Technical I have to swap areound the ports or outlets on my radiator 'brass;
Discussion in 'The Hokey Ass Message Board' started by nobby, Feb 1, 2024.
  1. nobby
    nobby
    how do i do it?
    map gas little bottle
    and plumbers soft solder
    what flux am i using
    liquid
    or plumbers paste stuff
    its a walker rad and new,
    if i heat the thing up with a map gas bottle
    what kind of flame am i aiming for
    do i clean off the old solder residue with a wire wheel in a grinder
    also it has a trans cooler in the bottom
    can i use that as a power steering line cooler
    thanks
  2. jimmy six
    jimmy six
    I’ve never checked my ps oil temp but I doubt it’s as high as my normal coolant temp.
    Budget36 and theHIGHLANDER like this.
  3. larry k
    larry k
    If you can’t do it ??? Take it to a radiator repair shop , they will check it when it’s done also !!!
    Budget36 likes this.
  4. theHIGHLANDER
    theHIGHLANDER
    If you clean with a wire brush be conservative. Too hard, too fast, the brush will leave carbon steel deposits and the solder will never take. Me? I'd warm it and wipe it with clean rags. Tinning is GOD when it comes to solder. I always liked "Ruby Fluid" as a liquid flux. Very clean. You want to tin the stuff just like body work, then you'll need less heat to do the job. Once done, a simple duct tape and low pressure with soapy water is all you need. 10psi is enough to leak test. Pics would help...
    Budget36 and jimmy six like this.
  5. daliant
    daliant
    Hardware store solder and flux will work just fine for radiator work, and a mapp gas torch will put out more than enough heat to do the job.
    If you know how to solder copper plumbing pipes together you should no problem moving the ports around on your radiator. Keep in mind that a soldered joint needs surface area to seal right and be strong enough, so it's more of a lap joint than a **** joint.
  6. I believe power steering pressure is higher than automatic transmission, for that part of the question.
    jaracer likes this.
  7. Budget36
    Budget36
    Question. Because I don’t know, but if all was cleaned up, would silver solder work?
    I know it would handle the pressure without issue, wonder about driving vibrations.
  8. Mr48chev
    Take it from an old fart who has ruined more than one br*** radiator because he decided that he would try to solder it up himself rather than take it to a radiator shop and pay a pro to do it right.
    Meaning, carry it to a good radiator shop with explicit directions on what you want done with a diagram drawn out and squeeze that piggy bank a bit and get it done right.
  9. theHIGHLANDER
    theHIGHLANDER
    Silver solder requires too much heat for this purpose. The worst thing you can do is overthink this job if you have the skill set for solder. Same common sense applies as it would for plumbing or body lead. Clean, good fits, manage heat. Still no pics tho?
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I worked at a radiator shop 40 years ago, please do as @Mr48chev says and take it to a radiator shop. when we soldered radiators we used an oxy acetylene torch with a number 0 or 1 tip and a very fine narrow flame. Also there are special tinning materials needed that you will not have access to. If you go after that with a propane torch (way too wide a flame) you will get it too hot and create a leak where the tank attaches to the core, then when you are trying to fix that you will create a leak where the tubes meet the bulkhead.... this is a walker Radiator? how much is a new one? 1200 bucks? do yourself a favor and have it done at a good radiator shop
    jaracer likes this.
  11. nobby
    nobby
    yes walker rad
    for i think sbf
    need one for sbc
    both the top and bottom feeds are now on the wrong sides
    i thought it would be simple as the 'bits' sit inside and carry no load if you like.
    the bottom old position would need a 'patch'
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I removed the picture of the off topic EFI engine
  13. nobby
    nobby
    do the ports if you like press fit almost into the same sized holes
  14. 19Fordy
    19Fordy
    WALKER radiators were very expensive. If you start soldering on it yourself you will open a can of worms that will cost you big time when you finally realize you should have taken it to a radiator shop and got it done and checked for leaks. "Penny wise, pound foolish".
    Moriarity likes this.
  15. Budget36
    Budget36
    I’d have found it easier to lay something over the intake;)
  16. jaracer
    jaracer
    At full lock it is in the 500-700psi range, while trans cooler pressure probably never gets over 100 psi.
  17. jimmy six
    jimmy six
    I’ve done only one and was instructed to flare the hole in the tank and tin it. I then tinned the new fitting, slid them together (a pretty tight fit) then sweated them together. I used my oxy/act torch with a pretty small tip. It never failed that I know of.
