Projects Cw moss 7 tooth f100 conversion
Discussion in 'Traditional Hot Rods' started by mark hogan, Feb 12, 2024.
  1. mark hogan
    mark hogan
    Received my steering set up today.
  2. alchemy
    alchemy
    Someone makes a supposedly drop in F100 steering box for all Model A’s? How do they guarantee that fit? Every single engine swap would be different.
    I’d think the builder would need to custom make his flange for distance left and right. Then might need to change the position front to back to clear the engine and the pedals. Hot rods aren’t a one size fits all.
    mark hogan, ydopen and chevyfordman like this.
  3. 1935ply
    1935ply
    from peyton,co
    I have an F-1 box in my '31, with a flathead. I had to machine the mounting flange off and make one for the model a mounting holes and weld it to the box. It's quite a bit closer to the box than the original flange for the pick up. I also don't think you will have much luck with the exhaust with an F-100 box.
    mark hogan and ydopen like this.
  4. Post up some photos of what you're working with so we can see the issues. I have heard that more than one Guy has had to remove the motor to get a steering gear in the ch***is.
    mark hogan, ydopen and Irish Mike like this.
  5. mark hogan
    mark hogan
    As I have the unit just laying in it’s about location, it’s lacking about an inch from mount plate to frame at front section. Just thinking the nose shaft is to long. Could lift or tilt motor to see if it would help. But my gut says it’s to far out towards motor all said and done…
  6. Yes Sir, you are a long way from being correct. The sector shaft isn't even far enough to get the Pitman arm on in the correct place. Hitting the Block is keeping the shaft from getting into the correct position and that is holding the Steering Wheel outboard and probably interfering with being able to close the Door. Not Good! Back to the drawing board.
    mark hogan likes this.
  7. Might be good if we can see the modification to the mount flange that was done.
  8. NealinCA
    NealinCA
  9. mark hogan
    mark hogan
    If it had turned a bit the sector shaft would be the right leigth for pitman arm to connect.
  10. NealinCA
    NealinCA
    To use the F100 box with a V8, you will need to move it back in the frame.
    mark hogan and Pist-n-Broke like this.
  11. mark hogan
    mark hogan
    Boy thinking CW builds a great steering set up.
    Pist-n-Broke likes this.
  12. alchemy
    alchemy
    Can’t return it? Especially since you told them you had a V8 and they still told you it would fit?
  13. Maybe a phone call to C.W. would be in line? If there's a miss understanding an exchange and some freight could get things moving in a better direction.
    mark hogan and Budget36 like this.
  14. mark hogan
    mark hogan
    I dropped them a line and missed the returned call. I’m going that direction in the am. I’ve got a real good idea now as to my fitment of needs. It’s all good . They built a great product. Thinking by time I’m done I’ll be able to help others on the same path. Fun stuff.
    Pist-n-Broke and Irish Mike like this.
  15. mark hogan
    mark hogan
    Not sure at this time if there was a fault? If I was not asked or I did not mention av8 I like to talk about what I’m doing so it had to come out somewhere in our discussions just don’t know if it was a clear statement. S..happens !
    Outback and Irish Mike like this.
  16. dwollam
    dwollam
    I have a '53-'55 F100 box in my '32 sedan with 8ba flathead. I cut the flange completely off and made a new one from 1/2" plate that matched the factory '32 bolt holes. Had to enlarge the center hole in the frame. Poked it thru the frame with the flange slipped over the box and bolted the flange to the frame. Positioned the box where needed and tack welded the flange to the box. Removed complete unit and welded it all up. Clears very well. Yes, '32 frame is a little wider there but I think it would work in an A.
    Dave
  17. 29Sleeper
    29Sleeper
    from SoCal
  18. 1935ply
    1935ply
    from peyton,co
    In the first picture you can see how far the sector shaft will sick out when the flange is moved toward the box. In the second one you can see how the exhaust can be worked around an f-1 box. IMG_1245.JPG IMG_0042.JPG
    kadillackid and mark hogan like this.
  19. Mr48chev
    I didn't find a 7 tooth steering box in the Cw Moss online catalog. Juat the 2 tooth for 1100 bucks that clearly states will not work with an A-V8.
    kadillackid, mark hogan and Budget36 like this.
  20. Automotive Stud
    Automotive Stud
    Not sure if this is any help, my dad put together this A with an F100 box 20 years ago. It can certainly be done. Note he cut the mast off the column at the bottom to clear the engine. It has off the shelf Red's headers for a '32 and they fit with a little m***aging on the rear tube. If I paid that kind of money I'd definitely be on the phone looking for a refund before going and cutting it to fit. thumbnail_20230220_173539.jpg
  21. mark hogan
    mark hogan
    I’m seeing clearly far more option's. On getting a roll on this steering set up. Just to let you all know, I had a person give me the number for CW Moss I never got to look at there site. I just talked about what I wanted to achieve to the person on the other end of the phone. And gave card number to get it made and shipped. It’s a real set back at this point. Clearly a lot my fault. But with all this info I’m receiving it’s like I just paid for a cl*** plus I got a wall hanger & trust me I’ve collected a few on the build…
    19Eddy30 likes this.
  22. Education is something we all go through. C.W. is a stand-up Co. to deal with. I'd still call and talk with them and just maybe something better than expected will come out of it.
  23. Gr8laker
    Gr8laker
    from Michigan
    Mark, we’re all human. Some Hambers are very experienced with these things. Several have walked in your shoes at one time or another.
    Next time, take the cl*** first. It’s cheaper, and you can buy a Hamb calendar for a wall hanger. That’s cheaper too!:)
  24. ydopen
    ydopen
    John
    saltracer219 likes this.
  25. ydopen
    ydopen
    Here is how I did an F1 box
    ModelA flange welded to box.
    Headers may be available from Reds Headers.
    John
  26. NealinCA
    NealinCA
  27. mark hogan
    mark hogan
    I did talk with the owner of CW Moss on my situation at hand, he and I came to the conclusion the AV8 part was never mentioned. All on me. So I shipped the system back. Hoping the still have my core.At this time I’m seeing know way to keep my original steering wheel and lite & horn stock set up. If I go to a F1 box set up. Sad. Still digging for direction. Thanks
  28. NealinCA
    NealinCA
    An F1 box can be set up for use with the original light switch/horn rod ***embly by using a 37-39 Ford lower plate and light switch bracket. The shaft can be swapped out or machined to accept a taper and key steering wheel as well.
  29. mark hogan
    mark hogan
    NealinCA I’m going to contact Millworks and see if they can build this set up! This would be ***’s. Thanks for the heads up, no one’s brought this up. Thanks
  30. NealinCA
    NealinCA
    Here are a couple of F1 boxes set up for 32's with the 37-39 Ford lower plate and light switch bracket
