Projects ONE PIECE AT A TIME ('47 FORD COUPE)
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 1, 2017.
  1. topher5150
    topher5150
    Making a check list. Feel free to comment
    ✅ Main harness
    _painless duraspark II harness 30812
    ✅painless Ford 3G alternator wiring harness 30831
    _and headlight, dimmer and ignition switch
    Thor1, bobss396 and Kelly Burns like this.
  2. bobss396
    bobss396
    O joy... a harness. Looks daunting all furled up like that. I made a harness "board" for mine. Identify the main (horizontal) bundle and the fuse box locations, this is essential and set in stone.
    My board is plywood, about 18" x 48" and I used finishing nails, a marker and rubber bands to route everything. I started with the steering wheel as the "datum" and worked it all left and right.
    I broke out what goes forward of the dash, what goes in the dash and what goes to the rear of the car. Ace Hardware has some real ugly colored zip ties, but the package deal is good and nobody will see that under the dash and so forth.
    brEad and Kelly Burns like this.
  3. alanp561 likes this.
  4. topher5150
    topher5150
    Getting everything sorted and making labels
    Trying to figure this one out
    Pink HEI ballast
    Purple F7 natural safety
    Dark PurpleA6 accessory power
    Red wire
    brEad likes this.
  5. topher5150
    topher5150
    Did a little putzing around the junkyard this weekend. The dial holes are almost the exact size of the gauges. Just got to fill in some of the other holes and paint her.
    Crusty Chevy and bobss396 like this.
  6. topher5150
    topher5150
    Got some idiot lights on eBay, trimmed the front down a few inches. Now I just need to fill the shifter hole.
    IMG_20240210_153151706.jpg IMG_20240213_170433184.jpg IMG_20240213_170454874_HDR.jpg
    brEad, Thor1, bobss396 and 1 other person like this.
  7. bobss396
    bobss396
    Kelly Burns, Thor1 and Crusty Chevy like this.
  8. topher5150
    topher5150
    I mean it ain't running so I can't get into trouble.
    brEad and bobss396 like this.
  9. topher5150
    topher5150
    I have 8" Ford steel wheels. Can I get a 6" or 7" on a wheel like that?
  10. topher5150
    topher5150
    Thinking of the best way to do this without getting myself into too much trouble.
    I'm thinking either t******* the flanges on the cross member and t******* the gas tank in the front
    -or-
    cut everything out and raise the floor a few inches
    Crusty Chevy likes this.
  11. bobss396
    bobss396
    Raise the floor and tank? That might be the way to go, less cutting and fitting.
  12. topher5150
    topher5150
    I'm not committed either way, the floor in the trunk needs to be replaced either way, maybe going the EMS way would be an easier option .......:rolleyes::oops:o_O
    bobss396 likes this.
  13. Crusty Chevy
    Crusty Chevy
    I like EMS stuff. Its thick metal and has a coating on it that keeps it from rusting. It fits 95% and you need to cut and weld it to the other 5%, which is better than many aftermarket panels.
  14. topher5150
    topher5150
    Hard to feel any motivation when you can't feel your toes IMG_20240323_073419713.jpg
    alanp561, brEad, Kelly Burns and 2 others like this.
  15. topher5150
    topher5150
    Doing some templates to see what I can do myself. Should I put a half-inch flange on the sides, or would I be ok to **** weld everything to the wheel wells?
  16. Crusty Chevy
    Crusty Chevy
    I did a down turned flange on mine, punched the flange for holes and welded it in from underneath. This required removing all the old floor where it attached to the wheel wells to get a smooth area to weld to. My floor was totally shot edge to edge, front to back. If you have a decent perimeter left of the old floor just keep that, make the floor fit edge to edge, drill/punch hole in it and plug weld to what is left of the old and seam seal top and bottom.
    brEad, RICH B and topher5150 like this.
  17. topher5150
    topher5150
    Finally got the lead out of my ***. Sometimes it gets overwhelming with all the small things you need to do to get this car running you just stop doing them.
    I got her out of hibernation got the fuel filter in place, got some fuel line and adapters and feeling kind of more geek about working on my car than I have in a while
  18. topher5150
    topher5150
    The wife thought she'd be funny and ambush me while it was working
    Tim, brEad, Crusty Chevy and 3 others like this.
  19. Dan Hay
    Dan Hay
    I have a similar picture of me somewhere that my wife took, covered in dirt in the trunk of my field car 40 Ford I built. It's tough to stay motivated, but I try to do one thing every evening, even if it's a small thing and only takes 10 minutes, it adds up over time.
    I figure for every one hour you can cruise and look cool there are about 5 hours of dirty thankless work.
    EDIT: Can't believe I found the pic so quickly! I also attached a pic of the "finished" product.
    53olds, Tim, brEad and 2 others like this.
  20. topher5150
    topher5150
    Don't worry I got her back, I made her come with me to the fowlerville swap meet
    LOST ANGEL likes this.
  21. topher5150
    topher5150
    Getting everything together to start on the brakes. Just thinking out loud, what would be the best route to go for the rear line to avoid the exhaust.
    I will be moving the prop valve to the other side and put an adjustable valve to the rear.
    brEad likes this.
  22. topher5150
    topher5150
    Getting the front brakes on and couldn't get the caliper bolts on. Took the caliper off and put the bolt in and the threads don't even go all the way through the caliper. I have two 80s GM bolts and they are totally different. IMG_20240521_184335417.jpg
  23. bobss396
    bobss396
    The 2 shiny ones look after market.
  24. topher5150
    topher5150
    They are, that's what came with the kit. The one on the left is from an 80s G-body GM that I pulled.
    It's just weird that the bolts they have for the kit are so drastically different.
  25. BamaMav
    BamaMav
    from Berry, AL
    My guess is the smaller bolts fit the GM metric caliper, the large one fits the old style SAE one.
    Tim likes this.
  26. topher5150
    topher5150
    The brakes are coming along a little to well....I'm frightened.
  27. topher5150
    topher5150
    Ok what am I doing wrong? I've been practicing on some brake line and every time I flare it, it ends up looking like deck nail....twisted and a square flare.
    Not sure if it's the tool or operator error
  28. RICH B
    RICH B
    If you followed the directions and can't get a good double flare after a few practice flares; I would consider the tool may not be up to the job.
    phat rat likes this.
  29. topher5150
    topher5150
    First I run the adapter and the whole thing goes ****eyed
    This is the first flare. Mind youat this point that I've wrenched on the flaring tool so much that it split one of the set screws
    Thirdly I have to use a hammer to get the flaring tool apart to get the line out and this is what I end up with
    brEad likes this.
  30. phat rat
    phat rat
