Projects 1953 Ford sed grille ideas...
Discussion in 'Traditional Customs' started by ford40, Feb 3, 2024.
  1. ford40
    ford40
    from pa
    Hi anyone with ideas ?
  2. 58prostreet
    58prostreet
    what's there looks pretty good to me.
  3. lothiandon1940
    lothiandon1940
  4. lothiandon1940
    lothiandon1940
    Any more ideas?
    brady1929 likes this.
  5. 34Phil
    34Phil
    1954 Pontiac or 1955 Olds You just need to find old junkyard and see what they have as desirable ones are scarce and rechrome high if needed..
  6. i.rant
    i.rant
    You have what appears to be a stock grille in great condition with very nice chrome.
    Dare to be different …….leave it as is.:D
  7. A.D.D.
    A.D.D.
    from PacNW
  8. goldmountain
    goldmountain
    All the cool cars I remember had aftermarket tube grilles. Shouldn't be that hard to make.
    vtx1800 and Tow Truck Tom like this.
  9. sko_ford
    sko_ford
    55 Plymouth would be my choice
    1stGrumpy, VANDENPLAS and Torkwrench like this.
  10. Chrisbcritter
    Chrisbcritter
    '57 Buick
    '52-'55 Meteor
  11. 2cdans
    2cdans
    combination- 54 ford park lamp housings 54 chev center with extra teeth.
    1stGrumpy likes this.
  12. Kosmos55
    Kosmos55
    Lose the center bullet and go with the factory '55-'56 Dodge center.
  13. There's an aftermarket piece that covers the center grill after the bullet is removed, It's clean and very 50's
    verde742 and VANDENPLAS like this.
  14. How about some complimentary pinstripe work on the hood. From a single picture I don’t know what your overall vibe is.
  15. Edsel58a
    Edsel58a
    Canadian Meteor has my vote. [​IMG]
    leadsled and VANDENPLAS like this.
  16. deathrowdave
    deathrowdave
    from NKy
    Straight Axle no grill and a Moon tank .
    I had a 53 Coupe in HS , I kinda liked the airplane propeller grill look , if you have a good one I’d keep it. Just my 2 cents
  17. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Yea-up 5 tubes looks best.
    That is my pick
    vtx1800 likes this.
  18. HOTRODPRIMER
    HOTRODPRIMER
    '54 Ford grille with center bullet removed and turn signals tucked inside the grill. HRP
    Dos Cincos and El Camino Kid like this.
  19. HOTRODPRIMER
    HOTRODPRIMER
    '54 grille with the center bullet removed. HRP
  20. HOTRODPRIMER
    HOTRODPRIMER
    I think it's a 53 DeSoto grille. HRP
    Squablow likes this.
  21. HOTRODPRIMER
    HOTRODPRIMER
  22. HOTRODPRIMER
    HOTRODPRIMER
    '54 Chevy grille with extra teeth. HRP
  23. HOTRODPRIMER
    HOTRODPRIMER
  24. HOTRODPRIMER
    HOTRODPRIMER
  25. HOTRODPRIMER
    HOTRODPRIMER
  26. HOTRODPRIMER
    HOTRODPRIMER
    Al Twitchells '52 Ranch Wagon, 1954 Ford grille surround with
    '54 turn signals &grille extensions, the center piece is from a 1954 Pontiac. HRP
  27. Kerrynzl
    Kerrynzl
  28. A.D.D.
    A.D.D.
    from PacNW
    IMG_3019.jpeg IMG_3019.jpeg So, I wanted to share something I learned about 1952-1954 Fords. Maybe this is common knowledge, but I’ll share anyways:
    This is my 1952 Ford.
    The parking lights mount into m***ive round holes with a raised edge on the outside (there is also a vertical seam under the headlight)
    Here is the ‘53:
    Outside of the fender appears to be the same, with a newer style design closest to the grille opening:
    The 1954 has a complete grille “Opening” (like the 1955).
    I also grabbed some already cut off front fender piece from a 1954 (I think) Mercury. It’s pretty obvious how much lower the grille opening is, and where it’s cut off for the bumper:
    I am sharing this, because I have a 1954 Chevy grille with extra teeth. My Ford is a 1952, so I am working around those big parking light holes!
    Have not decided how I will install my grille… but just sharing some knowledge for 1952-1954 owners out there!
  29. A.D.D.
    A.D.D.
    from PacNW
    Sorry for photos at the beginning, accidentally inserted those without realizing. How do I remove them?
