The mistakes only bother me because they were avoidable.
    I didn’t follow my own teaching
  10. nrgwizard
    nrgwizard
    from Minn. uSA
    Or; you "intentionally" set & showed an example of what not to do, demonstrated w/visual graphics, & discussed the ramifications of what, why, & how to correct them.
    All in all; good teaching... :D .
    Marcus...
  11. Not intentional. Just a combination of frustration, cold and impatience
  12. ekimneirbo
    ekimneirbo
    Anthony.........I think this should be your Avatar!
    Some craftsmanship accompanied by a little blood and dirt under the fingernail.............
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There, it’s fine now. :) IMG_2411.jpeg
  14. BamaMav
    BamaMav
    from Berry, AL
    I hear ya on the cold! Been thinking I got somehow teleported to Siberia this week!
  15. Fitting my crusty mock up engine
    Just rounded up what might be the correct power steering mounts and pulleys.
    crank pulleys seem to need spaced out to line up with the WP and PS pulleys.
    The other is the engine height. I’ve felt it was too low but this is where the store bought mounts settled at.
    I didn’t have the factory mounts but now have a set
    According to these old mounts the engine needs to move up
    ***uming these are the correct original style. If so, that would solve the PS pump hitting the frame issue.
  16. Picked up a couple wheels. 15 inch OE style stock wheels are a tough find
    NOS 60s Cal Custom spider cap trim rings.
    Hoping to talk her into either spider caps or push through cones and chrome lug nuts. And the outer trim ring
    Wheels painted blue
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    what is stuffed into the wheel vents? rubber? wonder if it was to keep brake dust off the wheels???
  18. The guy I got em from said something like that.
    mentioned that being factory?
    I don’t know.
    bchctybob, Johnny Gee and Moriarity like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No, not factory. But 57 did go to window less wheels.
    chevy57dude and chryslerfan55 like this.
  20. BJR
    BJR
    Those rubber pieces came with a rubber kit for a 55 Vette I did at work. So they must be factory.
  21. Well I be
    Cool
    Tow Truck Tom and chryslerfan55 like this.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A little reading say’s the rubber insert is used with full wheel covers. It helps keep dust from collecting within the face of the wheel and backside of wheel cover. :rolleyes:
  23. Think that’s what the guy said. He said he restored several tri5s.
    That’s sumthin
    I guess this wheel has been sitting in his shed a while.
  24. Used a set of OE tri 5 engine mounts. These trans dapt ones are lower than stock. The OE mounts raised the engine up 1/2 inch. I’ll use these trans dapt ones but will make a spacer. The PS pump clears the ch***is now. And could run a mechanical pump now.
    the alt bracket is just sitting there. It doesn’t clear the alt fan. I’ve fit it with rams horn manifolds. The ones with the alt mount that sticks straight out
    my ignorance is showing now. I’ve never used OE brackets on an sbc. The PS is fitting. The alt seems strange.
    I’ve got a set of aftermarket smooth 2.5 rams horns on the engine I plan to run. No alt provision.
    Got 3/8 clearance now. Everything I’ve looked at fights tight here next to the box.
    I’ve thought about shifting the engine over 1/4.
    Trying to fit as much as possible before this frame goes to get blasted.
  25. Picked up an upper hatch
    No exterior rot. A little on the inside.
    current one is rotted on the bottom
    for $70 I’ll use the lower portion to fix this one
    Picked up a lot of needed trim. $25 per stick average.
    better shape than the ones on the car. Thinking about adding the rocker trim
  26. Figured it out
    The upper bracket I have is this.
    And I’d need that lower if I run the current exhaust manifold
    the early intake I plan to use has a coolant port in the alt bracket location
    I’ll get this sorted out
    I guess I’ll find some 63/64 style alt brackets
    Or these 64 up vette ones
  27. BamaMav
    BamaMav
    from Berry, AL
    90* L bracket, bolt one side to arm, other to intake mount bolt. Simple and effective.
