Technical 283 identification
Discussion in 'Traditional Hot Rods' started by OWes21, Jan 19, 2024.
  1. OWes21
    OWes21
    I was searching through sites to try to identify this engine. It doesn't make sense to me. I'm told it is out of a 63 impala.
    Attaching pictures to see if I am reading it wrong. Asking for a bit of help from the experts.
  2. bchctybob
    bchctybob
    The experts on here just I.D'd mine for me recently.
    They are going to want a picture of the block casting # and the date code, both raised numbers and letters on the back of the block where the bellhousing bolts on.
    Might help to wire brush that front pad too, make the numbers all stand out more.
  3. Truckdoctor Andy likes this.
  4. lumpy 63
    lumpy 63
    yw 1966 truck 327 I think
    mad mikey and Truckdoctor Andy like this.
  5. squirrel
    looks like it says Y something.
    Like he said, casting number and date on the back of the block, and clean it up so we can see what the "something" is on the stamp.
    And if it is indeed YW, then the 327 was out of a 1966 big truck, or a 1967 K10-20, or a 1968 big truck. Casting date will tell you what year.
    Truckdoctor Andy and Moriarity like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    It also helps when posting pictures to select “full image” so we don’t have to deal with those small pictures
  7. squirrel
    and do a little cropping and zooming in so we see things big enough to read them
  8. OWes21
    OWes21
    IMG_20240119_165703.jpg IMG_20240119_165527.jpg IMG_20240119_170055.jpg Thank you I did not notice the thumbnail or full size. Also added the other numbers IMG_20240119_165703.jpg IMG_20240119_165527.jpg IMG_20240119_170055.jpg IMG_20240119_165703.jpg IMG_20240119_165527.jpg IMG_20240119_170055.jpg IMG_20240119_165703.jpg
    bchctybob likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    casting number is 64-67 327 or 67 302. hard to read the first character in the casting date (maybe a D?) but it is 1967
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    this is still hard to read, can you clean it please?
  11. JD Miller
    JD Miller
    Did the 4" bore 327s come factory with those 283 power pack heads installed ?
    My '65 chevy truck had powerpack heads cause it was a 283. Had a carter 4 barrel too
    anthony myrick likes this.
  12. Yep
  13. squirrel
    67 makes it a K10-K20 engine, interesting. If that's really YW, it's sure hard to read without some cleaning off
  14. DDDenny
    Not a 302!
    mad mikey and Moriarity like this.
  15. -Brent-
    -Brent-
    It's the right color for a truck motor.
    mad mikey and anthony myrick like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    I was just telling what the casting number was..... the book lists it as 64-67 327 and 67 302, we know this is not a 67 Z28 engine
    mad mikey and Johnny Gee like this.
  17. -Brent-
    -Brent-
    Haha, Mark let this story brew about the pickup that came from the factory with a 302.
  18. DDDenny
    Not everyone!
  19. 302 2v from a vette
    lewk, Nailhead Jason, GordonC and 5 others like this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    wouldn't that be an orange engine ?? hahaha
  21. bchctybob
    bchctybob
    Weren't the 2 bbl Corvette engines chartreuse.?
    lewk, Fordors, Johnny Gee and 2 others like this.
  22. OWes21
    OWes21
    That's as clean as the person selling would do.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    he thinks it is a 283???
  24. Moriarity
    Moriarity
    SUPER MODERATOR
  25. JD Miller
    JD Miller
    What kind of compression ratio did that have? .... 327, 4" bore with powerpack, 59cc chamber, heads and flat top pistons ?
    IIRC my1965 truck 283 with carter 4 barrel, had 9.5:1 compression ration, and 220 hp
  26. lumpy 63
    lumpy 63
    Nope. only on the Corvettes ***embled in Mexico.
  27. OWes21
    OWes21
    Yes
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    it is clearly a 327
