Technical Ford wishbone caster change
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 12, 2024.
  1. 65standard
    65standard
    A57E5B66-214E-48E1-9141-4DE9A5C503EE.jpeg I have a question about how the yoke end of a Ford wishbone is welded to the tube end. Is it just a **** weld or is the yoke partially in the tube like a drive shaft yoke? I need to change the caster because I’m flipping them upside down to lower the ride height.
  2. Unkl Ian
    Unkl Ian
    Can't answer your question exactly,
    but I have seen people use a Pie Cut to change the Caster.
    How much angle to you need ?
  3. 65standard
    65standard
    Flipping the bone’s upside down should lower the car an inch or so. It looks like that’s what people do when going with a suicide front end. But the caster needs major changes
  4. 65standard
    65standard
    Are the ends just **** welded to the tubes?
  5. 1946caddy
    1946caddy
    from washington
    Can't you just stick your finger in the hole and feel how far it goes into the tube ?:confused:
  6. 65standard
    65standard
    Yeah, I guess I can cut the spring perch bushing out and see what’s going on with it.
  7. BJR
    BJR
    If you flip the ends you will have the thinner / weaker end supporting the axle.
    V8-m, Kelly Burns and clem like this.
  8. flamedabone
    flamedabone
    The forged ends stick about an inch or so into the wishbone. You should be able to explore the hole and see the end. As long as you are past that, you can pie cut with no issue.
    -Abone.
  9. 65standard
    65standard
    F8F9D25E-6A68-4A29-B2C3-4272BA7E344F.jpeg 2BCEF180-DA49-45D3-B2A6-920A32A914D8.jpeg Thanks. Yes the yoke extends into the tube.
    By flipping the yoke and adding 2 degrees more caster, it lowered the car another 1-3/4”.
    Happydaze likes this.
  10. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    the forged pc has a bung that fits inside of the tube. 20200915_212405 (1).jpg
  11. alchemy
    alchemy
    Just FYI for other readers, the earlier wishbones (32-34 for sure) do not extend into the tube.
  12. 65standard
    65standard
    For the record, these wishbones are 1941. They are longer, have larger tubes, and thicker yoke ends than ‘32 bones.
    Unkl Ian likes this.
  13. I don't think I would stray from having more material under the axle!
  14. 4bangerbob
    4bangerbob
    from AB, Canada
    IMO you are raising the front of your car by doing this. The distance from the top of the axle where the spring perch/radius rod flange mates with the axle to the center of the spring eye is going to be increased, thus raising the front end of the car.
    The amount it is raised is the difference in the thickness between upper and lower flange on the radius rod.
  15. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    hi,my wishbone is not 32/34 and I extended the length to bring the ball mount farther back to meet the trans cross member,If pictures would help let me know.
  16. 65standard
    65standard
    raising the axle up is actually lowering the car.
    It’s like drop spindles. They raise the spindle on the steering knuckle to lower the car.
    or like drop axles. They bend the ends up to lower the car.
  17. 65standard
    65standard
    it doesn’t matter if the thicker part is above or below the axle. The eyelets are thru bolted with the axle, thus both eyelets are holding the weight of the car.
  18. 4bangerbob
    4bangerbob
    from AB, Canada
    If you are using conventional spring perches mounted through the axle then IMO you are wrong. If you are mounting the spring perches through the radius rods then you are right.
  19. 65standard
    65standard
    If my setup was still conventional with the spring over the axle, this mod wouldn’t change the ride height at all. It would only lower the wishbone down closer to the ground. So am I still right?
  20. alanp561
    alanp561
    Look up this thread and prepare to get educated.
    Illustrious Hector likes this.
  21. 65standard
    65standard
    Good information. Thanks, I added the link
  22. 65standard
    65standard
  23. 4bangerbob
    4bangerbob
    from AB, Canada
    With spring over the axle if the thicker flange at the axle end of the radius rod is 1 1/8" thick and the other flange is 5/8" thick then reversing them as you are doing would raise the front end of the car by 1/2" while at the same time moving the radius rod at the axle end further away from the ground.
  24. 65standard
    65standard
    If I was using that stock setup and if the yoke ends has zero caster built into them, then The half inch difference in the eyelets would move the axle 1/4” up. Which would move the ends of the axle up 1/4”. Thus a mini drop axle that still lowers the car 1/4”
  25. 65standard
    65standard
    0918B2AF-1208-4373-9CD3-039A3E2F8DBC.jpeg Wish bones are ready for welding
