Hot Rods Question ? 1960 Chevrolet 261 Engine
Discussion in 'The Hokey Ass Message Board' started by Dyno Dave, Jan 19, 2024.
  1. Dyno Dave
    Dyno Dave
    How many quarts of engine oil are required, add one for remote oil filter... Having trouble finding this information, have a 53/54 Chevrolet shop manual and it's not there. Thanks, Dyno Dave 5window, did'nt find the number in what you sent.
    But, Thank You.... the other nine can shove it up you know where !!!
  2. Budget36
    Budget36
    Spark plug wires appear to be red.
    Pocket Nick likes this.
  3. 5window
    5window
    Engine is blue.
    Budget36 likes this.
  4. 5window
    5window
  5. 5window
    5window
    So, what's your question?
  6. Complete junk
    I’d give that away to the nearest goof with a red shirt over his head in his avatar
  7. Budget36
    Budget36
    I’ll take inline 6’s for 200, Alex. ;)
  8. jimmy six
    jimmy six
    I’ll bet he wants us to identify the white and chrome thing mounted to the firewall with 2 hoses connected at the bottom. Nice hose crimps by the way!
    I only like black spark plug wires but that’s a personal choice.
    5window and Moriarity like this.
  9. No , no , give it to that “ It’s always a Dodge “ weirdo ,
  10. Coffee pot.
    Uses engine oil heat
  11. Hotwyr
    Hotwyr
  12. Hotwyr
    Hotwyr
    I run 4 qts in mine but that's without a filter since I change it regularly. I'd start there and then see wherr the level is after running it.
    mrspeedyt likes this.
  13. Dyno Dave
    Dyno Dave
    JohnLewis likes this.
  14. Dyno Dave
    Dyno Dave
    Thank You, Dyno Dave
  15. Mr48chev
    Screenshot (771).png Screenshot (773).png Well hell, you won't find 1960 engine specs in a 1954 book.
    If it is a 1960 261 out of a C 60 the pan holds 5 quarts plus the filter 5-1/2 quarts on a freshly ***embled "dry" engine. according to the GM heritage center vehicle info kits archives.
    https://www.gm.com/content/dam/comp...its/chevrolet-trucks/1960-Chevrolet-Truck.pdf
    Below the image from 1960 is the image from 54.
    That and most years you can find here. https://www.gm.com/heritage/archive/vehicle-information-kits
    The 54 truck page being here https://www.gm.com/content/dam/comp...its/chevrolet-trucks/1954-Chevrolet-Truck.pdf
    5window, Budget36 and JohnLewis like this.
  16. JohnLewis
    JohnLewis
    Already pretty much answered. I'm not 100% on in lines but small blocks are usually garuanteed to be 5 quarts. Filters depending on size are going to make up .2-.5 of a quart
  17. JohnLewis
    JohnLewis
    Put atleast 5 in it and if it starts ticking add a quart. 4 would be atleast at the minimum and and 6? At the most I'd say. To much oil you'll get a crank slap.
  18. Budget36
    Budget36
    And the question surfaces…
  19. 5window
    5window
    The best way to get answers! But this is the 19th post and Dodge as only been mentioned once. The HAMB is slipping.
  20. squirrel
    The owners manual usually has this information in an easy to find place...although you'd need the owner's manual for the engine came from.
    This is for a 59 truck, might help.
  21. Dyno Dave
    Dyno Dave
    My BAD.....Totally forgot to mention the 261 is from a 1960 Canadian Pontiac Sedan. Came with a # 848 head, I retained the hydraulic lifters and deleted the fabric timing gears. So still on the hunt for that oil can count. Thanks to all that replied.... Dyno Dave
  22. squirrel
    how about a picture of your oil pan?
    But it still holds 5 plus the filter.
    anthony myrick likes this.
  23. Dyno Dave
    Dyno Dave
  24. Dyno Dave
    Dyno Dave
    Out of curiosity I'll get a photo posted, thinking it's a standard Chevy pan. Could I ask what oil brand and rate you would suggest to use in this street engine...
    To Close This Post OFF.... Canadian Pontiac 261 with filter take (6) quarts of engine oil. Thanks to all that forwarded information, dyno dave
