Technical what solutions clean diamondback whitewalls to snowwhite
Discussion in 'The Hokey Ass Message Board' started by dr nick, Jan 12, 2024.
Tags:
  1. formulas
    3 vote(s)
    60.0%
  2. solutions
    2 vote(s)
    40.0%
  1. noboD
    noboD
    Lestoil. It's getting hard to find but it is killer for tires or any rubber part.
  2. HOTRODPRIMER
    HOTRODPRIMER
    I recently saw this product at Wallmart. HRP
  3. Mike Lawless
    Mike Lawless
    This is absolutely true. However I still use it on the wide whitewalls of my HD deluxe a couple times a year. The thing about that, is the tires on motorcycles don't last all that long, so by the time the sidewalls are showing visible cracks, the tread is done....***uming one actually rides their bike.
    On a car.....hard to say. Tires seem to be done well before the tread is gone these days. The common theme is about five years.
    I can't disagree with that since I had a set of six year old tires delaminate as we approached Rapid City, SD last year on our cross country road trip return leg. They had 15,000 miles on 'em.
    So, the question is, how long are you gonna have those tires?
    texasred likes this.
  4. Bandit Billy
    Bandit Billy
    When I ordered my DB Auburn WW's, there was a red tag on each tire warning not to use bleach products on the tires.
  5. 38bill
    38bill
    from Minnesota
    Been using Simply Green and green Scotch-Brite for 22 years on my set of DB whitewalls and they still looked like new. As mentioned its better to keep them clean or they can become stained.
    ps: I just replaced them this fall due to the age so don't panic. They looked like new in and out. I'm actually more concerned now as I question if todays tires are as good as they used to be.
    The 39 guy, Hotrodmyk and rockable like this.
  6. Lone Star Mopar
    Lone Star Mopar
    Im with the Magic Eraser crowd, some warm soapy water and elbow grease.
  7. Scumdog
    Scumdog
    Does anybody use (recommend?) a dressing to use on tyres after the whitewalls have been scrubbed clean? ie to keep the white looking white and the black section of the tyre looking deep black.
  8. Joe Blow
    Joe Blow
    SOS pad....works fantastic. They're made with biodegradable soaps and detergents for the rubber. Been using them for white walls/letters since I was a kid.
  9. ebfabman
    ebfabman
  10. Scumdog
    Scumdog
    Is that to whiten the whitewalls or is it to 'dress' the tyres as per my earlier post?
  11. theHIGHLANDER
    theHIGHLANDER
    Bleech-White DOES NOT work like it used to. In fact it's a joke. I bought a gallon of cleaner from bLowes (something 88?) for like 7 bucks. The down side is ya gotta wait a bit and re-apply before you get to it. Old stock Bleech White is liquid gold now. It used to be the standard and left a literal shine on ww tires. This new **** they use the name on is a placebo. If the product you're using isn't pulling a nasty baby **** color out of the tire it isn't working, the end. Black or white, it better be turning brown when wet or it's gonna dry brown when you're done. 7.50-17 wide whites are no day at the beach to clean especially when there's 6 of them *****es, so yeah the "new" Bleech-White sux.
  12. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Rub-O-Matic.jpeg This is when all other stuff fails.
    The only stuff I've found to remove the brown leaching into Whitewalls.
    Use with a 3M Scotch Bright pad. You don't have to rub hard.
    The Rub-O-Matic solution will remove / clean the whitewall with little effort.
    Strong stuff, not $ cheap but good ****.
    You can use a follow up with Purple Power to maintain whiteness and keep some moister in the Whitewalls.
    https://www.google.com/aclk?sa=l&ai...EwiWqNzNg_aDAxWvAzQIHbpRA1E4PBDDDwiuCA&adurl=
    AHotRod likes this.
  13. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Same here. Purple power doesn't strip and make the WW brittle and dry.
  14. hudson48
    hudson48
    Ed is that the degreaser product or one for whitewalls specifically. It is availabe here in Australia but only degreaser.
  15. The 39 guy
    The 39 guy
    I use simple green. Spray it on a small section scower with a soft nylon sponge ,then wipe off the area with a paper towel.
    The main goal is to not damage the glossy finish on white wall. NEVER use bleach or SOS pads.
  16. rottenrod
    rottenrod
    I use simple green and a hard bristle nylon brush on my Coker’s.
  17. ebfabman
    ebfabman
    It is a degreaser. I've used it for a while now and no issues. No scrubbing needed. Spay in on and rub it off. Leaves the white walls clean and bright.
  18. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    The challenging part is if the vulcanized rubber is leaching from the inside out that stains the white wall.
    That’s when heavy duty stuff has to be used and sometimes not able to completely get rid of inside out leaching.......
    That's when it ****s.
    New whitewalls have gotten very expensive.
  19. "WHAT SOLUTIONS CLEAN ......TO SNOW WHITE?"
    There was a girl in town that everyone called "Snow White"........
    .......but eventually, she drifted. :confused: :D
  20. bobbytnm
    bobbytnm
    I'll second that. As a kid Dad would make us boys scrub the whitewalls with an SOS pad before every trip. Works like a charm (especially if you can get your boys to do the dirty work)...LOL
    I still use the SOS on the wide whites on my Harley
    Joe Blow likes this.
  21. bigm
    bigm
    from Orange, CA
    This stuff works great. Use a soft brush, then rinse well.
  22. I have used Tuf Shine Tire Cleaner and Tire Clearcoat using their brush and sponge applicator on my Dback whitewalls. I'm very pleased, white as snow, black wall not to shiny 20240301_121654.jpg 20240301_121654.jpg 20240301_121625.jpg
    7car7 and jim snow like this.
  23. oldiron 440
    oldiron 440
    If Bleach White alone doesn’t get it go over with Comet scrub again and rinse.
  24. Chavezk21
    Chavezk21
    Gray scotch brite and dawn dish spray. Worked awesome on the white walls on my buddy's bike.
  25. 7car7
    7car7
    from Washington
    Hope I'm not too off topic, but I just received some brand new DB's. They have the blue coating. They came with a paper that says to wash off with only water. My question is, should they be cleaned before mounting? Or after?
    Just overthinking if some of the blue will get stuck on the rim contact point and seep out?
    jim snow likes this.
  26. 38bill
    38bill
    from Minnesota
    I always wash just enough of the blue film off so its not in the way of mounting.
    7car7 likes this.
  27. Roothawg
    Roothawg
    YES!!!!! This stuff is so easy to use.
  28. Fortunateson
    Fortunateson
    Used to be...
  29. 4speed411
    4speed411
    Scrubbing Bubbles bathroom foam cleaner is all I ever use
  30. 57JoeFoMoPar
    57JoeFoMoPar
