Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. 1/16" would be enough, and easier to work. You could go even thinner, I've used .040" aluminum. The trick is not deforming it too much while cutting it out. One of those cheap Chinese pneumatic 'nibblers' works well on thin material, just go slow and easy, finish up with a file. Use a light smear of silicon sealer between the intake and the spacer.
    Oneball likes this.
  2. Oneball
    Oneball
    I’ve got one of those nibblers somewhere I don’t use it much as it leaves little bits everywhere! I’ll dig it out.
  3. SDhotrod
    SDhotrod
    I don't know how I missed this thread. Love the look of this car. Especially the tail lights and rear styling. Glad to see the car getting the appropriate attention and a new life.
    williebill, bobss396 and Oneball like this.
  4. Oneball
    Oneball
    I’m loosing the will to live with this carb.
    How hard can it be to get a gasket that fits. Ordered one for a Mustang that had a 4100 as stock and this is what I get.
    Does anyone know of a gasket that works with a 4100 Autolite carb?
  5. That's the way the OEM parts look... Those will work just fine.
    Tow Truck Tom and bobss396 like this.
  6. Oneball
    Oneball
    IMG_6398.jpeg The radius on the top of the bores is such that it won’t actually seal on the carb bores.
    There will be a leak here.
  7. Oneball
    Oneball
    And this gasket is for a spreadbore 4300
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Tim.I know your in England.. but an email into this gentleman might be helpful
    He is very well known for rebuilding Autolites.
    Hope this helps.
    Ed's Carb services.
    Oneball likes this.
  9. Oneball
    Oneball
  10. Oneball
    Oneball
    Cam lubed
    And installed with my Alaskan thrust plate from Dennis
    Oil pump and chain on and timed
    Timing cover and sump on, that run in the paint is going to annoy me, a lot!
    Truckdoctor Andy and lumpy 63 like this.
  11. lumpy 63
    lumpy 63
    Building an FE over there reminds me of the summers I spent in Yorkshire , my cousin Andrew had an 390 powered stock car built on a Bedford van ch***is. His Dad was the local vicar and he constantly had that thing blown apart in the driveway of the vicaridge:D
  12. Pontmerc
    Pontmerc
    from Finland
    Oneball likes this.
  13. Oneball
    Oneball
  14. Oneball
    Oneball
    Hopefully I’m not going to need divine ***istance!
  15. Oneball
    Oneball
    Back to the two steps forward one step back thing.
    The new crank damper just slips on the crank
    I can’t see that being a good thing. It’s surely just going to eat the snout of the crank over time.
  16. lumpy 63
    lumpy 63
    If I'm not mistaken they are pretty much a slip fit, they just seem a little tight when they've been on for years. Im sure someone with more FE experience will chime in
  17. Oneball
    Oneball
    I spoke to the manufacturer, they’re supposed to be an interference fit. Going to see if I can find some one with a bore gauge small enough to measure it and then feed back to them.
    bobss396 and lumpy 63 like this.
  18. Oneball
    Oneball
    Damper bore seems to be 1-2 thou oversize based on the manufacturer’s specs. I’ve emailed Summit to see if they’ll do anything.
    Engine shop is waiting for valve guides, so come to a stop on the engine.
    Moved on to the shocks, got one front off. Looks like an original, there’s absolutely no compression damping left in it all. Would’ve been interesting on the brakes! The top sheered off the other one so gave up on that for the evening.
    guthriesmith and lumpy 63 like this.
  19. Oneball
    Oneball
    Cleaned the exhaust manifolds up and gave them a lick of paint.
    Stripped the rocker covers
    and painted too
  20. bobss396
    bobss396
    I used POR15 exhaust manifold paint on my car... baked at 400 F in the oven, it has held up pretty well.
  21. Oneball
    Oneball
    This is same sort of thing. I used to have a huge oven, like the range ones but with just one door. You could get a whole gearbox case in! Have just got a normal one now, don’t think they’ll fit. It’ll probably just burn off on initial run up anyway.
    If I can save up some money, next year I’ll treat it to some of the Kugel manifolds.
  22. Oneball
    Oneball
    Gave the engine bay a clean and painted the front of the ch***is whilst the engine is out.
  23. Oneball
    Oneball
    Summit have told me the crank damper is ok to use which I think is ********, loose is loose. I've measured the crank OD at 1.3750" (which is within the factory spec) the new damper from Summit measures at 1.3765". So going to see if I can find another one in the UK.
  24. patsurf
    patsurf
    buy a second -return one
    bobss396 likes this.
  25. Oneball
    Oneball
    Shipping is expensive for that weight. Also learned that the 427 style damper won’t fit my car without moving the dynamo. So the old one is going back on for the moment.
  26. Oneball
    Oneball
    Cleaned and painted the original damper, I’ll reference the inner to the outer when the paint is dry just to keep an eye on things.
    Started to get the intake together, smoothed any casting flash in the ports a little, fitted plugs to the exhaust crossover and started to work out the position of the heater pipe and PCV valve. I need to put a rocker cover on and the expansion tank to be sure about the heater elbow and make a plate to bolt onto the PCV hole.
    Also need to find some studs to bolt the carb down, who puts a fine thread in aluminium!!??
  27. Oneball
    Oneball
    Got the cylinder heads back, new valves, guides put in and exhaust manifold face skimmed. IMG_6570.jpeg IMG_6573.jpeg
  28. Oneball
    Oneball
    Heads on
    Tappets and tray in
    Intake on
    I’ll put some paint on and finish off tomorrow
  29. Oneball
    Oneball
    First thing I’ve painted on this so far that went ****ty
    Just checking is this the correct distributor seal?
  30. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes.. that is the Dist. core ring.
    loudbang and Oneball like this.
