Technical GM splined steering wheel to 3/4 shaft?
Discussion in 'Traditional Hot Rods' started by Andy65, Jan 13, 2024.
  1. Andy65
    Andy65
    Hello- Just picked up a 40 ford steering wheel that is made for a GM splined IDIDIT style column- My model A has a F-1 style steering shaft/gearbox now. Does anyone know where i can find just a stub shaft of a GM steering column shaft(where the steering wheel bolts on) so i can weld it to my 3/4 F-1 pickup shaft to mate the two together? Ive looked on speedway and summit with no luck so far. or maybe another solution?
  2. 34Phil
    34Phil
    Borgeson
    olscrounger and nochop like this.
  3. nobby
    nobby
    hello
    some 40 aftermarket wheels are dual fitment
    i.e. they have the chevrolet spline count and a slot for a woodfruff key
    which begs the quiestion
    does the wedge mating splinage of a chevy splined shaft replicate the taper of a early ford
    if so
    could you not file a slot into your wheel
  4. Happydaze
    Happydaze
    Gott to be easy enough to harvest the required stub from a s**** gm column? Or are they hens teeth now? Might later models fit? If you're doing the weld job route it'll need some lathe work first to ensure alignment and weld penetration, imo.
    Chris
    Hnstray, 1oldtimer and seb fontana like this.
  5. krylon32
    krylon32
    from Nebraska
    I bought a 40 wheel for my 40 and it had a changeable center for either a tapered and keyed shaft or a splined shaft.
    seb fontana likes this.
  6. deathrowdave
    deathrowdave
    from NKy
    If you knew someone with a lathe , I would have the shaft cut , pinned , same with the stub of the new shaft . Weld it all back together and it’s as good as it was new , just a different spline or keyed shaft
    alanp561 likes this.
  7. swade41
    swade41
    from Buffalo,NY
    Both ford and GM are 3/4 diameter, you could just swap shafts but of course you'd have to convert the lower to your f1 box.
    dirt t likes this.
  8. Speccie
    Speccie
    Andy65, I am in the same boat...I was thinking about using one of these upper steering shafts from GM and grafting it to my steering column. 1b7fd11ddfa234aa9006db700ce3cb0e.jpg
    Andy65 likes this.
  9. krylon32
    krylon32
    from Nebraska
    Just saw a Vintique 17 inch 40 wheel with horn ****on for the tapered shaft for $160. Ad said only used for setup.
  10. Andy65
    Andy65
    the wheel I have is a Vintique 15" wheel- the center is made for a GM tilt column- So I'm thinking my easiest route is to source a GM shaft that I can weld to my F-1 shaft being that they are both 3/4", I just dont have a GM shaft. Ill have to call Borgeson and see if they sell a shaft with the steering wheel end or maybe IDIDIT or one of those company's. I could always go to the pick and pull too.
  11. 34Phil
    34Phil
  12. Joe H
    Joe H
    I have a '41 Chevrolet truck splined shaft with a bad worm gear, if you want the threaded splined end, I will cut off a section for you. Threads might need chased, but the splines are still good. 3/4" shaft.
    Speccie and deathrowdave like this.
  13. deathrowdave
    deathrowdave
    from NKy
    There you go , cut and pin the two shafts to keep centerline accurate v them well . Weld them together and turn or grind the weld , as good as OEM . If you were near , I’d knock it in the head for you for a hand shake of friendship
    Budget36 likes this.
  14. Joe H
    Joe H
  15. Andy65
    Andy65
    OK- if anyone is struggling through this issue i was having- here is what left me confused. the borgeson shaft listed above through summit lists as 57 chevrolet 3/4" shaft, but the steering wheel i had lists as 11/16" GM p***enger car (69-96)- well- they are the same. both 36 spline, and although they list as a different diameter- its the same where the steering wheel fits. I called IDIDIT steering columns and they confirmed this, so i bought the borgeson steering shaft and it fits great. Problem solved! thank you everyone.
    swade41, seb fontana and pprather like this.
  16. I can verify that actual spline fitment for MOST gm wheels 1949(earliest I've personally tried) to the early 2000s is the same
    Johnny Gee likes this.
  17. willys36
    willys36
    Not sure I understand the setup you have but maybe this will help? I am building a '40 Plymouth and wanted to use the stock wheel with a modern GM tilt column. They both have the same diameter but slightly different splines. Here is how I adapted them.
    I bought a GM tilt column stub shaft on ebaY.
    Then I cut off the spline section and put it in my lathe. I turned the splines slight smaller on one end, slightly larger diameter in the middle third and left them full size in the final third
    Then I heated it red hot and quenched it in water hardening it. This gave me a stepped broaching tool.
    I pressed this tool through the wheel hole, cutting GM splines in it. Result was a perfect fitting wheel/shaft.
    Moondog13, cederholm, lostone and 6 others like this.
  18. BJR
    BJR
    NOW THAT'S OLD SCHOOL HOT RODDING. No Amazon or Summit parts, just old school ingenuity.
    ottersea likes this.
  19. 1971BB427
    1971BB427
    from Oregon
    Chevy splines haven't changed in many decades! I have a 2000 Chevy truck column in my '39 Chev coupe and a 1953 Chevy wheel bolted right on it fine.
  20. nochop
    nochop
    from norcal
    I’ve have a 56 olds wheel with taper and key slot (original) and my fusick re pop came straight splined. image.jpg
  21. 31 Coupe
    31 Coupe
    My LIMEWORKS '40 Ford repro steering wheel came with a GM splined GRANT brand hub that's bolted in with 3 x 1/4" bolts.
    When I changed my column to a Ford unit I bought a replacement Ford splined GRANT hub.
    F1 Ford columns have the same tapered spline as later Ford sedan columns etc.
  22. Joliet Jake
    Joliet Jake
    from Jax, FL
    I cut the "keyed" end off of my F1 box shaft. I had someone send me 12" of a splined early 60's steering shaft. I weld prepped and clamped the two shaft ends in a V block to keep them straight and welded it up, done deal, now I can use my 1959 GM wheel on my F1 box. IMG_4963.jpg it was easy. Now I can
  23. 1971BB427
    1971BB427
    from Oregon
    That's weird! I previously had a '51 Pontiac wheel on my 2000 column in my '39 Chev and it too was splined like the '53 Chev wheel I have now.
  24. 34Phil
    34Phil
    '58 Olds fit on '70 column here
  25. nochop
    nochop
    from norcal
    Speccie likes this.
  26. gatz
    gatz
    per willys36;
    "I am building a '40 Plymouth and wanted to use the stock wheel with a modern GM tilt column. They both have the same diameter but slightly different splines. Here is how I adapted them.
    Dang ! great solution!
    I took a more circuitous route when adapting the '40 Chrysler steering wheel to a 78 Malibu column.
    Bore out Chrysler hub to fit turned-down GM hub;
    Drill & c'bore locations for Socket Head Cap Screws;
    Mount GM hub to Chrysler wheel (O'Rings are for horn contact stem); Top View_1.jpg
    Finished 16" (from 18") wheel mounted to 78 Malibu tilt column; Steering Wheel Offset_1.JPG
    cederholm likes this.
  27. banginona40
    banginona40
    In my '33 Ford pickup I'm using a Column from a '60's Ford Falcon Van. I removed the center from the original Falcon wheel and installed it in a '49 Pontiac steering wheel. DSCN3238.jpg DSCN3236.jpg DSCN3237.jpg
  28. cederholm
    cederholm
    Not to hijack, but what do you guys know about Packard steering wheels? I've picked one up. Splined but a larger diameter than my F1. Any idea if its a Packard only, or the same as another manufacturer?
