Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is it 59” ? If so your looking at a 4x4 rear.
  3. lumpy 63
    lumpy 63
    2002 chevy blazer extreme. Has parking brake in rotor. Looks identical to yours
  4. squirrel
    If it were a Camaro rear it would have the mounting for the torque arm, eh?
  5. lumpy 63
    lumpy 63
    Pretty sure its blazer
  6. Grabbed some more 292 stuff.
    Laugh if ya want but this cam has all its lobes.
    Lifters labeled to match each lobe.
    Grabbed the head, another carb, and brackets. Mine had the wrong alt pulley. We good now.
    It’s not a hot rod engine.
    and I grab these 4 blade fans when I find em
  7. Jkmar73
    Jkmar73
    from Tulare, CA
    Working on steering for my model A. Steering angle and header size are making it more difficult than I thought. Am thinking of running two double joints to get proper angle. Single joint on bottom has a bit of a bind. IMG_1318.jpeg
  8. choptop40
    choptop40
    Make sure they are phased also....double joints dont require a support i think...
    Bill's Auto Works likes this.
  9. Jkmar73
    Jkmar73
    from Tulare, CA
    Yes, I agree about the phasing of the joints. I do think that a support is required for it as there will be 4 joints in play. I already have the guide bushing to use.
  10. badgascoupe
    badgascoupe
    With this cold spell I've been playing in the barn and feeding its wood stove.Got all the wood cut to the proper lengths,now can see where holes need to be.
    Okie Pete, saltflats, GuyW and 3 others like this.
  11. I guess this is what sent the 292 to the bone yard
  12. lumpy 63
    lumpy 63
    Intake or exhaust?
    enloe likes this.
  13. Exhaust
    The rest of it looks great so far
    Pulled a cam out of another one on Friday.
    Yea it’s used. I know…….
    But the plan for this one is seal it and send it
    It’s a beater we use to haul s**** and go on parts runs with
  14. lumpy 63
    lumpy 63
    That would make sense because it would backfire out the intake like a big dog:confused:
  15. The advance on the distributor was un hooked. New points…..new wire to coil.
    Bet they were chasing down what they thought was an ignition issue.
  16. lumpy 63
    lumpy 63
    Back in the 80s customers would come in with late 70s sbc's backfiring through the intake thinking they needed a tune up. They weren't real pleased with the flat cam diagnosis:rolleyes:
  17. Seems wiping cams is traditional :)
  18. lumpy 63
    lumpy 63
    Chevy had a problem with soft cams in the mid 70s for sure.
  19. lumpy 63
    lumpy 63
    20240127_182728.jpg 20240127_182739.jpg Started polishing these old edelbrock covers. They were on the 301 in the vette when I got it. I think they were installed in the early 70s and never run on the engine. I picked up some moon breathers to run on em.
  20. saltflats
    saltflats
    from Missouri
    Think I have a new old stock set of 6 cylinder GM lifters if you need.
  21. squirrel
    Playing with the cruise control on the Corvette, it's been having a pulsing pedal, quick surging. I redid the cable mount at the carb, made a less flexible bracket. I'm going on little drive to Tucson tomorrow, I'll see if that helped.
  22. I’d hate to waste NOS parts on this old beater :)
    enloe, 427 sleeper and saltflats like this.
  23. guthriesmith
    guthriesmith
    Worked on loading up a 53 Chevy today that my son bought. Pretty decent car that was parked 20 years ago to fix a transmission oil leak that ended up being the dipstick. Car never got put back together.
    IMG_8153.jpeg IMG_9109.jpeg IMG_9111.jpeg IMG_9112.jpeg IMG_9110.jpeg IMG_9113.jpeg IMG_8155.jpeg IMG_8181.jpeg IMG_9119.jpeg
  24. Dick Stevens
    Dick Stevens
    I'd want more than 2 strips of masking tape holding the hood down before I'd drive it though!
    enloe, chryslerfan55, 29A-V8 and 3 others like this.
  25. That’s called adventure driving
    had a chain and lock holding my 57 ford hood in high school
    enloe, chryslerfan55, 29A-V8 and 4 others like this.
  26. guthriesmith
    guthriesmith
    LOL! Those are actually ratchet straps but they do look like masking tape now that you mention it.
  27. Spent a lot of time cruising in a friend's '53 four door Belair in '67 and '68. There's also a four door '53 on my way to our rural school where I subs***ute frequently. I see it twice a day and each time it jars a pleasant memory. Sure like what you got. Nice score!
  28. Car doesn’t even need paint
    lucky
  29. LOL! Me too, Anthony. Me too.
    Ben
