Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 327Eric
    327Eric
  2. Messing with a 3 speed OD
    Saginaw output shaft bearing.
    Pressed?
    Snap ring is out. Barely moved.
    Gotta replace a gear
  3. Hard to flush, even with a plunger. Ever think of adding more fiber to your diet? Oatmeal helps.
  4. Lloyd's paint & glass
    I worked on luxuries lol, stuck a hose on for my brake booster, put my power steering hose on, vacuum lines for the modulator valve and spark advance. Most of the day was customer cars.
    scotty t, Tickety Boo, enloe and 5 others like this.
  5. gimpyshotrods
    gimpyshotrods
    I finished up the pruned case 4-71 that I was working on.
    This is a combination of vintage, new-old-stock, and new parts. I tried to get the finishes to match as close as I could. When the snout and tensioner are selected, I will apply the same finish techniques.
    Now on to building the manifold.
    29A-V8, Okie Pete, bchctybob and 25 others like this.
  6. guthriesmith
    guthriesmith
    Worked on the rear brakes on my slightly OT car yesterday after I noticed that the right rear wheel cylinder was leaking. I found lots of stuff that needed replaced once I pulled the drum. So…looks like it will sit on the lift waiting on parts I had to order while I am in Ohio this week for work. I’m not the worlds best at maintenance, but seems my buddy that I bought this car back from did zero maintenance while he owned it the last 9 years. I just need to go through most everything before trying to drive it up to Springfield, MO for the SWMO Hot Rod Hundred coming up in just a few weeks.
    Okie Pete, rod1, MMM1693 and 6 others like this.
  7. High test 63
    High test 63
    Tell me again what you're working on lloyd? A '79 caddy? Lol!
  8. lumpy 63
    lumpy 63
    20240225_122624.jpg Worked on the 52 pickup today, George came by with his *****in fleetline , the wheels are 1 inch too big to show:cool:
    Okie Pete, Stock Racer, rod1 and 13 others like this.
  9. DDDenny
    So, I'll just ***ume you forgot to post photos, you do have photos right!
    lumpy 63 likes this.
  10. ****. I posted these on the wrong “working on or do with your car thread”
    Muncie 319. R10 OD take apart number 2.
    the OD is in great shape. The trans isn’t.
    busted 1st gear and cluster that shaft looks great correct?
    Got more gears in stock at the house. Plus another complete trans.
    got an extra case for an OD trans if I need it.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    it was a 65 375hp short block that I bought on CL about 10 years ago. the guy advertised it as a 283. it was a CE engine that had about 5000 miles on it but it had freeze cracks on both decks. I paid 100 bucks for it and kept it until about 2 years ago when I sold the pistons and rods. I s****ped the block but still have the beautiful std small journal crank. sorry no pictures..... I would sell the crank though
  12. squirrel
    is something missing from this mainshaft?
    bchctybob and guthriesmith like this.
  13. squirrel
    I've been tinkering with interior again, got the kick panel in finally.
    Might recover a seat next.
  14. gimpyshotrods
    gimpyshotrods
  15. Oh yea.
    Here it is IMG_7326.jpeg I’ll be looking for a 319 main shaft
  16. gimpyshotrods
    gimpyshotrods
    I see them on eBay on the regular.
    Push the pieces together and get a measurement on the overall length.
    That will make it easier to match it.
    427 sleeper and Truckdoctor Andy like this.
  17. Grandadeo
    Grandadeo
    Finally back on the front suspension of my '48 F1 Panel after locating an elusive driver's side spindle arm. However, took a detour yesterday with the help of my son-in-law to track down an electrical issue that was keeping my roadster parked. I hate electrical - it's magic.
    Lee
    29A-V8, 61Cruiser and guthriesmith like this.
  18. lumpy 63
    lumpy 63
    I see you are slowly creeping up on that ugly steering wheel:p
  19. @gimpyshotrods
    PThe 318 and 319 share a lot of parts. The case has an extra hole for the reverse lockout and the main shaft is cut different
    319 shaft
    318 shaft. IMG_7328.jpeg lengths look the same. Splines look longer for the 319 plus the c-clip groove
    I’ve got an extra 318. Wonder if my machine shop guy can lengthen the spline ***uming the diameter is the same ?
    These other pieces were in the stash of spare parts.
    Muncie 4 speed stuff?
  20. gimpyshotrods
    gimpyshotrods
    I am seeing some listed as 318 with overdrive, that have the clip groove. I wonder if that would work.
    https://www.ebay.com/itm/1749970347...r&brand=Muncie&_trksid=p4247815.c101506.m1851
  21. Last edited: Feb 25, 2024
    Truckdoctor Andy and lumpy 63 like this.
  22. squirrel
    yeah, that's the last part that will turn red!
    Tickety Boo and lumpy 63 like this.
  23. Voh
    Voh
    I tried my had at painting the '41 on Saturday. I have a LOT to learn.
  24. Solid!
  25. Since i can’t speak of my current project on this site all i’ve got is i did the chevy shuffle and cleaned my garage up. It was 72* yesterday ( it should’ve been 25*).
    C83C7EF2-CCFC-4BB9-92C0-5978D55DF9C9.jpeg FAF74B1F-5943-40FE-A365-C6B850651839.jpeg 06EAF6CD-1761-45BF-B7D8-31A9D91799B7.jpeg
    current project has been evicted and tarped for now
  26. lumpy 63
    lumpy 63
    Is the one under the tarp the project you told me about thats getting the Tesla motor , bags and 22 inch wheels?
  27. YESSIR!:D
  28. chevy57dude
    chevy57dude
    Well, good thing it's outside then.
    Nice shop!
  29. swade41
    swade41
    from Buffalo,NY
    I got my 41 fired up yesterday for a short run, between it being pig rich and a coolent leak it ran me out of the garage.
    Today I investigated the leak and it's the cap on the new remote filler neck, doesn't seem to remain tight in the full twist on setting, but is tight at about an 1/8th turn, 3 different caps did the same thing.
    Looks like a few complaints on Summit's question and answer review section, I did order a different cap that someone else said works.
    I was only off by 2 degrees retarded on my timing so added that in and it cleaned up the rich idle a tiny bit. I fought with these carbs for a couple months in the past and finally threw in the towel and put my old carbs back on. I'm going to have to breakdown and drill and tap these metering blocks to put adjustable bleeds in to reduce some of the fuel, I was hoping the new bigger blower and fresh gaskets would clear them up a bit.
    Okie Pete, bchctybob, enloe and 8 others like this.
  30. alanp561
    alanp561
    But, the threads were cool;)
