Technical Saving a 39 Conv dash (updated pics)
Discussion in 'The Hokey Ass Message Board' started by ronzmtrwrx, Jan 20, 2024.
  1. ronzmtrwrx
    ronzmtrwrx
    This kind of a side thread that goes along with my 39 Ford Conv build. Progress is slow on the rest of the car, so I decided to tackle the dash repair so I might at least feel like I was moving forward. Here’s where it begins 8745426C-FA07-46F2-8AAB-E29B3986CC1B.jpeg In its earlier life, in the 50’s the owner added gauges out of a late 40’s or so Studebaker. 33A585CF-0E5D-4868-8EF0-6D6889F5936C.jpeg Make it fit however you can, right? They were not too kind to the dash. DE365546-A608-4F2E-8F39-243C5A3C608B.jpeg
    No problem. Just hammer out as best you can and find a donor piece to repair the damage. That’s where the fun begins. The convertibles and woodies had a different shaped dashboard than the open cars. These tapered from the inside edge of the gauge area out to the vertical line on the left side of the gauge holes. Same shape on the glove box door also. Well as you would expect, a donor piece from a Conv dash is not easy to find. So, I snagged the gauge area from a closed car dash from a fellow HAMBer and proceeded to make it fit. B9A3FA04-E4E8-427C-AA65-C9E82082B632.jpeg 61F33136-4A6A-4111-A2CA-EE7CFD208E6B.jpeg This was real fun, prying the lip up to remove the gauge mounts. It had to be removed so I could cut a wedge shape piece out to create the taper needed to make it fit. B6C60745-BF08-4F51-9964-25DAA406477C.jpeg 8257F9B1-B44F-4B48-9330-F6E86E828A1F.jpeg 0F9BA818-AEC0-4BF0-BCBC-E3B21981DA86.jpeg
    After tacking and then welding it up, I proceeded to smooth it up before making the transplant. 903E671F-BB74-4C6A-9507-7CFF82B77669.jpeg FA639FF2-88C1-4CC0-9CDC-52D999B5EB66.jpeg 7ADA058B-4A9C-4428-AEE4-31F793BE0D7B.jpeg 5FD1A0F8-2E43-4D72-A7CE-C7DE1DD27433.jpeg
    After careful fitting, I welded it up and started the finish work. That’s where I had to stop for the day. I’ll follow up after I get it all smoothed out. I did fail to get good pics of replacing that gauge mounting panel. That was not much fun, but all part of the job.
  2. alchemy
    alchemy
    Impressive repair, you do good work!
    Tow Truck Tom and ronzmtrwrx like this.
  3. L. Eckart
    L. Eckart
    Looks very nice!
  4. ronzmtrwrx
    ronzmtrwrx
    I had my 10 year old grandson working on stripping and sanding the glove box door. He says he wants to be the first to drive it when he turns 16. I said we better kick it in gear. Lol CFB96E80-C713-4556-8643-1AE5D4F88AA4.jpeg
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    With thar promise in mind you might 'get'rdone'
    That dash will certainly come to a happy end from what we've been shown.
    Thank You Ronzmtrwrx for the progress report
    ronzmtrwrx likes this.
  6. The 39 guy
    The 39 guy
    Nice job on your dash!
  7. Dak Rat
    Dak Rat
    from NoDak
    Most excellent work, you are a craftsman.
  8. brading
    brading
    You have made a nice job of that.
  9. ronzmtrwrx
    ronzmtrwrx
    Finished off smoothing up and checking the fit of the trim pieces. I believe it will p***. CABFE479-93DC-4AB8-8D09-5695D036F908.jpeg B03F8147-8774-495C-B94C-372DB17B537E.jpeg 2E1E172F-73D5-4E6A-B44E-844A22E9F40E.jpeg BFD36515-C144-480A-858B-07CD0C969EF5.jpeg
  10. Jethro
    Jethro
  11. BJR
    BJR
    Looks like it never was screwed up.:)
  12. ronzmtrwrx
    ronzmtrwrx
    Thanks. She’s got a couple little spots that aren’t perfect, but a little bit of primer should cure those ills.
    Tow Truck Tom and BJR like this.
  13. Fortunateson
    Fortunateson
    That glove box door looks great!
  14. Looks super.
    hope you saved those cool original gauges.
    Tow Truck Tom likes this.
  15. ronzmtrwrx
    ronzmtrwrx
    I did, but the speedometer has seen better days. The quad gauge still looks pretty good. The diameter of them is the same as the Ford gauges that are meant for it. The prior owner could have modified them to fit the original dash but they went a different route. I might actually try to use them, just to have something a little different. They were out of a 47 Studebaker with the bezel cut down to "sorta" fit. lol
    Tow Truck Tom and anthony myrick like this.
  16. The 39 guy
    The 39 guy
    Excellent work!
  17. ronzmtrwrx
    ronzmtrwrx
    Thank you, sir.
  18. deuceguy
    deuceguy
