Hot Rods Tallest, skinniest READILY AVAILABLE radial tire
Discussion in 'The Hokey Ass Message Board' started by drew1987, Feb 15, 2024.
  1. Crusty Chevy
    Crusty Chevy
    EV's are insanely heavy compared to our cars. Tesla Model X long range EV is 5,000lbs. I bet they would have a super stiff side wall and hard long wear compound.
  2. drew1987
    drew1987
    unfortunately, believe it or not those one 85–16 would be too tall lol but, I am writing them down and will definitely use them for something at some time
    As for used tires… I have a couple tire distributors, so “normal sizes” it just doesn’t make sense to try to save the money. Plus, I only have access to a static balancer, and believe it or not it works about 90% of the time, but 0% of the time if the tire is used. Coincidence? Maybe… But I have balanced so many new tires successfully with that balancer – we are talking probably 120 tires – there’s got to be more to it than coincidence
    Yes electric vehicles are slightly heavier, keep in mind a Tesla model X, though, is a midsize SUV. You would be surprised if you googled the weight of a similar sized Honda pilot. I bet it’s about 800 pounds difference at most. I am not a fan of this forced electric, by any means, but it affects me at work so I am up on it…
    Crusty Chevy likes this.
  3. krylon32
    krylon32
    from Nebraska
    I've got 500/16 front and 700/16 Excelsiors on my fendered deuce pickup.
  4. drew1987
    drew1987
    Bias ply of course?
  5. drew1987
    drew1987
    Chucky thanks for those! I have been considering them as well.
    I think for all things considered, I am going to run 15s with 165r15. I am shocked I didnt get those for my 1950 sedan back in the day, as they are WAY narrower than my 205/75r15s
    On the truck, id need to buy 16s (what it came with) and then go crazy for a tall enough, narrow enough tire. I am just going to rock the 15s with 165r15. Literally almost the exact perfect width, the perfect height, and more rubber/less rim (better ride) I am sold. I will likely order a set for the seday as well
  6. Beanscoot
    Beanscoot
    Well this tire linked earlier seems kind of well, expensive.
  7. noboD
    noboD
    A 165 X 15 seems awfully small for what you plan to use it for.
  8. 19Eddy30
    19Eddy30
    from VA
    When I purchased the EV tires about 8 yrs ago for a Pre War vehicle ,
    I hope I did not suport the EV agenda!!
    The vehicles I drive now daily and pleasure are early 90s & older , To me ,I shake my head seeing Vehicles sitting plugged in sitting inside on phones for 45- 1 1/2
    hrs waiting to drive
  9. drew1987
    drew1987
    NoboD it’s actually 28” tall! And 6.x” wide. That’s more than what the cars came with believe it or not. I can always check the load rating but I suspect it will be dandy
    Sglethargic I understand. I know how the internet is (really just less restricted human nature than face to face) but it’s ok if we don’t agree. We likely see the same tangible things with our own eyes and have a different take. It might make one of us right or wrong but it doesn’t make either of us a monster or anything. Either way, peace to you sir :)
  10. drew1987
    drew1987
    Looks like a lot of 165r15 are 1168lb load range. 205/75r15 (currently on my 1950 sedan) 1477lbs
    even with 500 lbs of people (unlikely) the sedan only needs 925 lbs per tire ***uming it’s 3200lb car. It’s going to be more like 2900 with the new style 6 and an aluminum trans
    The truck…. Likely just the wife and I or one 1 kid. Plus maybe a few hundred in the bed. No reason I can’t use those 165r15
    I like more tire for the truck, but I don’t want power steering. Which means pretty ideal to have the narrowest tires possible. Could always just run the bias ply it came with. If I do go wider radial 40psi helps with the steering.
    I have been in business long enough to know why there aren’t simply 175r15 with a 96 load range available for $78 cause I want them ahahaha supply demand compe***ion and volume. ALLLLLL against this endeavor haha
  11. noboD
    noboD
    But a 165 only has about four inches of thread. It's your car, do what you want. I would want a little more maybe a185.
  12. drew1987
    drew1987
    They have a decent amount more road contact than the 600-16 that came with it… and way stickier as it’s a radial
  13. X38
    X38
    But perfect for a VW bug.
  14. drew1987
    drew1987
    Thats what they are sourced from haha (dont tell anyone!)
