Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
    Oh come on Mark, you can just drill a pvc hole in the back of the man a fre:p
  2. choptop40
    choptop40
    Traditional meets practicality....They look awesome though...Been seeing Man A Free direct ports for Big Blocks lately....
    lumpy 63, Moriarity and guthriesmith like this.
  3. guthriesmith
    guthriesmith
    That line of thinking makes perfect sense to me. I have seen too many cool valve covers like early Cal Customs or early Vette that someone butchered a hole in for ventilation or the same to an intake. Even with those being a little newer, the whole look works together.
  4. 283john
    283john
    I'm travelling 4 hours Thursday to pick up a 3.08 rearend for my c-10 to swap out my 4.11 current one. Bolt-in and cheap. Maybe with longer legs and a torquey 355 I can float that puppy down to the next Lloyd's Fest.
  5. lumpy 63
    lumpy 63
    I keep my eye open for butchered Vette covers, that way I dont feel bad about further mods. 33058.jpeg
    enloe, rod1, Truckdoctor Andy and 8 others like this.
  6. I have a C10 rear end with 3.08 gears you can have! But it's a 6 lug
    enloe, Truckdoctor Andy and scotty t like this.
  7. bchctybob
    bchctybob
    I just drilled a hole in the back of the block and added a baffle and a fitting. Hard to do with the engine finished and in the car though. Like Guthriesmith said, it looks great, I was just bust in’ yer balls….
    I like the breathers on Lumpy’s valve covers.
  8. swade41
    swade41
    from Buffalo,NY
    I didn't feel bad about adding breathers to these and still like my placement of the breathers, not abstrusive and you still get the effect of the "corvette" valve cover.
    Screenshot_20240213_115527_Gallery.jpg Screenshot_20240213_115503_Gallery.jpg Screenshot_20240213_115433_Gallery.jpg
    enloe, 54reno, rod1 and 11 others like this.
  9. squirrel
    I wonder how they'll do with oil mist? Hopefully well enough baffled
  10. swade41
    swade41
    from Buffalo,NY
    You'd still have the oil fill tube breather, I ran them on the t-bucket's old motor without issues.
    I did put the old school wrist sweatbands on the new engine with the CalCustom valve covers
  11. bchctybob
    bchctybob
    Brading, thanks for the links. Some good info there.
  12. guthriesmith
    guthriesmith
    Ok, so you guys did bring up a good point about looking for butchered valve covers to get cheap. I retract my earlier statement and am reminded of some early Cal Custom ones I had that someone put drain pipe in to add fill and breather points. They worked well and still looked good.
  13. 283john
    283john
    I want a 6 lug. I have the 6 lug pattern chrome vette rally wheels. What year is it? I need the 67-70.5 model for the spacing to be exactly right and trailing arms with coils, not leaf sprung.
  14. swade41
    swade41
    from Buffalo,NY
    I have an early set of no breather/oil fill hole M/T's that some nimrod drilled a big hole in the flat on one of them, terrible tragedy.
    The ones under the window
    I've bought some rough valve covers in the past to either get the breathers from or knew I had breathers to cover someone's hack job of adding breathers.
    Those M/T's, I thought I had a piece of another M/T that I could weld in the hole but I couldn't find it.
  15. alanp561
    alanp561
    Wonder if anyone makes an adapter so I can run a set of Ford valve covers on my 283. Paint it all blue and nobody would know the difference, maybe;). I FOUND THEM
  16. Hey Alan, tell people your 283 is a Y Block 292, most people would believe it because of the rear mounted distributor on a Y!
  17. lumpy 63
    lumpy 63
    3 2 1....let the ford fanatics flaming begin:p
  18. Tickety Boo
    Tickety Boo
    from Wisconsin
    Gunna be a Sleeper :p
  19. Mike Miller
    Mike Miller
    Finished up the headers and started installing the fenders.
    enloe, coupe man, scotty t and 12 others like this.
  20. RmK57
    RmK57
    Found them where, in a dumpster?
    enloe, alanp561 and guthriesmith like this.
  21. Well ****, this is out of a square body man.
    enloe, Truckdoctor Andy and 283john like this.
  22. Just embrace the little Chevy engine Alan :);) I know it's killing you inside :p
  23. swade41
    swade41
    from Buffalo,NY
    You could always make the little 283 look like a flathead, probably the best running flathead ever
    enloe, 57JoeFoMoPar, alanp561 and 6 others like this.
  24. RmK57
    RmK57
    Look great in a 50’s chebby pickup.:cool:
    alanp561 and swade41 like this.
  25. wheeldog57
    wheeldog57
    Started taking apart the roadster, it's getting a rebuilt 255. Got to be ready for a Memorial Day race, wish me luck
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Needs reclocking to 6 to be considered custom.
    427 sleeper and lumpy 63 like this.
  27. DDDenny
    Now cl***, it's spelled, and I'll say it slowly, Che-vro-let, say it with me Che-vro-let.
    Good.
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No no. Shev/row/lay
  29. lumpy 63
    lumpy 63
    Went out in the Garage this afternoon and worked on the Dirty Virgin a little... Had a big *** needle shoved in my neck yesterday and the doc said to stay outa the garage for a bit. I figured chasing a few threads wasn't gunna hurt anything.
  30. bchctybob
    bchctybob
    ^^^^ Hard to hit the like ****on on that one Lumpy, ouch.
