Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. DDDenny
    "I told ya so"!
    That's what you would be hearing my wife say when she hears me crying in pain after I told her I would only be in the shop for a little while.
    scotty t and lumpy 63 like this.
  2. Sandcrab
    Sandcrab
    Resized_20240212_150429_1707792547062.jpeg Resized_20240213_171021_1707878070663.jpeg Made patterns and cast s couple spacers to adapt the original 215 Buick stick bellhousing to a T5 transmission.
    Tim_with_a_T, scotty t, rod1 and 12 others like this.
  3. mixerman
    mixerman
  4. lumpy 63
    lumpy 63
    It's all good Bob, getting old aint for *****s:D
  5. The31CoupeKid
    The31CoupeKid
    I finally got my 30 Model A coupe ready for the body shop…. Will be doing a thread on this build soon
  6. Dick Stevens
    Dick Stevens
    It would be appreciated if you would select full size images instead of thumbnails when you post pictures. TIA
    guthriesmith likes this.
  7. saltflats
    saltflats
    from Missouri
    Yesterday was make a big mess getting the O/T ramp bed trucks back end off the ground so I can tackle the rear brakes and inspect rear end. The seals in the rams on my lift are completely gone, took a gallon of fluid to get it picked up enough to get it on jack stands and all of that run out on my new concrete. :mad:
    So today I'll tear into this. Did I say I hate working on these 1 ton rear drum brakes. :mad:
    enloe and lumpy 63 like this.
  8. bchctybob
    bchctybob
    Pretty cool Sandcrab, but my T5 bolted right up to my 215 bellhousing. Is the adapter just to space the input shaft back to fit right? If so, make a couple and I'll buy one from you.
    I haven't bolted my bellhousing up to the engine yet, it's still in the car with the TH350 on it.
  9. squirrel
    haven't started working on it, but it's home. Uneventful drive from Tucson.
  10. Dick Stevens
    Dick Stevens
  11. 51504bat
    51504bat
  12. Sandcrab
    Sandcrab
    Check the input shaft stickout. Mine is 7 1/8" and the 215 crank is not deep enough to accept the pilot shaft.
    Let's see how the machining and fitup goes. I cast two so I could experiment.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
  14. Oneball
    Oneball
  15. Rockabillyhotrodder
    Rockabillyhotrodder
    from New York
    Doing a total rebuild of the 51 Chevy in my avatar. That photo is from the early 80s, built in the late 70s. Originally built with a 65, 396 I’m redoing it with a 59, 348 in an attempt to mimic an early build. Lots and lots of fabrication going on as often as I can
    bchctybob, swade41, mad mikey and 4 others like this.
  16. J. A. Miller
    J. A. Miller
    from Central NY
    427 sleeper and alanp561 like this.
  17. squirrel
    My brother likes the Batman emblem, he wore a sweatshirt with it (that our mom made ) for decades
    Driving it is OK, but doesn't thrill me...I'll likely let it go pretty soon.
    I have put a couple 283s in it over the years, then the crate 350 about ten years ago. David added the AC and disc brakes. And the alternator, when the generator died on a road trip!
  18. guthriesmith
    guthriesmith
    Looks like a pretty solid wagon Jim! Will be paying attention if you decide to sell it since I know someone that might be interested.
  19. snoc653
    snoc653
    from Iowa
    I'm about to start tearing into the 51 in my avatar as well. I'd love to know what all they did to make the Big Block fit as mine is going to have a one in it. All said and done, I'll have 505 cu in squeezed under my hood. In a pump gas friendly build. Why the choice of 348? Wouldn't a 409 also fit and be just about as period correct or are you going for mid 50s time frame?
  20. 427 sleeper
    427 sleeper
  21. lumpy 63
    lumpy 63
    Damn Jim , if you sell too many more cars you will have to put up a Forbes used cars sign:p
  22. DDDenny
  23. Rockabillyhotrodder
    Rockabillyhotrodder
    from New York
    Yes I’m going for a late 50s build theme and the 409 didn’t come out until 61 plus I had access to the 348 at the time I started looking. The 348 is actually wider than the BB Chevy creating even more fitment issues. The BB was much easier to fit into the very tight engine compartment. I used a front saddle engine mount but I would use the side mounts if I were to do it again. barrel shaped exhaust manifolds that dumped out the back. Had the cut the firewall mounts to clear all worked out pretty good.
    snoc653, bchctybob and chevy57dude like this.
  24. Bandit Billy
    Bandit Billy
    Getting ready to mount my hood on the PU tomorrow evening. Easier to add the trim and latches like this.
    Poverty cap, scotty t, TA DAD and 9 others like this.
  25. mad mikey
    mad mikey
    Looks like something HAMB member Bruce Fischer would be interested in.
  26. chevy57dude
    chevy57dude
    @squirrel - Dream find right there! '58 anything in that condition doesn't seem to exist here in the northeast. I always thought the '58 Chevy was ''going one more'' than the '57 with the quad headlights, 4th fender louver, W engine. Glad for you.
  27. saltflats
    saltflats
    from Missouri
    I would guess the 58 wagon didn't handle very well, I don't know as I haven't driven one. The car that I worked on didn't handle very good in my box.
    I sure do love the look of a 58 Impala hard top.
  28. squirrel
    The wagon handles like a full size car from the late 50s...not very well! and it has manual steering, so it's a little hard to drive. It does have power discs, so it stops ok, and the 350 gets up and goes ok, too. 3.36 gears with a TH350 means you can hear the engine singing on the highway at 70 mph. It doesn't mind, though. I do have to fix the driveshaft center support, David said the frame is cracked around the mounting holes. It has a little driveshaft rumble.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    yeah, but will your wife ride in it?
  30. squirrel
    She didn't today. But she used to 35 years ago!
