Technical Need a SBC measurement Motor mount to front of WP.
Discussion in 'The Hokey Ass Message Board' started by movin/on, Jan 23, 2024.
  1. movin/on
    movin/on
    I'm mocking up a 1931 Model A and at this time no SBC.
    I'd like to get the distance from the center of the Motor mount to the front of the WP shaft flange.
    I'd like to know how far back the mounts should be from the Radiator. I can always use a pulley/fan spacer.
    Movin/on
  2. 19Eddy30
    19Eddy30
    from VA
    Pete & Jacks has the measurements on there site , for weld / bolt in mounts SBC A & 32 33-34 frames
  3. -Brent-
    -Brent-
    I can get measurements for you tonight if your questions aren't answered.
  4. Oneball
    Oneball
    There’s more than one length of water pump on a SBC. Do you want a short water pump measurement, I can look at the Vette in the morning.
  5. 19Eddy30
    19Eddy30
    from VA
    Typically(sbc) measurements are for the short "" Vett style water pump
  6. 05snopro440
    05snopro440
    From the center of the bottom motor mount bolt hole to the front of the short water pump flange is about 11-1/4". That's without gaskets between the pump and block. The shaft of the pump sticks out about 1/2" past the flange on my pump. That's a short pump on a '67 283 measured on an engine stand in the garage.
    I don't know your motor mount design, so hopefully that's a useful measurement for you.
  7. squirrel
    get all the parts together, before you start making mounts. Then you'll only have to do it once.
  8. Jmountainjr
    Jmountainjr
    ^^ This. You didn't say what style motor mounts. ***uming side mounts, you might be using ones with a doughnut style rubber, or ones with a factory style bonded rubber. Usually frame and/or tire rake puts the front of the engine down, and carb and driveline may want the rear of the engine down. You probally can get enough play to overcome this with a doughnut rubber, albeit it under strain, if you put your frame mount flat to the frame. With a factory style mount with a horizontal bolt connection, maybe not. Things work best without a lot of strain on the parts. If you must drive ahead, at least get the frame set up with the rake you will use and then set the frame mount 2-3 degrees down.
    05snopro440 likes this.
  9. movin/on
    movin/on
    I didn't realize there were so many options. I'm a Ford FE guy installing a SBC into a friend's car.
    I've been welding for 50+ years and know about the details, but "measure twice and cut once" is my practice.
    Since I don't have the SBC Thats why I asked. I do have a Model A frame (SBC mounts) of my own here but wanted some satisfaction of the location. That was done 30years ago. How much longer is the long WP from the short?
    Movin/on
  10. 19Eddy30
    19Eddy30
    from VA
    Other details on where motor mounts would go , Best to cut Firewall First , then mock up to set motor mounts & clearances between Radiator ,then fab the firewall as needed / want ..
    This is with the measurements from P&J's motor mounts off stock location on side of block , Vega box...
    With radiator in stock location
    With fenders , SBC in pic has a Zipp's water pump riser , ( with straight 6 chev water pump ) witch is same distance of short v8 Vett pump , ( block to water pump flang where pulley bolts to,,
    with spacer shown in pic would be with long water pump ( with out fan spacer )
    Fan is 1-1/2 from radator ,
    Zip riser moves fan to center of radator ,
    ""With Out zip "" riser the center of fan will be 3-1/2 to 4 inch lower ,
    With Radator in Stock location ,
    With Stock ,Firewall ( 30-31 shown)
    will need to be cut / modified to clear distributor & back side for heads ,
    more on P***enger side.. Not Sure on 28-29
  11. Oneball
    Oneball
    On my Vette 296mm along the ch***is rail from the centre bolt of the motor mount to the face of the pulley, you’re relying on me getting it square!
  12. 19Eddy30
    19Eddy30
    from VA
    From center motor mount bolt on block
    To flange where water pump pulley
    Is 11 -1/2 inches , Short Vett pump
  13. pprather
    pprather
  14. 1971BB427
    1971BB427
    from Oregon
    You'll save nothing by trying to build now without an engine in there for mockup. And likely create problems you'll have to rework later if anything is even a little off.
    I'd simply concentrate on other things on the build until you have your engine, or can maybe borrow a block to use for mockup.
    There's always plenty to take up time on most builds.
  15. nochop
    nochop
    from norcal
    I would probably mock up with trans installed as well. Measure twice…..etc etc. I like exhaust too as a retired plumber, waste dictates
    05snopro440 and -Brent- like this.
  16. DDDenny
    I've never seen a reason to even consider using a long water pump on a hot rod, especially starting with a fresh build, and the justification of using it because it was already on the engine with all the matching bracketry, pulleys, etc escapes me.
    If for no other reason than those long water pumps and related OEM hardware are just plain ugly.
  17. ekimneirbo
    ekimneirbo
    ^^^^^^^^^^^^Whut he said^^^^^^^^
    Trying to do it with a measurement will lead to problems later. You need to know how the exhausts will interact with the frame and the mount as well as the steering. You can pick up smallblock cores for as little as $100 and resell them when you are done.......or keep them. You need to know up and down as well as fore and aft...........
    05snopro440 and nochop like this.
  18. ekimneirbo
    ekimneirbo
    Maybe these will help? One is a V8 and the other is a V6 which is a V8 with 2 cylinders removed. Don't know which water pump it used. Chevy SB left side.jpg
  19. '29 Gizmo
    '29 Gizmo
    from UK
  20. DDDenny
    Now that is suitable for framing, just needs the emblem and the bowtie in the frontal view photoshopped out first.
    '29 Gizmo and sdluck like this.
  21. '29 Gizmo
    '29 Gizmo
    from UK
  22. squirrel
    on your drawings, the V8 has the short pump, the V6 has the long pump. I can tell by the lower pulleys.
    19Eddy30 and ekimneirbo like this.
  23. ekimneirbo
    ekimneirbo
    Do you know the difference between the two? I knew a couple weeks ago, but my old-timers has been active lately.:)
  24. squirrel
    I don't have both to look at right now. The long one is about an inch longer where the back of the pump is, but the shaft length might not be that much different. I tend to keep them totally separate in my mind, so I haven't really bothered comparing them. Short pump setups get short pump parts, long pump setups get long pump parts, never the twain shall meet.
    427 sleeper and ekimneirbo like this.
  25. pprather
    pprather
  26. 05snopro440
    05snopro440
    The long pump is 1-3/8" longer than the short pump on a SBC.
    I wouldn't place the engine mounts without an engine. Oil pan clearance, crank pulley clearance, exhaust location, and distributor clearance are all important items to know.
    427 sleeper and nochop like this.
  27. DDDenny
    Yep, simply the type of exhaust manifold/header/steering column/ location can create a real cluster f#@k if not planned as a whole.
    sdluck, 427 sleeper and nochop like this.
