Technical ‘41 Ford banjo
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 20, 2024.
  1. 65standard
    65standard
    FEEA1C95-3399-45DB-A072-61F2DCAD97A3.jpeg I’m using a 1941 Ford car rear ended in my ‘32 ford. I see some stamping on the bottom of it. Hard to tell but looks like something-34. Anyone know what ratio was used in 1941?
  2. continentaljohn
    continentaljohn
    Depending on what it came out of it 8-34= 4:25 truck ? it does look like a 9 so 3:77 and more common in early ford
    Moriarity likes this.
  3. jimvette59
    jimvette59
    It is 9-34 4:11 OOOPS ?
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    9-34 is 3.78
    Tim likes this.
  5. Ken Smith
    Ken Smith
    Alliance Vendor
    34 ring gear teeth. 9 pinion gear teeth, so the ratio is 3.78:1.
  6. wheeltramp brian
    wheeltramp brian
    Same as mine in my 41 3.78.
  7. 65standard
    65standard
    Thanks everyone. Appreciate the help
  8. doctorZ
    doctorZ
    That's the original ratio. That being said, it's worth checking (if you are after a certain ratio) because after 80 years parts tend to get swapped out.
