History looking for model a Cdan w/ 32 gas tank pics???
Discussion in 'Traditional Hot Rods' started by 2FORCEFULL, Feb 8, 2024.
  1. ALLDONE
    ALLDONE
    So far all I find is coupes,.. and the one I did find the gas tank sticks out way too far... I know about the dagels kit,... but wonder why they have it out soo far... I tryed to call to see why??? but no answer.... maybe buy the kit and mod it??? or is there some reason that it can't be shoved in more???? looks like they sell you the coupe kit and don't have enough call for a sedan??? any way, I own a fab shop... but the shop time would be x3 or 4 to start from scratch,... you get the whole kit for around $1300, that includes the tank and every thing included... their kit has the filler neck out about 6 or 8 " judging from the only pic I found...
  2. ALLDONE
    ALLDONE
  3. HOTRODPRIMER
    HOTRODPRIMER
    Here you go. HRP
    HRP
    duecesteve, Tim, Hotrodmyk and 5 others like this.
  4. ALLDONE
    ALLDONE
    thanks a million.... so my question...why have the tank stick out so far??
    and on the dagels kit , looks like the green car has one they also stick down a coupple inch's
  5. 2935ford
    2935ford
    That's my green '28.
    It is a Daigel's kit.
    It did not fit as well as I had hoped but, I didn't want the tank to take up the back seat or use the stock tank due to me using a '32 dash. It works just fine and is a larger tank than the stock '32 tank.
    I like the fit of the first pic in HRP response much better as well as the entire car. My favorite. :)
  6. ALLDONE
    ALLDONE
    anyone know the dimensions of a 32 gas tank??? my want is to use the 32 frame horns so I can use the spreder bar..... looks to me like the tank could go in another 6/8"
  7. ALLDONE
    ALLDONE
    I'm lov'n your car... soooo much right about it.... did you do the install?? did you try with out the bumper to see how it would look... some more pics of it would be way cool... thanks for responding...
  8. ALLDONE
    ALLDONE
  9. ALLDONE
    ALLDONE
  10. pprather
    pprather
  11. pprather
    pprather
  12. chevyfordman
    chevyfordman
    2FORCEFULL likes this.
  13. ALLDONE
    ALLDONE
  14. 2935ford
    2935ford
    Thank you. Much appreciated. It is a fun car to drive and I enjoy it a lot.
    It's a build me and my best friend Paul put together in my garage.
    I no longer have the rear bumper on it. Only reason I wanted on was for tank protection but without better support for it, it kinda flopped up and down while driving.
    Like I mentioned, I was not overly thrilled with the fit of the tank. There is nothing more I can do to tuck it further in as you are limited to the frame extensions and where they weld to the A frame. The tank does what I wanted it to do and I'm Ok with that. Dagel told me for some reason they fit better on the coupes?
    On another A roadster I had, I used those saddle tanks. Problem with those is filling as there is one on each side. A bit of a pain. I like the '32 tank much better. 28 tudor 004a.jpg
  15. Blake 27
    Blake 27
  16. [QUOTE="2FORCEFULL,
    [​IMG]so, here's an off beat question..... would a 32 hood fit,... or still be too short????
    If I had kept going on this one, it would have been a combination of model A and 32 cut and welded together to make it. So basically, you have to make it.
    [​IMG][/QUOTE]
    duecesteve and 2FORCEFULL like this.
  17. ALLDONE
    ALLDONE
    what I did was order just the frame horns, that way I can fab up the rest with the tank pushed in a far as it will go, I think the dagel frame with the cross beam is making the tank stick out,... the coupe body is farther away from the rear end then the CDAN...
  18. ALLDONE
    ALLDONE
    as you can see,... the dagel tank kit needs to be different for the CDAN... the coupe body sticks out almost to the tip of the fenders...
    2Blue2 and pprather like this.
  19. 2935ford
    2935ford
    That's probably the difference!
  20. ALLDONE
    ALLDONE
    I ordered the tank and frame horns... but didn't get them yet... but I did measure... mine is 16'' from the cross member to the body.... but I also have shocks there... so that shortens it up to 12''..... tank is 17'' so I could mount it with only 5'' sticking out... but I could also move the shocks to the other side if needed...
    I own a ch***is fab shop with a plasma table where all I have to do is say... mount this tank as far in as it will go.....lol... being 70 does have some benefits....
    pprather likes this.
  21. 2935ford
    2935ford
    Cool! Good luck with the install. Pictures when it's done. :)
  22. Jim Mothershead
    Jim Mothershead
    Way back, John at TANKS, made a pair of saddle tanks that went under the 2 splash aprons.
    Yogi's bought TANKS
  23. ALLDONE
    ALLDONE
    I had those on a Model A before.... here's how it goes you go some where and the one side gets low... so you switch over, and first station you see you stop and fill that side up... little father down the road the other side is getting low so fist station you have to stop and fill up and so on and on.... seems like they were only 7 maybe 8 gals.... so any performace motor , lucky to get 10 mpg,... so getting gas every 40 miles or so... big P.I.T.A.
  24. HOTRODPRIMER
    HOTRODPRIMER
  25. krylon32
    krylon32
    from Nebraska
    Clone the installation from the burgundy sedan. It's pushed in tight and uses the 32 frame horn covers and taillights. Perfect.
  26. Tim kerns
    Tim kerns
    from Ohio
  27. ALLDONE
    ALLDONE
  28. ALLDONE
    ALLDONE
    Sitting at the cross roads.....one thing for sure...the fire wall gas tank is going bye bye....Pretty much sure that I escaped death with the big engine fire I had, and got very lucky...Soooo... what to do and how, is where I'm at...I ordered all the parts to do the 32 tank in a model A... got the tank, frame horns , spreader bar and such.... there's a lot of opinions floating around here... which I personally like as it gets options out there before you do something,... and can't turn back...
    I spent a good amount of time staring at the tank hanging off the back of my model A....not sold on the plan at all...and sitting there on a 5 gallon bucket.... all I can think is there has to be something better.. my direction of build on this model A was to build a weekend racer that a guy drove back and forth to work in the fifty's... took a lot of stuff off to give it the Ol Hot Rod look. .one of the first things to go was the bumpers....and the clothes hamper trunk on the back... I personally like the clean look of a C-dan with nothing back there...
    So,... I'm not gonna start Fabing, cutting anything that will make me wish I never did it when I'm done
    Being it's a Cdan.... there's tons of room In the back seat area...I was thinking, and again just a thought...
    why not put the tank under the back seat and french it down a little to where it hangs lower than the floor??? I would have to cut a round hole in the back corner for the filler tube... , kinda like a pick truck..
    or fab up a fuel door in the back somewhere.. I'd like to do it where there's no paint work involved on the body...
    so sitting on the cross rad bucket, here's where I'm at... I'm gonna start with removing the rear seat and rear floor board,... some thing that I was gonna do even if I use the 32 tank...
    So... flame away.... gimmie some Ideas and dirrection here....what would you do????
    Just Gary likes this.
  29. ALLDONE
    ALLDONE
    here's the back of the car...but as of now, the bumpers and frame horns are gone...if you look at the bottom of the body,... theres a about 4'' skirt bolted to the bottom of the body... guess I never paid attention, but I've never seen this piece on any model A.. I used to own a hotrod paint shop,.. painted many model A's ,... all where hot rods that showed up in pieces... never seen this skirt piece ????
    winduptoy likes this.
