Technical 51 Mercury Lowering
Discussion in 'Traditional Customs' started by jumbogem29, Feb 8, 2024.
  1. jumbogem29
    jumbogem29
    from Alabama
    Hello looking for info would like to see some 51 Mercury with a 4 inch drop any problems with going that low i front or back running the flat head mercury mtr. Was looking at the fatman 2.5 up right and a eaton 1.5 drop coil spring is that to low ?????? Thanks any input welcome .
  2. poco
    poco
    from oklahoma
    That is to low if you live in Okla
    Surfcityrocker likes this.
  3. Aerostar springs. Cost around $75
    Homemade 2 inch blocks.
    plus a couple students weighing it down
    $100 drop so far
  4. da34guy
    da34guy
    2 fat chicks in da back seat will get ya started
  5. Surfcityrocker
    Surfcityrocker
    from Austria
    Too low to be practical. I have a 3 inch drop on my 50 Mercury and even that gives me troubles sometimes.
    guthriesmith likes this.
  6. leadsled
    leadsled
    Aerostar springs and 3" blocks in the bag. Start there. If you go any lower in the back you may want to put a set of casters on it for the steep driveways.
    Surfcityrocker and guthriesmith like this.
  7. Sum54ford
    Sum54ford
    from St. Louis
    IMG_1232.jpeg My 51 Mercury has 4” lowering leaf springs from Jamco in the rear with 4” lowering blocks. Up front I have Aerostar springs. I run 7.10 - 15 tires in the front and 6.70 - 15 tires in the rear. Flathead V8. I drive this car everywhere and it drives fantastic.
  8. Dangerousdan
    Dangerousdan
    from Arizona
    The stance on your Merc is the perfect look. Thanks for the information.
    williebill and Sum54ford like this.
  9. Sum54ford
    Sum54ford
    from St. Louis
    Thank you, I wanted the cl***ic 50’s style static drop.
    williebill and 51 mercules like this.
  10. Doctor Detroit
    Doctor Detroit
    I agree with the comments above. Perfect stance for a '51 Merc static drop. Thanks for sharing the details.
  11. 50 Merc Man
    50 Merc Man
    I have the same setup on my ‘50 , outfitted with jamco suspension front and rear. Lowered springs in the back with 2” blocks. Front is the 3” lowered springs with 1” dropped spindles. Only problem I really have is gettin in and out of my driveway!! IMG_6081.jpeg
  12. Aerostar or cut 2 coils will drop the front 4 in. 4 in blocks in back and remove a couple of rear spring leafs.
    Sprout likes this.
  13. MercMan64
    MercMan64
    from Taylor mi
    I did 4” blocks on the back of my 49, huge difference. I haven’t had a chance to do the front yet to level it out. But so far I haven’t had any issues with getting into my sorta steep driveway IMG_3162.jpeg IMG_4178.jpeg IMG_4366.jpeg