    Im wondering why I didnt put them on my 50 back when I built it. Probably because 205/75r15 was $45 per tire and we were broke
  15. drew1987
    drew1987
    I found 195r15 and 185r15 by the way. Both of them are 8 ply truck tires. Ironically too big for my application.... 185r15 is a little too tall but strong. upload_2024-2-18_18-27-24.png
  16. drew1987
    drew1987
    SAD update.
    one would ***ume 165r15 meant 165/100r25 but it doesn’t. That would make them 28”. They are only 25.4. So back to the drawing board
    For the truck, I’ll likely run a narrow truck tire. For the sedan I’ll likely just piney up the dough for 205/75r15 wide whites. Or maybe even the bias look radials.
  17. billfunk29
    billfunk29
    from Minnesota
  18. drew1987
    drew1987
    What the ?!?! I cant even imagine what those are for... I do know toyota made a 20" rim thats SUPER narrow like maybe 6" or 6.5 for the new prius but this is just strange. Thats a lot of sidewall for any 19" thats not on a truck! But its narrow. Strange! Cool find
  19. shortypu
    shortypu
    I bought these when i was building my 31,its a 215/85/16 that i mounted on a 16x4 1/2 ford wheel.Found them at Pep boys. IMG_0339.JPG IMG_1851.JPG
    AHotRod likes this.
  20. drew1987
    drew1987
    Those would likely be a perfect fit BUT I wonder if the extra plies make the ride brutal?
    in a car with power steering I’d just under inflate but certainly not in what I’m building haha
  21. 19Eddy30
    19Eddy30
    from VA
    ^^^^^ Those 215/85/16 side walls look like Snow tire's ,, for Me that would be alot of Grinding & buffing to remove lug's off side walls!!
  22. Toms Dogs
    Toms Dogs
    from NJ
  23. drew1987
    drew1987
    Eddy once you grind the tire how do you make it smooth again? How do you buff a tire?
  24. 19Eddy30
    19Eddy30
    from VA
    I do not know how to copy / past a link here from HAMB,
    Thread ***le
    SMOOTHING TIRE SIDEWALLS, REMOVING LETTERING,
    Its a method thats been around since 60 that I know of , do not know when it began
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
  26. pprather
    pprather
  27. billfunk29
    billfunk29
    from Minnesota
    BMW I3 electric. I saw one on the road and they do look weird on a modern car. I plan to use them for road trip tires on my speedster. On widened 19" chevy wire spoke wheels. Save the Cokers with Flaps and tubes for around town. IF I get time, Ill put one on the rim and post a picture.
  28. nrgwizard
    nrgwizard
    from Minn. uSA
    Kinda lost track of which pizza-cutter-tire you're planning on running... but if you're gonna use the Blizzacks, be forewarned that while they're probably the best thing on ice/packed-slicked-snow/fresh snow ever made, they'll wear fast when it gets warm. Not quite like leaving sticky tire tracks down the road, but not far from it. I use them as "bad-season" tires here in MN. Change happens ~ Nov15 & Apr15, from/to "summer-types->soft-winter-types". Doing that, I can get ~ 4+yrs out of each set. Mostly hiway travelling, no burnouts/autocrossing/etc, & that was @ 25k mi/yr min. I actually have bead-leak issues from salt/magnesuim-chloride road "coatings" before tire tread wearing out. I've also learned that since they have 2 rubber-compounds, the last ~1/4" is a harder rubber, so they get used as reg tires then. I've used them as summer-type tires, but they're less than happy at 70*+, tread-wear shows. They are very good quality tires. Close-out price is a screaming deal, get what you can.
    Just a note on probable compromises.
    Marcus...
  29. billfunk29
    billfunk29
    from Minnesota
    I3 tire.jpg The tread pattern is not my favorite, but this seems like the only reasonable way to get modern tubeless radial performance in this size tire. Admittedly, the tire wear is not ideal. Another detail is the rim geometry. The old rims don't have the same shape to grip the bead. I am looking at using the 19" donut spare rims to replace the existing ones. Instead of inserting a strip for widening, I will just add half the donut rims on each side of the spokes. I will still have two welded seams, but no insert strip. I may just test them as is on a trailer to see how they work. I feel better testing custom wheels on a trailer (before paint) so I can inspect for any problems.
  30. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Once you get all that stuff figured out, add this to the mix:
    Skinny 16s for the front and slightly wider 18s for the rear. Same brand and model series preferred. :rolleyes:
    I've just about worn out my computer trying to find this combination. No hurry though, I'm trying to find a pair of Wide 5 18s that I can afford!
    gnichols likes this.
