Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
    That ****s Johnny . Been there.
  2. mopacltd
    mopacltd
    This ch***is only getting small motors
  3. ironandsteele
    ironandsteele
    I'm working on what was supposed to be a quick king pin swap that quickly turned into king pins, axle repair, wheel cylinders, brake hoses, wheel stud repair and a height adjustment.... so far. :rolleyes:
    ironandsteele.com​
  4. lumpy 63
    lumpy 63
    Tore apart the "nasty" looking 350 this afternoon... That thing was freakin cherry inside! Still had hone marks and the plastic cam gear had very little wear! Lifters pulled out with no effort. Probably woulda done 50,000 more miles:D Off to the machine shop tomorrow , bore .030 zero deck and stuff all that NOS chevy hi po stuff in it.
  5. mopacltd
    mopacltd
  6. snoc653
    snoc653
    from Iowa
    The big block is ready to start re***embling for the 2nd time. The builder that did the machine work left everything very dirty with dirt ground into the new rod bearings, so we had to take it apart and hone the lifter bores, drill the extra water p***ages, coat the lifter valley and clean out the trash left in the block order a new set of rod bearings sized to fit properly. It was ***embled with standard bearings, had to order 4 stdx bearings to get the right clearances.
  7. lumpy 63
    lumpy 63
    Dropped off the 350 block at the machine shop came home and ground on the turbo heads for a couple of hours taking out all the sharp edges and gasket matching em. I pretty sure grinding on cast iron heads is also becoming a thing of the past...
    enloe, High test 63, BigRRR and 11 others like this.
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
    Finished up all the welding and painting on the 56 Chevy frame that can be done before the body goes back on, then Ahron will start on welding in the cage.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Latter bars and sway bar.
    427 sleeper likes this.
  10. GuyW
    GuyW
    Look like rear axle will attempt to move on an arc from front spring eye, and on a different arc from ladder bars.
  11. Marty Strode
    Marty Strode
    He has spring sliders at the axle.
  12. Tickety Boo
    Tickety Boo
    from Wisconsin
    8.jpg A better picture of the slider
  13. Tickety Boo
    Tickety Boo
    from Wisconsin
    Hoping the anti-roll bar will keep the car square and straight off the line, take some of the twist stress off the ladder bars. :rolleyes:
  14. GuyW
    GuyW
    Thanx - good photos and a real nice job on the car
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    Thank You GuyW,
    Will find out how good of a job, when we find out how straight it goes, and how it hooks.
  16. lumpy 63
    lumpy 63
    I helped my friend Butch put one on his Willys , the truck has ladder bars and would twist pretty hard on launch. The bar helped tremendously.
  17. Jkmar73
    Jkmar73
    from Tulare, CA
    Nothing on the car today. At Peterson museum today.
  18. I’m cleaning up the shop in preparation for a 1933 Ford ZZ Top replica to arrive. A local guy bought it a year or so ago and at the end last year it started running very poorly. As in it will barely pull itself. Whoever built it used a Holley Pro-Jection 4 on it. The owner is a good friend of my brother and nephew, and my nephew asked me about how to fix it. That’s easy, says I, it obviously needs a nice Holley 4 barrel. According to the owner, who allegedly ran the numbers, it’s a 400 Small Block Chevrolet. We will see. I do know it’s got angle plug heads and a Vic Jr. intake. He bought a new 3310 for it. This is what I get for shooting my mouth off. I do know the ch***is is strictly O/T so you won’t see that. Or the wheels. Hopefully it will be more fun than fixing filthy old diesel’s. Maybe between this and Lloyd’s Trukus, it will motivate my big *** to work on my 50.
  19. HOTRODNORSKIE
    HOTRODNORSKIE
    Got the headers painted and the brother powder coated the ladder bars installed the headers today what a pain on the backside what boredom does to a guy. 20240203_104420.jpg 20240203_155418.jpg 20240203_155439.jpg 20240203_155458.jpg
  20. lumpy 63
    lumpy 63
    20240203_130634.jpg Got the crate 350 , t400 and gear vendors all bolted up and installed in the AD ch***is.
  21. Take a piece of cardboard and make a list of jobs that need to be done on your truck brother. No matter how small the task. Cross it off when you do it. Makes things start moving along. And gives you milestones. That's how I do everything. I make a goal sheet for my week. I don't put stuff like "get red car done"... I'll put down "prep right fender and door on red car", "remove gl*** from blue truck", "weld patch in Pontiac quarter panel".... it's like having a boss to motivate me lol
  22. warbird1
    warbird1
    Getting the Hydro for the roadster ***embled...
  23. blue 49
    blue 49
    from Iowa
    I've been trying to shine up a pair of staggered bolt Cal Customs. I hope to put them on the 283 engine they're setting on. The machine shop is backed up a couple of months.
    Gary
  24. guthriesmith
    guthriesmith
    Those are looking good! I came real close to buying a set of those yesterday at a swap meet but don’t have anything that staggered pattern ones will fit on right now.
  25. BJR
    BJR
  26. blackdog
    blackdog
    from Golden BC
    Cleaning up a multi decade parts and shop "collection" after the p***ing of a friend and mentor.
  27. HOTRODNORSKIE
    HOTRODNORSKIE
    Car was built in 64 and raced into the early 70's it steers like a tank but thats how it was built and how it will stay.
  28. That’s a great idea Brother! I like that and will start on it tomorrow!!!
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
