The Ultimate 235 Hop up Thread.......
Discussion in 'The Hokey Ass Message Board' started by SLAMIT, Jan 20, 2011.
  1. I believe Melling does.
  2. drumyn29
    drumyn29
    I think the issue was these main bearings drop right in using the dowel to guide and place it, somehow my dowel was misaligned even though it turned over perfect when I built it. Re-did the machine work on the engine today and will ***emble this week.
    Screenshot 2024-01-21 at 12.38.42 PM.png Screenshot 2024-01-21 at 12.38.48 PM.png
  3. drumyn29
    drumyn29
    Has anyone given thought to using a die grinder and making a small valley from the oil hole on the engine to the threaded stud hole so it can get to the rockers without using the special bolt with the hole in the center?
  4. Baumi
    Baumi
    No I haven‘t, but you could just cut back the Head gasket in this area. I have no clue if this is a good oder or not… but I‘d rather sacrifice a headgasket than the deck of a good block!
    jet996 likes this.
