Technical Shortened 32 rolling chassis for a model A
Discussion in 'Traditional Hot Rods' started by Hotrodmeister, Feb 6, 2024.
  1. Ron Brown
    Ron Brown
    Try Blackboard Hotrod Frames in Bakersfield, Ca....I have one in my 31 roadster on 32 rails and it handles like a gocart...I'd buy another no problem...when I get home Sat. I can post some frame pics if you like. IMG_5023.jpeg
  2. Hotrodmeister
    Hotrodmeister
    from Virginia
    b
    Please do! Thank you for contributing!!
    Outback and 19Eddy30 like this.
  3. banginona40
    banginona40
    I have pondered doing the same thing. I did speak with the gentleman from Blackboard in Central Valley, Ca. and he had no problem with a pinched and shortened '32 frame setup up for a Model A. Boling Bros. are doing some really nice work too.
  4. oj
    oj
    Jack from down around Virginia Beach does them for Hilton, give him a shout.
    Just Gary likes this.
  5. Hotrodmeister
    Hotrodmeister
    from Virginia
    What engine and trans setup were you contemplating with the shortened frame?
  6. hotrodlane
    hotrodlane
    Are you sure this frame in this build thread only has a 103.5 wheel base? As there looks to be plenty of room in front of that flathead. I went through the thread and don't see where he shortend the wheelbase. Maybe I am just overlooking it. Said he printed the rails full size from wescotts site. Thnaks
    X38 likes this.
  7. hotrodlane
    hotrodlane
    Could you please post some example pics of a Car with the frame you are wanting? As I personally have never seen anyone do this. And you say the reason you want to do it is to achieve a certain look. So surely you must have seen this certain look before. Please post some pics
    X38, Outback and Just Gary like this.
  8. D-Russ
    D-Russ
    Copied and pasted from post #254 in the thread I linked earlier:
    "I planned all along to use a model a body on my frame with a slight channel so I wasn't too worried about it being exactly perfect in every dimension. As for it not being exactly the right length...well, your right, it's a tad shorter, but there again, I was putting a model a body on it so it wasn't an issue for me. I actually bobbed the front of the rails 2 1/2 inches and kept the stock model A wheel base of 103 1/2 instead of the 106 for 32's."
    flthd31, 05snopro440, Outback and 2 others like this.
  9. Ron Brown
    Ron Brown
    I went with the 32' length frame...it allowed me to use a SBC with no firewall setback and had Rotlieb build the hood to fit....I like the look of the extra length hood IMG_0576.jpeg IMG_2675.png IMG_2680.png
    Just Gary and 282doorUK like this.
  10. Crumley
    Crumley
    Hot Shoe Hot Rods in Missouri make an A+ frame. They have a website. It is basically a 32 frame with a top of the frame flat to accommodate a model a body. They the in different stages of completion.
    Outback likes this.
  11. Hotrodmeister
    Hotrodmeister
    from Virginia
    I believe Flthd31 crafted his gorgeous coupe with shortened 32 rails. I think many on this forum would consider his very well done.
    D-Russ likes this.
  12. Hotrodmeister
    Hotrodmeister
    from Virginia
    Thank you for sending this information along! It is very intriguing, seems like a similar design to Walden's. I believe Walden's requires minor cutting of the body. I am not sure if Hot Shoe's rendition is almost completely bolt on.
  13. flthd31
    flthd31
    I'm the guy that built that grey coupe and yes it has a 103.5 wheelbase. I did print full size rails but modified them to fit my needs.
    teach'm, V8-m, Dino 64 and 3 others like this.
  14. flthd31
    flthd31
    Here's a few pics for you. It's not that unusual. Generally speaking if you see a Model A on 32 rails with a stock hood, the wheelbase is stock, there's no other way to do it. If it has a 32 hood the wheel base is most likely 1 9/16 longer than stock model A (that's the difference in model A and 32 hood length).
    The look is a low model a with a hood that's short and stout like Henry built them.
    To some of us that extra long hood looks out of place on a model A. You may not be able to notice it but to some it sticks out like a sore thumb. A couple of these pics are of my car. 356643-1326525577-20938d175fbb04acfe54501ea786d459.jpg 426758-1353300333-ad4f9e6c0f76e14ff5484d3e89509fa3.jpg before tear down with tires_013.JPG DSC_8056.jpg grey coupe5a.JPG IMG_4647.jpg IMG_4658.jpg smallIMG_6577-4.jpg uploadfromtaptalk1356040715970.jpg uploadfromtaptalk1356040818493.jpg
    teach'm, 05snopro440, Dino 64 and 3 others like this.
  15. flthd31
    flthd31
    Here's how it was done. Unfortunately a few guys just posts to change your mind. You've got a good eye. The difference is subtle but powerful.
