Hot Rods Hemi freeze plug question
Discussion in 'The Hokey Ass Message Board' started by shaunez, Feb 29, 2020.
  1. Just being devils advocate, over time could the HH 2 piece plugs( which are obviously good quality) be a ****** to get out?
    While undoing the cap screw, what happens if the T bar starts turning with the cap screw once backed off slightly?
    Just a thought, as a lot of these type of things are made for limited hour use, not longer term.
    I read there have been long term use with no leaks but what about removal after that long term,, just a question.
    nochop likes this.
  2. slayer
    slayer
    I know that car! I think we (Dad and I) met you at the Voodoo Kings cruise night at woodfire chicken in Itasca. We would have been in our whiteValiant,and would have been asking questions about your Hemi.
    Hemi-roid likes this.
  3. coop46
    coop46
    from New Jersey
    Could be.... I never had to take a set out that have been in long. These were in for 3 years but the motor hasn't been run. The bolt is stainless. The guys are right on that YES / NO picture. The wrong way and you barely get a squeee on the o-ring..... then the whole thing spins. The only thing I would do is go up a bolt size if I made a set.
    Desoto291Hemi likes this.
  4. Hemi-roid
    Hemi-roid
    from Cary, IL
    Yep! I haven't been making longer distance cruise nights as often as I used to. By the time I get off work and get to the cruise night, it's almost over. I've been going to the Broken Oar, Cary, and McHenry cruise nights because they're close to home. I'm hoping to retire soon, and get back to cruising longer distance and having fun.
    slayer likes this.
  5. Hemi-roid
    Hemi-roid
    from Cary, IL
    I made everything out of stainless to help prevent that, or at least slow it down. Since I made them myself, if I had to drill or cut them out to remove them, it wouldn't be any loss. I can just make a replacement. I doubt I have $5 apiece (other than my time) invested in them.
    Barrelnose pickup likes this.
  6. coop46
    coop46
    from New Jersey
    So let me ask.... these things look great and seal fine when installed right, but where does the freeze protection come in?? These thing would never pop on a freeze up.
  7. 57 Fargo
    57 Fargo
    It doesn’t because despite everyone calling them frost or freeze plugs they have nothing to do with freezing whatsoever. Correctly called core plugs, the holes are there to remove sand from the casting process, lots of engines don’t have core plugs at all…
  8. nrgwizard
    nrgwizard
    from Minn. uSA
    Freeze Protection:
    It's called: *Properly* calibrated-for-the-(low)-temp-protection-needed-for-your-area-temps = Anti-Freeze. Either propylene glycol or ethylene gylcol . Also ***ists w/ raising the boiling temps, as does increased pressure for the closed-system cooling system. They use to use alcohol.
    As mentioned before, a couple of times: the *core* plugs/holes are actually for the sand-casting cores-extensions that position & hold the sand core (hopefully)correctly in place inside the larger pattern which has compacted sand all around it to provide the correct external & internal shape(s), while the whole mess is slathered & drowned in molten metal. Usually cast iron, or aluminum. Once cooled, they're broken off, the casting vibrated & hopefully, the internal-sand-mold breaks apart & all the sand & wires that are also in the sand-core come out of the casting. Most goes through other openings in the block like water-pump p***ageways, head-p***ageways for coolant, & also some oil p***ageways, etc. Doesn't always happen, completely. Posting pics would probably make things easier, but I'm not good w/that. ;( .
    Being referred to incorrectly, even for decades(or maybe a century+) doesn't change the definition.
    Hth.
    Marcus...
    Just Gary, loudbang and twenty8 like this.
  9. slayer
    slayer
    I huess you never saw a a block with freeze cracks and all the plugs still in place. A friend if mine ruined a fresh buint AMC 258 because he forgot to put antifreeze when he built it.there was a foot long crack in the side of the block, but the core plugs were hanging tight. Hard and expensive lesson learned.
    gimpyshotrods and loudbang like this.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Go to a marina or boat storage yard in the spring & you can observe first hand that "freeze plugs" have no effect on block damage !
    slayer and 57 Fargo like this.
  11. coop46
    coop46
    from New Jersey
    Interesting..... but I've never heard these thing ever called anything other than a freeze or freeze out plug. Ok so this has come up because my "core" plugs were leaking. In flipping the strong back around which the builder put in backwards I feel some grit in those bores. Sand from the casting process I presume? Shouldn't it all be flushed out? And whats the chance of this "grit" migrating to the oil side with a bad gasket? Or is that impossible? Thanks for the edumaction fella's
  12. coop46
    coop46
    from New Jersey
    The slang term "freeze plug" was coined many decades ago out of ignorance of the true purpose of the core plugs - they were never designed to be displaced by water freezing inside the block due to a lack of an anti-freeze/water mixture and their displacement is merely coincidental if freezing does occur.
    gimpyshotrods likes this.
  13. Jack E/NJ
    Jack E/NJ
    from NJ
    coop46>>I feel some grit in those bores. Sand from the casting process I presume? >>And whats the chance of this "grit" migrating to the oil side with a bad gasket?>>
    Ed Murphy already calculated the chance is 100% in your case.
  14. coop46
    coop46
    from New Jersey
    Murphy's law? Why do you say? I'm gona have the motor torn down, inspected and re***embled just for piece of mind.
  15. slayer
    slayer
    Are you just fealing the ruff casting or is there loose sand like grit in the block. Just so your aware, the opening in the cor plug holes are ruff cast, not machined.
  16. coop46
    coop46
    from New Jersey
    Loose sand grit.....
  17. Oneball
    Oneball
    There’s always rubbish in the cooling jacket somewhere. Don’t worry about it. Give the cooling system a rinse through. Fill with antifreeze and away you go.
    coop46 and slayer like this.
