Hot Rods Identify a Dropped tube axle
Discussion in 'The Hokey Ass Message Board' started by uncle buck, Feb 12, 2024.
  1. uncle buck
    uncle buck
    IMG_6902.jpeg IMG_6903.jpeg IMG_6901.jpeg I have this 4” dropped tube axle and have never seen another one like it. It has set screws for the king pins rather than the traditional tapered wedge bolts. It was removed from a 1934 Ford pickup that was drag raced in the 60’s and early 70’s. Can anyone here identify who the manufacturer was?
    Thanks
  2. I’m thinking Speedway Motors
  3. '29 Gizmo
    '29 Gizmo
    from UK
    Could be home made.
    Not the sort of thing i would run on the street looking at the construction
  4. squirrel
    looks pretty nice to me. Get it magnafluxed, put it back in....
    Kelly Burns likes this.
  5. Nailhead Jason
    Nailhead Jason
    if its been in there a long time, which it looks to have been, it could be an MAS axle. those were pretty common in the 70's and 80's
  6. 270ci
    270ci
    I have an old MAS tube axle that looks almost identical to your's, but has better welds.
    My guess is you have an MAS axle.
  7. 42merc
    42merc
    Challenger, in so-cal on Foothill Blvd.
  8. TerrytheK
    TerrytheK
    I think these guys are right. I had a tube axle from M.A.S. (Minnesota Auto Specialties) under the front end of my first '27 T roadster. It was set up for Econoline spindles but also used allen head lock screws to hold kingpins in place.
  9. uncle buck
    uncle buck
    truck has since been sold....
  10. HOTRODPRIMER
    HOTRODPRIMER
    I agree with the MAS axle. HRP
  11. tubman
    tubman
    I have a dropped tube axle I bought at the Sr Peter, MN swap meet years ago the also has the allen-headed lock screws. Given the location, I always ***umed it was an MAS.
  12. RICH B
    RICH B
    Did MAS make tube axles with perch pin bosses welded in? Don't remember seeing them in any of their stores.
  13. Pete1
    Pete1
    from Wa.
    EXTREMELY poor welding.
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Wonder what the spot of what appears to be br*** was about !
  15. RICH B
    RICH B
    Rust where the spindle contacted the welded on steering stop.
  16. uncle buck
    uncle buck
    These are definitely welded in. Thanks for all your input. MAS makes sense to me.
  17. seb fontana
    seb fontana
    from ct
    PSI.. I had one. Same set screw set up. WAC uses 2 set screws on his axles.
