rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  2. Now the pins go through a pin checker. My friend made me this as a Christmas present. The pins believe it or not and I have done it can bend. These are made out of tool steel. They are the bigger nitro diameter and thicker than a stock hemi pin. They are junk if they are out .001 20240201_170433.jpg 20240201_170455.jpg
  3. saltflats
    saltflats
    from Missouri
    Interesting that the small end isn't bushed.
  4. These engines don't use C clips or spiro locks. They use these*****ons. The oil ring holds them in place. It's so much easier to work with. Not only going together but also taking a piston off. With all of the violence going on the other locks would get out of their grooves causing a big disaster. 20240201_183921.jpg 20240201_183950.jpg
  5. Saltflats no need. To machine bushings then press them in and then hone to fit is alot of work. The small end is drilled for oil. We also are not trying to get 100,000 miles out of the rods. For a street engine with steel rods I could see it. I have never seen a aluminum rod that was bushed.
  6. The tapered ring compressors are bore specific and the way to go. Just push the piston down it's so easy. You will never use the adjustable sheet metal one again.
    If you read the instruction then you saw the bolt stretch requirements. A bolt stretch gauge is used. The bolt is measured with no torque on it. The bolt is then torqued to the recommended spec. Another measurement is taken. The 90# recommended was right on. 20240201_191851.jpg 20240201_191148.jpg 20240201_191502.jpg
  7. It's all done. I was doing all of this real time. It will go in the car on Saturday. The hard work is over. 20240201_201712.jpg 20240201_201703.jpg 20240201_201641.jpg
    TFoch, wicarnut, bchctybob and 13 others like this.
  8. Fun to follow the live updates!
  9. saltflats
    saltflats
    from Missouri
    Guess that make's since.
    427 sleeper and mad mikey like this.
  10. It's time to get some things done. The big hemi is going back in the chassis. 20240203_125146.jpg
    TFoch, bchctybob, Oneball and 9 others like this.
  11. mad mikey
    mad mikey
    In February, good deal.
    SS327 and 427 sleeper like this.
  12. The deed is done. It's bolted in. Standing back looking at it I think it looks good. It sure has a different look to it but not so much it looks like a different car. I still need to get the Bruno and lenco in after they are checked out. The dragster style zoomies are going to look great. More to come soon. 20240203_181105.jpg 20240203_181055.jpg 20240203_181047.jpg 20240203_181039.jpg IMG_170700513635F.jpg
    TFoch, The 39 guy, porkshop and 15 others like this.
  13. Mike I hope to have it running by the end of the month. I want to take it south to a track for testing. The nitro chaos event on memorial day is coming up fast. I want to be ready. This car is going to be crazy with big nitro.
  14. mad mikey
    mad mikey
    I look the new look, very serious machine.:) It sure does have a presence.;)
  15. Calkins
    Calkins
    racer-x, 427 sleeper and mad mikey like this.
  16. slayer
    slayer
    The new look totaly reminds me of this car. Sattlemaier, Lou 32 ford.jpg hqdefault.jpg
    Oneball, bchctybob, racer-x and 2 others like this.
  17. mad mikey
    mad mikey
    And many others from the glory days. This is all I got on short notice. LOL File0259.jpg
    Oneball, racer-x and 427 sleeper like this.
  18. No disrespect to the other guys before,,,,,,but , Brian’s machine is head and shoulders above the rest .
    A Mopar coupe with a blown Hemi,,,,on Nitro,,,,with those zoomies and the injector hat !
    No comparison to the others .
    Unless you start mentioning the old AA /Altereds ,,,,,then they are close.
    Sorry,,,,I’m prejudice,,,,,that beautiful green Mopar is tops !
    Tommy
    loudbang and racer-x like this.
  19. Calkins
    Calkins
    The 554 and 15oz both had blown Nitro Hemis, and ran in Top Fuel in the 1960's. Brian's coupe is a modern retro with a properly branded body, in my opinion, of course.
    racer-x and das858 like this.
  20. Thanks guys for the compliments. Some very cool historic cars were mentioned and shown. To be included into the conversations with these cars makes me feel good.
