Technical 302 GMC main bearing tech
Discussion in 'The Hokey Ass Message Board' started by john mullen, Jan 20, 2024.
  1. OK I have searched everywhere to folind the main bearing bore sizes for the 302 GMC inline six.
    I have a block that does not have the og main caps and I'm installing steel 4 bolt caps and need the factory main bearing bore specs.
    Thanks in advance John Mullen
  2. SEAAIRE354
    SEAAIRE354
    loudbang, jimmy six and Gofannon like this.
  3. Hotwyr
    Hotwyr
    Do you have someone who will step bore the block? I have a 261 Chev block I'd like to save but have been unable to find someone to take it on.
  4. Gofannon
    Gofannon
    I have a 270 block missing caps as well, so I'm watching with interest. I think the front cap will interchange with Chevy, make steel caps for 2 and 3. Did you know that GMCs manufactured for Staghound armoured cars had a Chevy style 4 bolt rear cap? These were made in a Chevrolet plant, not Pontiac. Here's a pic of one.
    Torkwrench, D-Russ and SilverJimmy like this.
  5. Mainedrifter2
    Mainedrifter2
    I just tore apart a GMC 270 if anyone needs parts, just pay shipping and they are yours.
    loudbang and Torkwrench like this.
  6. @john mullen , what do we need?
    Side cover?
    Push rods?
    Lifters?
    Cam?
    Distributor?
    Oil Pan?
    @Mainedrifter2 , does the crank have 4 or six bolts for the flywheel?
  7. Mainedrifter2
    Mainedrifter2
    Yes, yes, yes, yes, I think so and yes. I’ll take some photos when I’m in the shop tomorrow and there are some photos in the classifieds. I’d love to see someone use them.
  8. 302GMC
    302GMC
    from Idaho
    Gents - don't forget when align boring a gear driven cam engine, you risk losing the proper proper gear lash ...
    Torkwrench, lumpy 63 and RMR&C like this.
  9. Gofannon
    Gofannon
    Can that be compensated for? Bore it sideways a bit so the distance between centres remains the same?
  10. 302GMC
    302GMC
    from Idaho
    Betcha you could buy a complete core (or 2) for what you'd spend align boring a 4 main GMC or Chev ...
    Gofannon likes this.
  11. Hotwyr
    Hotwyr
    I think you're right, but this was a fresh build that broke the center main bearing caps. Can't bring myself to scrap it.
    302GMC likes this.
  12. jimmy six
    jimmy six
    If done correctly, you remove surface from the main caps. If the machinist knows his tooling he can take the minimum off the block and more from the cap to get the correct diameter.
    The most difficult is adding steel main caps to a cast iron block.
    Cloyes makes and stocks cam gears for Chevrolet/GMC that are made for engines that have been line bored.
    The distance between centerline from 1937 to the last push rod inline is the same and so are the gears according to a Cloyes engineer I talked to 25 years ago when I wanted to buy offset keys and he said I didn’t need too. Just buy a set with 6 different keyways on the crank gear.
    D-Russ, SEAAIRE354, loudbang and 3 others like this.
