Hot Rods Let's finish the 50 Chevy pickup
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Dec 29, 2023.
  1. 05snopro440
    05snopro440
    That's the one! they also had a 60/40 split bench if someone found that more desirable, and similar looking buckets.
    Bill's Auto Works likes this.
  2. I like those seats but they are a royal pain in the *** to recover because they are molded. If I could find a black one I'd roll with it :D
  3. These are the newer-ish Chevy pickup transplants that came already in my '50 AD panel truck. I'm gradually s****ing off a lot of the "street rod" influences on it, but I think I'll keep the seats,........ partly because I like the built-in seat belts. In my case, I like being able to step through to the cargo area. I might reposition each seat outboard an additional 1/2" so I'll have an inch more in between for my big feet.
  4. 05snopro440
    05snopro440
    Molded as in the foam is molded? Just curious, I know little about upholstery.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Being in the business, how hard would it be to re-foam the carc*** and make a traditional cover for it?
    427 sleeper likes this.
  6. swade41
    swade41
    from Buffalo,NY
    Can't you just go right over the factory material to avoid the struggle ?
    Lloyd's paint & glass likes this.
  7. swade41
    swade41
    from Buffalo,NY
    I've had all 3 styles in it, the 60/40 and the fold down armrest models (armrest set up like 60/40) make you sit a bit left of the steering wheel since it's a contoured foam design, the early models of the bench were the flattest, this bench is an 89.
    Here's the 60/40
    05snopro440 likes this.
  8. lumpy 63
    lumpy 63
    I use the 88-98 seats in all the 55 -72 trucks I build, and yes the upholstery shops dont like em because they say they have to peel the fabric off the foam.
  9. ***Area-51***
    ***Area-51***
    from Ohio
    Yep, I find these to be fairly comfortable too, if you can find one that's not fubar'd
  10. The pattern is in the foam, I've never been to the factory and seen them made, but it's all heat formed and the cover is glued to the foam. When you try to pull the material off it'll tear the foam up. You can recover them, 1/2" sew foam will absorb some of the pattern, but not all.
  11. I just looked at swade41's seat again, I'm not sure that one is molded. Terry text me earlier that he had one that appears to be 56", said it's got a good cover on it too, but it's tan. I'm gonna go get it next week
  12. twenty8
    twenty8
    Geez man, be careful how you phrase things..........:p
  13. That's how we did them back when we had S&S Automotive. Glue a piece of 1/2" sew foam down, then use 1/2" on your covers. It works decent
  14. 32fenderless
    32fenderless
    for the 88-98 style, if you find a cheaper version truck that has vinyl covering they don’t have the formed foam. Much easier to upholster. Also, stay away from the ‘95 -98 style as that foam is contoured to your body and doesn’t line up well with the steering wheel on the 47-54 style trucks.
  15. Apparently, I need to start looking for an 88-94 seat as well. Hopefully with a nice blue upholstery.
  16. Lmao!
  17. Just stole this image on Google, I wanna do this in black but use blue thread. Cup holders optional ;) images.jpeg.jpg
  18. This evening I jumped in the cab and installed the new turn signal switch, made a bracket for the brake light switch, and stuck it all together. I've got a hot wire hanging for the headlight relay, but that's as far as I got. Brake, tail and turn signals work fine. Didn't take pictures. I have some crayons, guess I could draw some :confused: :D
  19. lumpy 63
    lumpy 63
    Turn signals check, brake lights check, burnout shots? :p
  20. You'll be the first to see it if it happens lmao! Hard to take a picture from inside the cab though :rolleyes:
  21. Old shop truck getting closer... 20240221_133422.jpg 20240221_133436.jpg 20240221_133529.jpg 20240221_133558.jpg
  22. lumpy 63
    lumpy 63
    Hey Lloyd , I can probably get the factory deluxe heater from that same truck if you want....
  23. Los_Control
    Los_Control
    from TX
    @Lloyd that seat looks like it fits pretty good. What do you think it came from?
    I have a 1991 chebby daily driver .... I thought about putting the buckets in it and the bench from the chebby in my 49 Dodge.
    My 1991 bench is about 58.5" and kinda too wide ... when I close the doors the edge of the seat will be right up against the doors. .... and molded so would not really be sitting centered with the steering column.
    I'm going to have to agree that @swade41 has a really sweet looking seat :eek:
    I'm guessing it is a 1973-1987 C10 (square body seat)
  24. swade41
    swade41
    from Buffalo,NY
    The bench seat I currently have in the 57 is from a 1989, like I had mentioned the earlier OBS truck seats seam more flatter but the later ones towards the end of the series have a more contoured foam.
    It's like they have molded in side bolsters on each side of the spot (60/40) they want you to sit in, even that 89 has some in it.
  25. rusty1
    rusty1
    hey Lloyd, who's 65 Malibu?
  26. chevy57dude
    chevy57dude
    Truck sits really nice! Dang! Now you just have to find someone to put the gl*** in it.:cool:
    What kind of shop dog are you going to end up with? At least a cat..
  27. It's a customer car
  28. This seat is the back seat from a square body blazer. It's 50" wide. Got about 4" open on each side of the seat. It's too small, I've got half an *** cheek hanging off one side lol
    SS327, mad mikey, 05snopro440 and 4 others like this.
  29. What's it look like?
