SOLD!! Up for sale is a very nice S10 T5 transmission with a 3.97 ratio first gear. This transmission number is 1352-222, out of an 1993 S10, and is perfect for an early Ford Hot Rod. This is the World Cl*** version, with roller bearings on the main shaft and the higher quality fiber synchro rings. This was said to have been pulled from a running truck and shifting fine. I verified it bench shifts smoothly and feels good in all gears. Endplay feels good. Not pictured but included is an S10 shifter. As most of you know, the S10 trans is perfect for a hot rod since it has the shifter close to the bellhousing and works well with a bench seat. This S10 ****** has following ratios that I verified by putting it in gear and turning it on the bench. 1st: 3.97 2nd: 2.34 3rd: 1.48 4th: 1.00 5th: .72 The gear ratios on this transmission make it perfect for a hot rod, and the T5s are very light and compact so they fit in most applications. It bolts right up to a small block chevy with the standard chevy bellhousing. May need a little trim of the input shaft depending on the application. Perfect for a Flathead Ford. These T5s are becoming harder to find. I will ship on buyer's dime, which will run about $175. Feel free to contact me with any questions you may have
