Technical ***February 2024 Banger Meet Thread - Happy Groundhog's Day***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 1, 2024.
  1. Jiminy
    Jiminy
    Link to previous month: January 2024 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    April 14, 2024 4 Ever 4 Antique Nationals at Irwindale Raceway in SoCal.
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. winduptoy
    winduptoy
    checking in...got a banger Roadster fix yesterday... but the temps are cooling back off and the road salt was terrible
    lots of OT work going on at the moment
  3. Czek’d in
    winduptoy and Outback like this.
  4. Checking in.. Currently looking for adjustable cam gears!
  5. denis4x4
    denis4x4
    from Colorado
    Returning to Durango in a couple of weeks and will install my new engine. Found a ‘32 style dash that fits the ‘28-‘29 Model A and considering an update. Original tank is full of rust and was replaced with 10 Gallon tank in the bed.
  6. Outback
    Outback
    from NE Vic, Oz
    Yes sir,
    Nothing much to report, just a 12v conversion on my Genny & getting ready for the local rod run in a month.
  7. 282doorUK
    282doorUK
    Checking in with a suggestion :D
    Retson the Racer and Outback like this.
  8. wuga
    wuga
    I have just installed my equalizer intake with a pair of 97s. The intake does not come with a throttle arm and the one off my Ansen is not very comfortable on there. Is anyone aware of a throttle arm that works with this intake? Snyder's sell one, but I'm not sure if it works or do I have to make one?
    Warren
    Airborne34 likes this.
  9. walls
    walls
    If you can weld, it wouldn’t be too hard to make a custom length/shape throttle arm like the one you posted.
    https://www.ebay.com/itm/204199111531
    I had this one saved in my eBay watchlist for a year or two, but never bought one.
    Might be what you’re looking for.
  10. brokenspoke
    brokenspoke
    Charlie Yapp has a blue print for making a DYI arm
    Airborne34 and Outback like this.
  11. Stovebolt
    Stovebolt
  12. Airborne34
    Airborne34
    from Texas
    I have that same manifold with 97’s and had same problem. Charlie Yapp originally made it for the Riley 2P program but changed to Equalizer when he sold off the Riley 2P
    There needs to be some offset in the arm so none of the standard throttle arms work . All that I tried had some type of interference. I’ve been told that Charlie had a specific arm that came with the kit, but I’ve never seen one.
    The one from Snyder’s is a similar design for most and won’t work. I’ve tried the Burns arm along with several unknown arms. None of them worked.
    I ended up making one from the pattern from Scalded Dog Speed, a C.Yapp company. I used aluminum vs steel and have no problems.
    Hope this helps.
    BeaverMatt, GuyW and winduptoy like this.
  13. winduptoy
    winduptoy
    Howdy....what's the weather like under younder....snowing sideways here today
  14. Fabber McGee
    Fabber McGee
    How about up yonder? Been very little snow here this year, not much more than a foot and mostly above zero (farenheit), a lot teens and 20's. Until last week when the bottom fell out of the thermometers. Luckily, it's nearly always wind free here.
    Screenshot 2024-02-03 105813.png We need a touch of cool weather occasionally to weed out the intentionally homeless that want to live under the bridges, this should do it, haha. Supposed to be above zero tomorrow and for the near future. Gaining over 6 minutes of sun every day now and the sun is getting high enough in the sky to have some power. Shouldn't have any more extreme cold this year... especially since Al Gore overheated the planet.
    winduptoy and GuyW like this.
  15. wuga
    wuga
    Hope this helps.[/QUOTE]Riley 2P
    When I asked Charlie about the throttle arm, he never mentioned the pattern, but rather told me about the one from Snyder's. I wasn't particularly impressed with that arm so I am going to make one from your pictures. Thank you for those.
    Warren
    Airborne34 and winduptoy like this.
  16. Ain't quitting the day job any time soon. As I have about 30 linear feet plus or minus 1/2 a mile of wire beaded edge to make, time to learn. For the first go tried 22 gauge 3/16ths rod. Since the valence panels aren't structural, thoughts on 22 gauge? Or should it be 20 gauge? Learned my lesson on 18 gauge building seats, not doing that again. Happy February. IMG_0204.jpeg IMG_0206.jpeg
    Outback likes this.
  17. 2A762B70-BC89-4F60-93DA-401516E7C5B5.jpeg B67D6802-D0A6-4C23-B89E-038FB5E5654B.jpeg Work on the cream T continues… building a stainless header at the moment.
    raaf, winduptoy, GuyW and 3 others like this.
  18. Continuing the speedster saga, picked up an engine at auction, complete unknown. What I did know it has no compression. From the outside it looks very well thought out with some interesting details. There was a model A intake and exhaust mounted with no adapter plate. The earliest vw distributor conversion ever, off a 36hp bug. The head is a cast iron Simmons. There is also an Exterior oil line from the starter side of the hogshead to the front of the block. Today I started pulling it down. What other surprises will appear?
    well...
  19. Stovebolt
    Stovebolt
    Yesterday was mid 90's - I went to a hot rod gathering 45 minutes drive from my place.
    Coupe got to 170F, but did not boil - travelled well at 60mph.
    The two banger powered cars there at the event - my coupe and the organiser's ccpu - both B powered.
  20. ZerroHalfcup
    ZerroHalfcup
    We don't always get a good snow down here so when it happened a couple weeks ago, I couldn't resist getting out to fool around a little bit
  21. burl
    burl
    from Minnesota
    Been picking away at this cluster. Got the rear dialed in but plenty of problems left to solve on the front.
    Need to start digging into the banger for this.
  22. Dan from Oakland
    Dan from Oakland
    He wants to go for a ride!!
    winduptoy likes this.
  23. burl
    burl
    from Minnesota
    This is one i made for a single but could be used on a pair. Just simple steel bent to the offset required. Has double spring for race requirements db engine.jpg
  24. burl
    burl
    from Minnesota
    he will if he lives long enough, he's 10 but thinks he's 1
  25. Sounds like you need get moving
    J
  26. Fabber McGee
    Fabber McGee
    Pretty handy, you won't have to paint the car or the dog, they're already color matched.
    Shutter Speed, winduptoy and burl like this.
  27. burl
    burl
    from Minnesota
    brown dog brown car hehe
  28. burl
    burl
    from Minnesota
    story of my life J
  29. Me too
    J
  30. meteorpete
    meteorpete
    Getting ready to take the body off so I can get crackin on the ch***is. But couldn't resist checking out my new 16" Kelsey Hayes rims and Diamondback Aubern radials. IMG_0419.JPG
    Jacksmith, Outback, winduptoy and 3 others like this.
