Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. swade41
    swade41
    from Buffalo,NY
    I got my push/pull handle shortened (3 inches) and bracket made, painted and mounted to hold the disconnect switch.
    I decided to have the handle even with the bumper in the on position, might change the T-handle part to red or might not.
    Also gave it a lift since I need to get under it to run the new wiring harness and brake work eventually.
  2. Mr48chev
    In truth getting an EKG done so I can have rotary cuff surgery on Tuesday. Car stuff probably won't happen to any degree until July.
  3. saltflats
    saltflats
    from Missouri
    Good luck on your surgery Mr48.
    enloe, lumpy 63, osage orange and 5 others like this.
  4. BJR
    BJR
    I have had both shoulders done, one at a time. :D 6 weeks in a sling, but both turned out perfect, and I can work overhead with no issues or pain. Hope yours turns out just as good. Brian
  5. Pass The Torch
    Pass The Torch
    Made a custom push bumper so I can get this slug into the shop and tend to the laundry list of stuff I need to get busy on. I don't like hills...
  6. Paint looks perfect to me.
    this isn’t the GNRS:)
  7. Frames
    Frames
    9B789956-D523-4329-BC89-3746ED51EB20.jpeg 138BA1E4-C0E7-4836-B300-DF71461E0B35.jpeg Building a 32 roadster for my grandson. Thread " Maxi-taxi. Chassis is a roller now. Building a tube frame chassis for my show room. 215 Olds engine. Taking it apart for painting and chroming. Starting to build an offset sprint roadster for my show room. Drive line complete. 350 Hilborn injected S B C and3" offset open tube Halibrand. X-Shift transmission. Starting to build an 8 B A short block in my spare time. 2-20-24 8BA short block is done. Starting to build a 59A. Update. Changed I-beam and bones to Ford 38 tube axle and hairpins on the double tube chassis. C201D380-FEAC-4FB7-95D9-F1662D6D0D01.jpeg
  8. guthriesmith
    guthriesmith
    Yea, the paint isn’t the issue. It is the*****py bondo job covering up rusted rear quarters. :rolleyes:
    Anyway, we did get it in the shop and pulled all the parts out of the interior. Seems it came with a few 54 trim pieces like a couple sets of headlight bezels, etc. in addition to parts that were actually off this car.
  9. I’m building a beater with*****py bindo work.
    we ain’t bothered by it
    It will look great dropped in the dirt
  10. 29A-V8
    29A-V8
    from wyoming
    Thats what I did with mine.
    Bill's Auto Works likes this.
  11. High test 63
    High test 63
    Hey lumpy, what pistons/ cam you got in mind to go with the nos guts / heads for your 350?
  12. lumpy 63
    lumpy 63
    I bought a set of DSS forged flat tops with 2 valve reliefs, compression works out to 10.25 I'm still on the fence with the cam , may use a copy of the 7140 off road #1 cam or do a streetable solid roller....The parts came with an NOS LT1 cam but I want something a little bigger.
  13. nochop
    nochop
    from norcal
    Went over to the body shop and mocked up the radiator and hood for tweaking before priming IMG_6741.jpeg IMG_6743.jpeg
  14. gene-koning
    gene-koning
    The outside temps got to nearly 50 on this 4th day in Feb in the north west corner of IL. The roads are clear and dry, the sun was shining. I filled up the truck with gas (it is down to $3.05 per gallon today) and we did a 120 mile Ice Cream run this afternoon! The Ice Cream place in that town 60 miles away (same chain store we have here in town) was the excuse to do the 120 mile cruise.
    It was a great way to spend the day. Sorry, nothing great to see, so no pictures.
  15. lumpy 63
    lumpy 63
    Dropped off the rotating****embly + the heads and new valves at the machine shop today. Now I gotta figure out an intake set up....
  16. LT-1 intake or Performer RPM and a 3310 Holley?
  17. lumpy 63
    lumpy 63
    Trying to be period correct ... even though it would be after 1965... I dont want to pay $700 for a Z28 intake although I could rob the one off my truck. Resisting the urge to install the intake that the name must not be spoken here ;)
  18. saltflats
    saltflats
    from Missouri
  19. lumpy 63
    lumpy 63
  20. swade41
    swade41
    from Buffalo,NY
    R you the 1 kidding me ???
  21. Lumpy, I’m a little out of it this morning, but you lost me with the X. No worries, how about a nice Edelbrock Tarantula?
  22. lumpy 63
    lumpy 63
    Think 8 barrels of goodness Andy:D
  23. Lloyd's paint & glass
    TUNNEL RAM!!!!!!! TRX!!!!! BREAD BOX!!!!! there ya go. :D
  24. lumpy 63
    lumpy 63
    Narc:p
  25. Lloyd's paint & glass
    You're welcome :)
  26. “but I want something a little bigger”
    That’s what she said
  27. guthriesmith
    guthriesmith
    Scattered all the parts from inside the 53 on the floor to sort stuff out. We also swapped to a different set of rollers. Need to bolt the front clip back on and start making it back into a car.
  28. lumpy 63
    lumpy 63
  29. saltflats
    saltflats
    from Missouri
    Trying to get brakes install on the front of an O/T ramp bed truck. Two trips to the capital city and still need to make another trip tomorrow to get all the correct parts. :mad:
