Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Took the headlights for our '47 apart and slotted the backside of the adjustment screws along with making a couple access holes in the buckets. Put some new wires and loom on them along with a couple of NOS bulbs. Will see if this works for adjusting them once they go in from under the fender.
    charleyw, rod1, Chucky and 3 others like this.
  2. choptop40
    choptop40
    Took inventory of the trunk full of parts in the 50 Desoto........Got lucky.........2 NOS upper grille bars , didnt know they were in there...One will fetch some decent coin... C8322449-595D-4A42-B7D3-7FFB74613802.jpeg 99F39191-83CD-4799-8D91-23F58B5F4B4C.jpeg
  3. flux capacitor
    flux capacitor
  4. Oneball
    Oneball
    flux capacitor likes this.
  5. flux capacitor
    flux capacitor
    Thank you , lotta time in it & nice to bring it back to life. An old friend who past not long ago was nice enough to dig it out & it reminds me of him ❤️ he wanted to see it used
  6. berijillel
    berijillel
    osage orange and flux capacitor like this.
  7. Chucky
    Chucky
    You mounted your steering column with exhaust clamps?:eek: At $4.50 each, you damn right I did.
  8. Pete1
    Pete1
    from Wa.
    Breathed it around that it was for sale.
  9. Jkmar73
    Jkmar73
    from Tulare, CA
    Got the steering finished. Had to use two double joints to get the clearance around the headers and the correct angle to get to the shaft coming out of the steering box. Just have to make a bracket for the support bearing. Probably will come off of the top of the frame. Also made up exhaust hangers and welded them in. IMG_1328.jpeg
  10. Put the lights on our '47, also messed around with the nose of the hood some more. Hoping someone would show up so I could take it off and finish it; but it was quiet today. Stuck an old top grille bar on to check if everything was still in the right place.
  11. flux capacitor
    flux capacitor
    Thank you ! More of same today
  12. Rounded up the grille parts from various hiding places and after a couple hours had it together. Shoulda been quicker; but the spring clips were a nuisance to get in place. Next step; see if it still fits in car.
    TigerFan, 40two, LAROKE and 9 others like this.
  13. Pontmerc
    Pontmerc
    from Finland
    Test drive, fixing heater.just examine it.
    My latest purchase...its a 1962 volvo amazon kustom.need to think something different for that front grille, which currently resembless too much east german build trabant.... 17065375739707463360224826542772.jpg 17065376135308784807541027318688.jpg 17065376407964215707297914131226.jpg
    TigerFan and 40two like this.
  14. TA DAD
    TA DAD
    from NC
    This ram air build has been the toughest thing to get it where I am satisfied with the look. This fender inlet is like the fifth rendition. But I could not be happier. Mig welding rust and that stainless screen is always a challenge. The worst part is now I have to do it one more time !
  15. Chucky
    Chucky
    Final steering mods included flipping column to underside of lower mount and building custom angled upper hex couplings which position the upper mount in a more perpendicular relation to the column. Bottom line, the steering works!!!
  16. Not much done today; glued in some felt sealing strips between the inner pan and radiator and bolted the grille in place.
    skooch, charleyw, Chucky and 6 others like this.
  17. 5C051583-B77A-4E8A-A8CD-4DA0464EDB00.jpeg Finished up wiring the 57 3100 and fired her up. All bulb NO led. (Got lucky with the pic) but man she’s bright!
    Gotta figure out what’s up with the Voltmeter.
    Iron Lords Forever/Forever Iron Lords
  18. choptop40
    choptop40
    Got this for the Desoto.. going with Turbo 400. … 27B9B729-DA6E-467E-9912-49EC4A6EB238.jpeg
    TA DAD and A.D.D. like this.
  19. A.D.D.
    A.D.D.
    from PacNW
    Installed LED bulbs for the ‘52. Had some old discontinued lights at work, grabbed ‘em.
    Also, installed my “Traffic Minder” Guide traffic light thingie… so, I can see the light change (windshield in the ‘52 is kinda low).
  20. nobby
    nobby
    trikejunkie and RICH B like this.
  21. 65type1
    65type1
    Made a ghetto tonneau cover from a canvas tarp.
    LAROKE, swade41, 40two and 2 others like this.
  22. Scott Younker
    Scott Younker
    Installed Pie Crust Cheaters on the 32
  23. TigerFan
    TigerFan
    from Athens, GA
    I dropped my column a bit, and made a door so I can access my master cylinder through the floor once everything is together. I also worked on a bracket to add another connection point between the body and subrails. I have to give a shout out to Cornfield Customs for the coining tool to round out beads. Wow, it makes a difference.
  24. TA DAD
    TA DAD
    from NC
    Working on my fender to keep it from blowing off at around 80 or 90. This should keep it intact to at least 100. Lol IMG_1234.JPG IMG_1236.JPG IMG_1235.JPG
  25. WC145
    WC145
    from Maine
  26. Got up to the shop and found another welder sitting in the middle of the place.
    Added some fender welt to the front pan and since John stopped by I enlisted his help to tighten all the bolts and screws that hold the front clip together.
    Moved on to the bumper and found out one of the brackets was bent. Really don't know how you can take an unbent bumper off a car and remove, blast, and paint the irons and end up with one bent about 4" out of place. One of Drake's bumpers fit the other three and doesn't look too bad IMG20240208111050.jpg IMG20240208172731.jpg
    TigerFan, TA DAD, lurker mick and 2 others like this.
  27. BigRRR
    BigRRR
    Hey Chucky ... Curious to the make/year of your ride - I noticed the trim badges on your dash, I have one that's been hangin around forever ... was in my grandfather's parts pile, my dads, and now mine - always wondered what it was out of it!
  28. Chucky
    Chucky
    1941 Studebaker Champion
    @BigRRR
  29. BigRRR
    BigRRR
    Thanks ... My tool cabinet is covered in old emblems ... most of them I know the origin of, but that one I had no idea until now :)
    Chucky likes this.
  30. TA DAD
    TA DAD
    from NC
    I got the reinforcements welded in, still a little work to finish things up on this fender. I got to get it back on the road ! I miss getting my fix . IMG_1242.JPG IMG_1239.JPG
