Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. benchseat4speed and porkshop like this.
  2. NealinCA
    NealinCA
    I mocked up a 37 Ford Woody bumper that I picked up at Turlock swapmeet.
    I have a strip of black tape across the bottom, as I think the bumper needs to be trimmed off to give it a slimmer look, similar to where I was headed with the 40 bumpers.
  3. NealinCA
    NealinCA
    I hit some milestones with the new steering box project.
    I assembled the 100th new steering box:
    And finally got somewhere with the new sector shaft forgings
    In that we finally have a fully machined and dimensionally correct sector shaft
    Now to machine a small batch and send them off to heat treat. This is what helps to keep the 5w project progressing.
  4. dwollam
    dwollam
    Dang! Color me impressed! Wish I had just a small amount of your talent.
    Dave
    porkshop, SS327 and -Brent- like this.
  5. banjorear
    banjorear
    Right? Damn impressive all around.
  6. The37Kid
    The37Kid
    VERY Impressive! Proof that we can still build stuff in the USA. Bob
  7. alchemy
    alchemy
    The bumper fits perfectly. It might even be fine untrimmed.
    Outback likes this.
  8. I agree. Though the trim is going to be just one of a million little details that will set this car apart.
    Outback likes this.
  9. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Not me, the bumper needs shortened. Good design, just to long.
    SDS and Bandit Billy like this.
  10. NealinCA
    NealinCA
    I'm with you on this. I'll keep fussing with it until it's "right"
  11. A Boner
    A Boner
    Normally my response would be to hang it on your shop wall…but in LA traffic, a bumper might be a good idea!
    porkshop and -Brent- like this.
  12. NealinCA
    NealinCA
    I wanted a chrome 40 Ford horn button, so here is what I came up with. A 2-1/2" freeze plug, with some grooves cut on .060" centers to mimic an original plastic horn button. I will send it off for plating, then epoxy it to the cut down plastic horn button.
    20240211_112218.jpg 20240211_115828.jpg 20240211_115934.jpg 20240211_122306.jpg 20240211_122336.jpg
  13. dirt car
    dirt car
    from nebraska
    I've taken a liking to the ribbed horn button & steering wheel & I'm sure your quite aware the dash knobs, window cranks & door handles are out there with the similar design if you so choose, toss in the 32 bumpers & you've come full circle.
  14. -Brent-
    -Brent-
    That's AWESOME, Neal.
  15. alchemy
    alchemy
    I’m sure you’ve thought all the other interior accoutrements through as well. Do you have a set of those flippy-knobbed Chrysler handles? That would be my pick.
    porkshop likes this.
  16. NealinCA
    NealinCA
    I'm doing an eclectic mix of 49-57 Ford/Mercury parts. 49 Mercury door handles and window cranks. 49-51 Ford pedal pads, gas pedal and inside rear view mirror. 55-57 Thunderbird ignition switch, headlight switch and cigar lighter.
    BigJoeArt, Tim, Speedy Canuck and 5 others like this.
  17. I love the horn button.
    Have you considered producing more than one?
    -Brent- likes this.
  18. NoSurf
    NoSurf
    Dude, you're sick. But in a good way.
  19. Bugguts
    Bugguts
    Your creativity is amazing!
    Who looks at a freeze plug and see’s a beautiful horn button!
    Way to think outside the box.
    rod1, -Brent- and pprather like this.
  20. SDS
    SDS
    I agree, it does look great...but if you have access to a lathe, why start with a freeze plug versus a hunk of aluminum rod stock or plastic?
  21. NealinCA
    NealinCA
    Because it was already the right size and shape, cost $2, and I spent 10 minutes machining the rings. Plus, it's steel, so it will chrome plate easily, which was the whole goal of this project...a chrome 40 Ford horn button.
    I'll try harder next time.
  22. DDDenny
    I think it's perfect!
    porkshop, dwollam and NoSurf like this.
  23. hahha I was going to say... why reinvent the wheel if the freeze plug gets you 90% of the way there.
    Outback and porkshop like this.
  24. Ha! I’ll take one.
    pprather likes this.
  25. alchemy
    alchemy
    Some guys look at a hunk of material and see an afternoon’s work. Some guys look at a freeze plug and see a horn button.
  26. I can't wait to watch this interior come together. Already looking incredible.
    Outback likes this.
  27. Tim
    Tim
    from KCMO
    Love that “horn” button
    Outback likes this.
  28. NealinCA
    NealinCA
    I am also working on getting the engine buttoned up, but I had valve interference issues with the Potvin 3/8 cam and Edelbrock heads. I worked up a fixture to bolt the heads to on the mill. Hope to get them cut this weekend
  29. SDS
    SDS
    Jeez, tough crowd...
    A lot of platers won't put anything into their tanks that has/had galvanize or zinc on it (like freeze plugs). Those contaminate the tanks which yields bad plating results.
    I turn my knobs and such from aluminum or stainless, then polish them with 3M mirror paste. Chrome plating has gotten cost prohibitive around here (northeast) and it's poor quality...your $2 freeze plug could end up being a $50 chrome horn button in the end.
  30. -Brent-
    -Brent-
    Drop that horn button in some muriatic acid for a minute or two and the zinc will be gone.
