Hot Rods Inside diameter of Speedway straight front axle
Discussion in 'The Hokey Ass Message Board' started by AnimalGuy, Feb 22, 2024.
  1. AnimalGuy
    AnimalGuy
    I was wondering if anyone e would know the inside diameter of a Speedway straight front axle. Is either the standard or the heavy duty a 1 3/4?
    I'm starting a g***er build and it's a really small car and I think the 2 inch axle will look like a dump truck axle under it. I figured since I. Going to have to get a custom axle and solar nobody wants to make one with a smaller tube I thought about just cutting the ends off the bigger axle and welding in the smaller tube.
  2. big john d
    big john d
    from ma
    try WACCUSTOMS torrington conn
    AnimalGuy likes this.
  3. squirrel
    Unless the engine is way far back in the car (like a dragster), then you really want a 2" axle. Which is why no one will make you a smaller one.
  4. AnimalGuy
    AnimalGuy
    Yeah, I can see that but my car only weighs 1300lbs total. I figurd I'd a car like a 58 impala with a big block goes down the track on a 2 Inch axle mine should be fine with a thick wall 1 3/4 chromemoly axle.
  5. squirrel
    It probably would be OK at 1-3/4".
    I think you'll find the tube ID of the Speedway axle is closer to 1.5", though.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    will anyone even be able to visually tell the difference on 1/4" in diameter? seems like a lot of effort for nothing?
    GordonC likes this.
  7. squirrel
    I wonder how hard it is to find an Anglia axle? or if that's not the correct width
    Moriarity likes this.
  8. lake_harley
    lake_harley
    AnimalGuy....I sent a PM to you about an axle I have that might be of interest to you.
    Lynn
  9. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    This might be of interest to you. Probably have to put an internal sleeve in and turn down the outer but it is a forging. There are a few variations.
    https://www.speedwaymotors.com/Weld-In-Axle-End-5-2-Inch-x-188-Inch-Wall,37949.html
    May Dad made a couple of these for me when I was a kid to fit '54 Chevy spindles to a homemade straight axle. I don't remember the O.D. 4130 that we used, but I think it might have been 1 7/8".
    AnimalGuy, Fordors and squirrel like this.
  10. 1ton
    1ton
    Was just looking at that specific axle. Thinking of making my 56 a g***er.
    The speedway axle is two inch OD with 1/4" wall thickness.
    To me that sounds about right. I would not go smaller. MHO.
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Just for comparison, Mark Williams makes 1 1/2" and 1 5/8" tube axles with .125" and 1.88" wall thickness.
    Unfortunately, they will not make one longer (at least in the 5" drop).
    Seems like the OP isn't too far off with a 1300 lb. car.
    https://markwilliams.com/34004.html