    I did recess the firewall about 3 1/2 inches only in the area that interfered with the engine. That's why from the side view it's not that noticeable. This recess works good for me. I've done a few like this. Pedals are no problem at all. A small block Chevy wouldn't be much different. I used F1 pedals and bent them to fit my application. It's all connected with original Ford clutch linkage. Hangers would properly work better for you. recess firewall_008.JPG recess firewall_009.JPG recess firewall_010.JPG recess firewall_013.JPG recess firewall_018.JPG recess firewall_019.JPG recess firewall_020.JPG
    Tim_with_a_T, Rolleiflex and hfh like this.
  16. flthd31
    flthd31
    Here's some floor pics that may be of some help. I like to make my floors removable. The master cylinder and battery are under there.
    coupe floor_003.JPG coupe floor_006.JPG ebrake5.jpg floor finish_011.JPG floor finish_016.JPG
  17. -Brent-
    -Brent-
    If you're going to run a stock A length frame, you'll have to do the same type of modifications of A-framed hot rods.
    I reversed my firewall to give me space. At the time I wanted either a 389 Pontiac or a 327 Chevy.
    Luckily, if you push the firewall back, you can remove the rear shelf and it's a pretty decent trade.
    hfh, Outback, flthd31 and 1 other person like this.
  18. hotrodlane
    hotrodlane
    You did one hell of a job building those rails. Did you also make the top of them completely flat like model A rails or do they slighty kick up like 32 rails do from the firewall forward?
  19. flthd31
    flthd31
    Thanks. They're slightly kicked up like 32 rails do. That little rise gives a couple inches more drop in front. Model A cowls have little feet that are easily modified to compensate. Here's my way:
    32 ford frame build_436.JPG 32 ford frame build_439.JPG 32 ford frame build_440.JPG 32 ford frame build_441.JPG 32 ford frame build_442.JPG
    teach'm, hfh, akoutlaw and 3 others like this.
  20. Hotrodmeister
    Hotrodmeister
    from Virginia
    Outback likes this.
  21. Hotrodmeister
    Hotrodmeister
    from Virginia
    Did you ever consider using a flat 32 firewall? Is there a reason that would be problematic?
  22. flthd31
    flthd31
    No I never considered a flat 32 firewall. You would have to do some fab work to make it fit the model A cowl as it's not welded in on a 32. It could work. I'm sure it's been done.
    Plus my firewall wasn't all that bad except for the feet which needed modified anyway.
    Another note for you. The frame was shortened by locating the rear tires dead center in the rear wheel-wells of the body then measuring forward 103 1/2" and locate the front cross member. In essence the front cross member was moved backwards. I then bobbed roughly 3" off the frame horns to be more like a model A.
    I was originally going to use a model A hood but ended up using an original 32 hood which is 1 9/16" longer than Model A. Had I known that when placing the front cross member I probably would have moved it 1 9/16" farther forward. I had to cut some off the 32 hood at the cowl to make it fit.
    teach'm, Dino 64, hfh and 4 others like this.
  23. flthd31
    flthd31
    Here's a 32 firewall in a model A
    05snopro440 and akoutlaw like this.
  24. hfh
    hfh
    from Western MA
    I built my roadster many years ago. I used a stock wheelbase ‘32 frame with a ‘29 roadster body. I’ve always thought that the hood is too long. I wish now that I had moved the front crossmember back a bit.
  25. Jmountainjr
    Jmountainjr
    Hot Shoe Hotrods in MO aquired LRS Inc that was also in MO and developed the '32 A-Plus frame. You can mount the A body onto a '32 style frame without modification to the rear body sills. The only real give away is where the frame makes the 90 degree inboard turn at the front of the rear wheel well. Back when I ordered my LRS frame you could get about any wheelbase you wanted. The LRS frames were well made with excellent welding. Maybe give them a call and see what's available today.
    19Eddy30 likes this.
  26. Hotrodmeister
    Hotrodmeister
    from Virginia
    This is very interesting, and informative. Thank you for taking the time to share. Do you have any pictures of the car with that frame?
  27. Dino 64
    Dino 64
    from Virginia
    You did a fantastic job on that coupe, you were nice enough to give me the color of it, thank you
    oj, akoutlaw, Outback and 1 other person like this.
  28. flthd31
    flthd31
    Ha ha!
    Yeah...no problem. Coupe's looking good.
    Dino 64 likes this.
  29. Hotrodmeister
    Hotrodmeister
    from Virginia
    That is a sharp color. Both of your cars turned out great. Who made your frame?
    Dino 64 likes this.
  30. Dino 64
    Dino 64
    from Virginia
    Brookville, after building it, I realized a Pete & Jakes frame would have better. If was ever did again