    Today's fun involved making all new fuel lines. Nothing could be saved from the old setup. Lucky for me I had several fittings from past projects I could use. I had to run across the state line to pick up what I didn't have. I need to go back tomorrow for a few 45 degree hose ends. I'm pretty fussy when it comes to fuel lines. They can't be a mess or too long or have funny angles. Sometimes using a 45 degree fitting compared to a 90 degree can make the routing look so much cleaner. I spend alot of time trying different combinations. Now that the barrel valve is on the hat it brings up serious safety concerns. The blower belts when they break whip the belt with a crazy amount of force. It's always on the drivers side. These Kevlar belts can cut fuel lines with ease. They can cut through a funny car body with ease. The oil lines and pump on a 426 hemi are on the drivers side. The oil lines can be cut to. A yet to be installed belt guard will go on. The lines are routed away from from the top pulley for starter clearance and to get them away from the belt. I use a stainless hose going from the tank to the pump because it's stronger in the event of a crash. There's alot going on here most of the time goes un noticed. Safety first 20240204_192310.jpg 20240204_192316.jpg 20240204_192354.jpg 20240204_192403.jpg
    Oneball, TFoch, oldsroller and 11 others like this.
  21. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Brian;
    Asking 'cause I really don't know... Since it appears to me, that the feed & return fuel lines hang out in the thin air, mounted only at each end, & broken belts destroy stuff on the dr-side, why can you not run the lines to the pass side, w/a 90* behind the blower-bracket & then another 90* into the barrel valve fittings. Looks like only a few more inches of fuel lines(which could be supported behind that bracket) & maybe 2 - 90* fittings instead of 1 - 45* fitting ??? If it's a safety thing ??? Are the kevlar belts strong enough to cut the frame also? Or was that not a problem in the past? IDK.
    I do like the new look. :) .
    TIA.
    Marcus...
    slayer likes this.
  22. A proper belt guard and proper routing are all you need. To run the line around the back of the blower would look stupid and add about five feet of fuel line.
  23. wicarnut
    wicarnut
    Lookin Good ! Bud
    racer-x likes this.
  24. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Brian;
    I didn't mean all around the back of the blower, just crossing behind the pulley on the pass side. But I suppose then they'd be in the way of the starter.
    Marcus...
    Algoma56 likes this.
  25. Running it behind the pulley puts the return hoses in a even more hazardous situation. A back fire out of the injector or even worse a burst panel fire could melt the fuel hoses instantly. Then I would be testing out my fire system and fire suit. Bad idea there. But thanks for trying to come up with ideas.
    loudbang and Dick Stevens like this.
  26. vitamindart
    vitamindart
    thanks for taking the time to explain all the ins and outs of what's going on and why. this is one of my favorite threads to read. have been lucky enough to see the car in person and meet you once.
    Algoma56 and racer-x like this.
  27. Oneball
    Oneball
    Why do you have a bypass pipe round the pump?
  28. 19Eddy30
    19Eddy30
    from VA
    Its a way to Not route fuel back to tank from shout off valve, back to inlet side of pump, its a optional routing/ return.
    There are several different ways to plum these mechanical pumps when running a big rubber band on the front, it's up to whoever's laying out the fuel system.
    what they want or if spend the xtra $
    fittings and hoses.
    I always run the lines & protect with Chromoly or****anium.
    When it comes to the Kevlar belt it depends on your set up you get 1-10 runs on a $400 belt
    bchctybob, Desoto291Hemi and Oneball like this.
  29. Yeah,,,,,it’s an easier way to not deadhead the pump .
    Tommy
    bchctybob and Dick Stevens like this.
  30. I****ume your talking about the chrome line going from the shut off valve to the inlet side of the pump. Previous comments are correct. Here's alittle more in depth answer. When the fuel shut off is activated or when lifting from full throttle the fuel pressure spikes. The pump is still rotating. The fuel has to go somewhere. A poppet valve set at 150 pounds will open up sending the fuel back to the tank or to the inlet side of the pump when lifting. A pump loop line works when shutting off the fuel. The fuel loops back to the inlet side of the pump eliminating the spike. Without it the fuel pressure can damage a cast pump. It will cause it to swell and throw it out of spec requiring it to be sent in for service. Without servicing the output will be down. It will throw off the tune up. Worse yet cause a possible severe lean condition causing major engine damage. I use a steel pump while a pound or two heavier it won't swell if something messes up. They stay in spec. Soon everyone will be running nitro with all of their new found nitro knowledge.
    bchctybob, Johnboy34, patsurf and 7 others like this.
