Technical Old Schrader tire inflator
Discussion in 'The Hokey Ass Message Board' started by 65Val, Feb 7, 2024.
  1. 65Val
    65Val
    from BC Canada
    Hey guys…I just received this old Schrader tire inflator from my Father-in-Laws estate. The pressure indicator gauge part isn’t working. There is no part number on the inflator at all. Has anyone ever seen one of these? I’ve Googled it and nothing.
    Thanks!!
    Just.dale and saltflats like this.
  2. Mr48chev
    that may be the oldest one i have seen.
    65Val likes this.
  3. saltflats
    saltflats
    from Missouri
    I have a few Schrader pieces but nothing like that, nice.
    Same as my last name but no relation.
    65Val likes this.
  4. Oneball
    Oneball
    The R trademark symbol came in in ‘46 so it’s after that.
    65Val likes this.
  5. 65Val
    65Val
    from BC Canada
    Any ideas on repairing the gauge part? Won’t read tire pressure.
  6. Oneball
    Oneball
    They’re nothing more complicated than a piston with a spring, so either air isn’t getting to it, it’s not sealing or it’s jammed. Does it pull out?
  7. 65Val
    65Val
    from BC Canada
    I’ve had it all apart to clean it and can’t find any reason for it not to work. The slider gauge part will slide out when I pull it with pliers against the spring.
  8. Oneball
    Oneball
    I’ve just got one in a key ring, it takes no effort to pull out, certainly don’t need pliers. If you take it apart and connect it to an air line does air get to the hole where the slider fits?
  9. texasred
    texasred
    from Houston
    I would bet money Mark owns one
    Desoto291Hemi and Moriarity like this.
  10. 65Val
    65Val
    from BC Canada
    Yes
    All my newer gauges pull out easily. This one has a long spring on the gauge slider that, I ***ume, retracts the slider when the unit is removed from the tire you’re measuring.
    Ebbsspeed likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    Haha, mine isn’t that old, and it is a milton
    34E1FE24-C4A6-48AD-86E7-6898A04BB12F.jpeg 8099F64C-447B-4662-A731-D55518973D1B.jpeg
    Desoto291Hemi likes this.
  12. 65Val
    65Val
    from BC Canada
    Beanscoot likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pics for you, always select "full image" when posting pics
    65Val likes this.
  14. 65Val
    65Val
    from BC Canada
    Thanks….Sorry about that. I could enlarge them on my phone, so I thought everyone could as well.
    Moriarity likes this.
  15. 65Val
    65Val
    from BC Canada
  16. There is a p***age that connects the two sides,,,,,,have you removed the flexible hose and inspected the inside ?
    Might have some trash built up inside ?
    Tommy
  17. 65Val
    65Val
    from BC Canada
    Just did that… pretty clean…applying air to that port delivers air to the supply ( quick disconnect) port… hose is open and clear. Unit inflates tires fine… just the gauge slider isn’t moving.
