Amusing car stuff / funny / stories / pics , print / whatcha got
Discussion in 'Off Topic Hot Rods & Customs' started by choptop40, Jan 16, 2024.
  1. LOST ANGEL
    LOST ANGEL
    Leaf spring lowering kit.
  2. Now thats all wrong, you need some solid skid plates as well.
  3. Six Ball
    Six Ball
    from Nevada
    In the first one everyone knows you have to use hardwood. Pine or fir is too soft for serious suspension work.
    The second one at least will save the ends of the U bolts. once they drag a few times the nuts won't come off and you have to cut them and buy new ones if you don't have a welder to tack a new threaded piece on. I put the U bolts on upside down to protect the threads. You have to retighten them occasionally because the rounded end will tend to straighten out over time.
  4. gene-koning
    gene-koning
    That would be a lift kit, not a lowering kit. To be a lowering kit, the axle would have to be above the spring. Unless the car was on its roof and you are looking at it from the bottom....
    I never would have thought about skid plates, do those void the scrub line rules? Asking for a friend, maybe he will get a different answer then the one in my head.
    Actually, I'm guessing the guy was probably bending the bottom plate trying to keep the U bolts tight, the tubing is to keep the plate from bending, or maybe not...
  5. twenty8
    twenty8
    There was a thread not long ago about scrub line where one guy had the idea of castor wheels (or similar) under the low parts so the car would roll along instead of skidding along in the event of a flat tire.
    Worst part about it............... HE WAS SERIOUS!!!!!:eek::eek::eek:
  6. LOST ANGEL
    LOST ANGEL
  7. pirate
    pirate
    from Alabama
    I looked at a car for sale once with Craftsman universal sockets welded to concrete reinforcement bar shaft. “Um no thanks”
  8. duecesteve
    duecesteve
    This was a sad day for someone.thats why you don't run gl*** fuel filters!
    Driver50x, SS327, X-cpe and 6 others like this.
  9. DDDenny
    And red plastic fuel hose!
  10. LOST ANGEL
    LOST ANGEL
    The " I have no ****in idea what is going on here!" kit.
  11. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    :oops:Well sshhuoorre the lower shock mount bust.
    The bands restore stability.
    See?e? there they really do - dooo:oops:
    Six Ball, duecesteve and Sharpone like this.
  12. gene-koning
    gene-koning
    "That bar thingy used to be hooked up over there. It came loose and was banging around, but I finally got it fixed so it don't bang no more. I fixed it all by myself."
    I saw a lot of these owner repairs come in at my welding shop. A surprising number of those owners didn't want to pay to have them fixed correctly. I should have taken pictures of some of them.
    Six Ball, Tow Truck Tom and Sharpone like this.
  13. Ford52PU
    Ford52PU
    from PA
    not sure if I missed someone else posting this. The most used tool in my garage.
  14. Sharpone
    Sharpone
    IMG_1999.jpeg Looks like a hardware store puked, Amazing, probably more $$$s in junk than the cost to fix correctly. Simply amazing - speechless!!!! I’m thinking people watch the Red Green show as a how to program.
    Dan
    Six Ball and Tow Truck Tom like this.
  15. duecesteve
    duecesteve
  16. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Fifty something years ago, my favorite weldor had a sign on the wall.
    "Minimum charge $8.00. If it ain't worth $8.00, throw it away!!!"
    Driver50x, SS327, X-cpe and 10 others like this.
  17. 41 GMC K-18
    41 GMC K-18
    The Giraffe, is the only animal in the bar that can truly say,
    "Gentlemen, the highball's are on me"
    Driver50x, Toms Dogs, SS327 and 5 others like this.
  18. ClayMart
    ClayMart
  19. Six Ball
    Six Ball
    from Nevada
    They actually sell a crescent wrench now with both standard & metric markings. I guess for those who really need to know.
  20. LOST ANGEL
    LOST ANGEL
    No worries, I welded it myself!
    skooch, clem, SS327 and 12 others like this.
  21. BJR
    BJR
    How can a person weld that badly?:eek:
  22. John Hertz
    John Hertz
    67drake, Ford52PU, SS327 and 8 others like this.
  23. Sharpone
    Sharpone
    IMG_2002.jpeg Practice practice practice
    Dan
  24. duecesteve
    duecesteve
    A 110 volt harbor freight mig , no doubt. I admire how they beat the joints together so it would match perfectly too!
    Sharpone and Tow Truck Tom like this.
  25. sidevalve8ba
    sidevalve8ba
    Ahh, the definition of a booger weld! ^^^
  26. 6sally6
    6sally6
    ONE OF the best post on the board
    6sally6
  27. 6sally6
    6sally6
  28. ClayMart
    ClayMart
    "I cut it off three times and it's still too short!" :confused:
    :eek:
