Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    More Shaker time today. got the outriggers welded in and one brace for lower control arm mount.
    Ben enjoying this free welder. :)
    Okie Pete, mad mikey, enloe and 15 others like this.
  2. patsurf
    patsurf
    guthriesmith and bchctybob like this.
  3. saltflats
    saltflats
    from Missouri
    When I would go to the Melt Down Drags the car entry number goes in a raffle. It was my lucky day. :)
    The Melt Down guys really had it figured out. All the sponsor money went into buying stuff for car guys and gals and they had stuff donated also and it went in the raffle. They are non profit.
    One year a won a stack of DVD's of vintage drag racing.
    Okie Pete, mad mikey, das858 and 10 others like this.
  4. Lloyd's paint & glass
    Hmmmmmm.... sounds like Lloydfest 24 needs a welder and a plasma cutter to give away this year!
  5. mopacltd
    mopacltd
  6. saltflats
    saltflats
    from Missouri
    Thanks
    mad mikey and osage orange like this.
  7. Lloyd's paint & glass
    And you got a free Gene Winfield autograph :D
  8. saltflats
    saltflats
    from Missouri
    That was a bonus :cool:
    I have Gene's autograph from some years back at the SEMA show.
    Okie Pete, mad mikey, enloe and 6 others like this.
  9. Rlc51
    Rlc51
    Been working on the 26 t the 265 lost compression so found a runner 283 to bolt in its place need to finish up the wiring and and figure a new fuel tank and should be back and running
  10. Dick Stevens
    Dick Stevens
    It would be great if you would select full size images when when you post pictures, it just makes it easier for those of us that follow the threads. TIA
    guthriesmith likes this.
  11. I'd be delighted to have welds that good. I've got the Hobart Handler 190 and a Lincoln tombstone backup. As an old farmer once told me, "I guarantee it not to rip, rattle or tear." Breaking wasn't guaranteed.
  12. Rlc51
    Rlc51
  13. Rlc51
    Rlc51
    Sat here for like 20 min trying to figure out how to do that and think I figured it out for next time !
    osage orange likes this.
  14. atch
    atch
    Great!
    You can change the existing ones in the edit function.
    Thanks.
    Bill's Auto Works likes this.
  15. atch
    atch
    Not his first rodeo (obviously)...
  16. fastcar1953
    fastcar1953
    Fixing the big ugly grille. Time to make it look right. IMG_20240222_190106652.jpg IMG_20240222_185950360.jpg
  17. 26 T Ford RPU
    26 T Ford RPU
    Needs a crank hole in the grille.:) JW
    fastcar1953 likes this.
  18. fastcar1953
    fastcar1953
    I'm just glad it doesn't look like a cattle guard off a train.
    bchctybob likes this.
  19. D2Denny
    D2Denny
    Finished up fabricating pedal mounts for AV8 conversion. Didn't want to spend $$500. on a pedal kit or trying to locate an F1 or 32 cross member, so was able to do it with $12.00 worth of 1/4" plate. When I removed the body but before pulling the 4 banger I made a Jig for pedal location. Was able to land the later pedals in the exact spot that the A's were.
  20. vtwhead
    vtwhead
    ^^^^^^good idea!
  21. swade41
    swade41
    from Buffalo,NY
    Sent some juice down the 41's new central nervous system, proud to report no smoke ! Lol
    Tomorrow I'll circulate the fuel system to check for leaks and turn it over with the coil off to build some oil pressure, if all is good then see if it'll fire.
    Last time I attempted this the harness melted down freakishly.
  22. Digging thru some of the trans junk I bought Monday.
    Guy said he had all the pieces for a Saginaw R10 set up.
    plus spares
    Got an extra non OD Saginaw and another trans with OD with all the other junk
    Kinda simple.
    Didn’t come with solenoids but I have 3 and 3 governors at the house.
    I’ve got a bag full of the needle bearings and other small pieces for the OD
  23. Thought about using the Saginaw in my merc. Almost the same length as the Merc 3 speed set up.
    Ive got an s10 t5. About 2 inches longer overall. Only thing I kinda don’t like is the 4:1 first
  24. Mike Miller
    Mike Miller
    Rear bumper and throttle link. DSCF5745.JPG DSCF5747.JPG DSCF5748.JPG DSCF5749.JPG DSCF5750.JPG
  25. I’ve spent quite a few hours stripping my 56 Bel Air Sedan. It’s been sitting around waiting it’s turn for way too long. It’s got a long way to go. IMG_9334.jpeg
  26. MMM1693
    MMM1693
    Looks like a good start and good bones to start with
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    gave it a gl*** bead blast and mounted some 97's I had with SP tops horne22.jpeg
    Made up a couple of dog bones and linkage
    horne44.jpeg horne55.jpeg horne66.jpeg horne77.jpeg horne88.jpeg horne99.jpeg
  28. rustydusty
    rustydusty
    Right now I’m wrestling with an exhaust system for my’40 Olds. Tried block hugger headers and they hit the steering box. I have now bought “extra short” headers and still have an issue with the down” pipe. Just ordered a flexible exhaust pipe. Hopefully this will work…
    bchctybob, mad mikey and lumpy 63 like this.
  29. lumpy 63
    lumpy 63
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    I used to have an L79 327 in my shop bathroom, but it is gone now...
