Hot Rods Let's finish the 50 Chevy pickup
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Dec 29, 2023.
  1. lumpy 63
    lumpy 63
    Hey Lloyd we are doing a couple of AD trucks at the shop, I can ask the owners if they have any use for the original gauges...
  2. fastcar1953
    fastcar1953
    Sol on gauges. They got rid of them a long time ago. Sorry
    Lloyd's paint & glass likes this.
  3. saltflats
    saltflats
    from Missouri
    You can buy the parts to restore the factory gauges.
  4. chevy57dude
    chevy57dude
    Working factory gauges are cool. Fill in what Chevy didn't supply with aftermarket stuff. Got a couple of 2'' gauges here for ya, if you need. Let me know.
  5. mad mikey
    mad mikey
    I have some older aftermarket gauges laying around as well. Let me know if you need them.
  6. fastcar1953
    fastcar1953
    Oh hell your a body man . Cut it up and install a different dash or at least gauge cluster from something else.
    I installed a 54 chevy car dash in a 89 s10. Get busy thinking. Good luck. :D
    I always liked the 55 chevy car dash. I bought one at a swap meet . Waiting for the right vehicle to put it in.
  7. That was the plan originally, but it wasn't my truck then, that's when it had 20" wheels on it lol... I had a full set of autometer gauges, but I sold em. I'll check into what James said about new faces.
  8. Just let me know. Street rod guys put them fancy digital gauges in em, I'm sure there's a set laying in somebody's garage going to waste!
  9. Got the running boards mounted today. Didn't get back under it to take pictures, because I'm fat and my knees hurt. I put a 48" section of 2" angle on the outer edge of both sides to stiffen them up. I need to add another support back by the rear fender, I'll get back on that in a few days. 20240212_171457.jpg 20240212_171440.jpg
  10. Hey Brother! Looks Sharp! We just won’t let Little? Truckdoctor step on them in Bowling Green!
    The question mark is because I’m 6’2” 350 lbs and Little Truckdoctor is 6’3” and 280 lbs, and he’s only 14!!!!.
  11. It's so low that you don't need to step on them! But it's good at the door, I didn't put a bracket at the rear, but if the push down on it at the rear it flexes the fender, so I'll make 2 more and stick them on. Still much better than paying $600 for brackets lol
  12. swade41
    swade41
    from Buffalo,NY
    This place is phenomenal for quality wire and accessories, super fast shipping and a flat rate $3.97 shipping no matter what you buy.
    https://www.batterycablesusa.com/
    I just put all new cables in the J with the soldered ends they sell and just got an order in for the 41 for some 6 guage and ***orted ends.
  13. Hey Brother, what does Trukus have for windshield wipers?
  14. Alan is sending me the cable, I moved on to some of the other things that need done until it gets here. Brakes is at the top of the list now lol... I need a friend to help me bleed them! I tried the gravity method, but nothing is moving.
  15. Nothing, the arms are on it but there's no blades. They're just for looks anyway. I use rain-x religiously lol
  16. fastcar1953
    fastcar1953
    Their reasonable on price and shipping is cheap enough. Their in louisville ky.
  17. gene-koning
    gene-koning
    Anything behind the wiper arms, or just the arms still attached to the cowl?
  18. The drive is there. I haven't had a hotrod with wipers in my life!
  19. BamaMav
    BamaMav
    from Berry, AL
    That hole looks like it’s in the perfect place to run some stacks!
    As to brake bleeding, go to Harbor Freight and get one of those Mitymite vacuum pump knockoffs. It comes with hose and adapters to fit your bleed valves. East to use, loosen the bleeder, stick the adapter on it, pump the pump handle until you see fluid with no bubbles in the clear hose, close the bleeder and go to the next one. I usually try to gravity bleed mine first, rr first, the lr, then rf, ending at lf, then same pattern with the vacuum pump.
  20. I was really reaching out to find more/ better friends lmao! I had one of the vacuum pumps but it **** out finally. If nobody stops by soon, I'm gonna have to go get a new one.
  21. Dick Stevens
    Dick Stevens
    If we were closer to you, there would be a lot of guys ready to help whenever it would work out!
  22. little red 50
    little red 50
    I've had both and the one from harbor freight is actually much better.
  23. rusty1
    rusty1
    try speed bleeders, one man job.
  24. Big news!! I have brakes!! And the better news is the transmission works!!! :cool: I mounted the power steering pump, wired up the gas gauge, stuck a cheap oil pressure gauge inside, couldn't be more happy right now with the truck. Now I can move it around under its own power while I finish stuff. What a relief!! Couple of pictures for you ****ers too make fun of :p 20240213_191332.jpg 20240213_191337.jpg 20240213_191344.jpg 20240213_191405.jpg 20240213_191521.jpg 20240213_191629.jpg
  25. lumpy 63
    lumpy 63
    Just spoke to Vito , his buddy owns one of the trucks at the shop . He said it shouldn't be a problem getting the gauges , we get the cab this weekend hopefully you will have em soon.
  26. I think I've got the multi gauge, I need a speedometer. Rusty sent me a pm today about the other one. Let me know what you come up with big guy!
  27. swade41
    swade41
    from Buffalo,NY
    I see you were checking for leaks the traditional way with the Firestarter
    All kidding aside congrats on getting it up and moving on it's own, always a great milestone
  28. gene-koning
    gene-koning
  29. You're CRUSHING it Lloyd!
  30. That's my shrink tubing facilitator lol... about time for a new one, it's running low on petrol
