Projects 1939 Ford convertible mild custom.
Discussion in 'Traditional Customs' started by John 79, Sep 13, 2023.
  1. Jacksmith
    Jacksmith
    from Aridzona
    El Perfecto!
    John 79 likes this.
  2. Okie Pete
    Okie Pete
    Looks great
    John 79 likes this.
  3. John 79
    John 79
    from Sweden
    My 283 was missing two of the holes for the front mount. This might seem like a small easy thing to fix but i hate to drill because i always get everything crooked and it have to go fast so im a measure once drill twice guy. This time was gladly not a***** up time and it came out good.
    20240118_173603.jpg 20240118_181218.jpg 20240118_182241.jpg 20240118_183031.jpg
  4. alchemy
    alchemy
    The upper right side goes into the cavity behind, where the fuel pump push rod is. Did you clean the shavings out?
    John 79 likes this.
  5. John 79
    John 79
    from Sweden
    Yeah i read that when i was searching for what thread the holes had (i got the metric system so im not so sure about inch) but thanks for the heads up. I will block the fuel pump off and took the push rod out, the original pump wont fit with the front engine mount.
    Okie Pete and The 39 guy like this.
  6. krylon32
    krylon32
    from Nebraska
    If you could access one there is a great custom 39 Deluxe convertible features in HOP UP annual #17. You are going to have a really nice ride when your done.
  7. Jacksmith
    Jacksmith
    from Aridzona
  8. MMM1693
    MMM1693
    I will also be watching closely. Just purchased a 40 Deluxe and wrestling with which way to go. It seems like I change my mind constantly, depends on which way the wind is blowing I guess.
  9. John 79
    John 79
    from Sweden
    Im the same, i dont have a 100% determined plan, i just build and do as i feel like along the way. There is so much cool stuff and different styles to build.
  10. John 79
    John 79
    from Sweden
    Gettin the 283 ready and when i took the oilpan and timing chain cover off i found that one bolt for the front main bearing cap was missing :eek:
    This engine was running this summer, i dont have any high hopes now that ive seen that the bolt was missing but i just put a bolt in and hope for the best.
    Also changed the timing chain and some expansion plugs.
    It might work and it might not work, we will find out when i fire it up for the first time.
    420198760_1832242947210482_7059840429706305475_n.jpg 420515973_7155242767903531_5728427239243056255_n.jpg
    Kelly Burns and anthony myrick like this.
  11. Crusty Chevy
    Crusty Chevy
    At a minimum plasti-gauge that front bearing for peace of mind. Would not hurt to check all of them including rods while you have it upside down and then properly set torque on mains and rods. If it or any of them are way out of spec then throw a set bearings in there, they are not all that spendy.
    Toms Dogs, Okie Pete and John 79 like this.
  12. Okie Pete
    Okie Pete
    Nows the time to check the main bearings and rod bearings. Don’t just guess and cross your fingers.
    John 79 likes this.
  13. John 79
    John 79
    from Sweden
    The main caps and rod caps is marked/numbered so they changed all the bearings at one time but thats no guaranty they are good.
  14. John 79
    John 79
    from Sweden
    Well i got the crank mains off and its shot, seems ive been ripped off.
    It*****s because its kinda hard to find a 283/327 here.
  15. Nailhead Jason
    Nailhead Jason
    Had to do the exact same thing on the 283 in my 39. Also, if you find that you need a spacer between the block and the hurst style motor mount plate, The original shackle bars of a 35 to 40 ford front spring are almost the perfect size. I used some old ones, opened up the holes just slight bit with a round file and welded them to the back of my hurst mount.
    ChuckleHead_Al and John 79 like this.
  16. Okie Pete
    Okie Pete
    Dang it . I hate to hear that . If the block is ok can You order a rotating****embly for it and rebuild it ?
  17. alchemy
    alchemy
    What kind of doofus would even bolt the pan back on with a missing main cap bolt?
    Kelly Burns, John 79 and ronzmtrwrx like this.
  18. Okie Pete
    Okie Pete
    A doofus that gives the rest of us a bad name .
  19. John 79
    John 79
    from Sweden
    Yeah, i wonder.
    And the pan had been on there for a long time.
  20. Okie Pete
    Okie Pete
    My cousin was looking for a cheap mode of transportation in the early 80’s . He found a 68 Chevy c10 setting in a guy’s backyard. The bed was full lo trash . He brought it gave it a tune up , repaired a few things and drove it about 200 miles. It developed a knock . We pulled the engine. There was tin shims under the main and rod bearings . The bearings were down past the babbit . Doofus’s are everywhere
  21. John 79
    John 79
    from Sweden
    Well got my hand on another 283, got it mounted and bolted in place.
    Did som spacers for the motor mounts to raise the engine a bit.
    The big bolts for the motor mounts are old rear shock mounts from a 49 Ford connected to the original bolt, had to drill the motor mount a little for the bigger bolts.
    The starter relay was hitting passenger valve cover, other than that nothing was in the way and the relay is a easy fix. 20240213_125345.jpg 20240213_131009.jpg 20240213_131025.jpg 20240214_111552.jpg 20240214_111922.jpg 20240213_131038.jpg
    GordonC, don colaps, mvee33 and 9 others like this.
  22. Okie Pete
    Okie Pete
    Good to hear that You’ll be cruising soon .
    Kelly Burns likes this.
  23. Jacksmith
    Jacksmith
    from Aridzona
    I had a similar issue w/the solenoid's position & so I moved it inside the cabin; cleaner firewall & not so easy for un-authorized hot wiring via some scoundrel.
    That's quite a nice car you've got there!
    Okie Pete and Kelly Burns like this.
  24. Outback
    Outback
    from NE Vic
    Thanks for keeping us in the loop. Cool project.
    Any thread on your 49?
    Kelly Burns and Okie Pete like this.
  25. MMM1693
    MMM1693
    Good for you! Wish I was making the progress on my 40 that you are on your 39.
    Okie Pete likes this.
  26. Chop Chop Carson Top.
  27. John 79
    John 79
    from Sweden
    Minor update, got the radiator/lower radiator pan and a pulley powdercoated.
    Now the radiator is in place and i have to find some fitting hoses.
    The original plan was to rebuild the original radiator but time and money got in the way so the easy solution was a new aluminum radiator.
    It kinda*****s with a modern radiator but it got better with some black paint and i still have the original radiator that will be rebuilt when time comes.
    Also got lycky and got a pair of 265 manifolds for a case of beer, needed those for clearence.
  28. John 79
    John 79
    from Sweden
    No, the 49 is sold now.
    Outback likes this.
  29. Crusty Chevy
    Crusty Chevy
    Radiator looks 100% better in black. I have two originals one has many stress cracks in the tanks from tensions left in from the original stamping process 80+ years ago. The other looks great but could I know could crack at any moment. You will hardly notice the new one from the driver's seat.
  30. John 79
    John 79
    from Sweden
    I thought of grinding down the tig welds on the top of the new radiator to make the top tank look like it was made i one piece but i was afraid of leaks.
