Hot Rods rear tires
Discussion in 'The Hokey Ass Message Board' started by cabriolethiboy, Apr 6, 2019.
  1. A Boner
    A Boner
    Any chance you could post a screen shot of this tire from the Yokohama website?
  2. chopndrop
    chopndrop
    Screenshot_2019-04-11-08-30-01.png Screenshot_2019-04-11-08-30-29.png Screenshot_2019-04-11-08-30-35.png
    Looks like comes in 2 sizes
  3. dana barlow
    dana barlow
    from Miami Fla.
    For the time frame,,rear tires 1950s started getting some wider tires an 15in. 5up to 6in was in thing an 16 out if your hotrodding.1960s 6to7in+, 15 an 14in. was getting in the mix fronts could even be 13rims, end of 60s 8+. Only thing using under 6in rears normally an maybe 16in was flathead V8s n fours. OHV V8s looked for wide for some bit.=16 an 5in wide dose not belong for the most part on OHV V8 powered hot rod. I know today some of you kids look around at all the rim higths an think,sure 16rim,but no those 16s were going out like bigger then 7in. headlights were out of style an in the trash. How well things worked had a lot to do with what hot rod guys picked to use. So wider rear tires for bit/an looks an smaller 7in. head lights{ unlike the big old ones,actually worked well plus looked much more aero. Pick your time,or mix it up an look off the mark. Extra note on wide rims,better to have match or bigger then tread,rims smaller the tread looked to be on wrong rim but was done some do to low $.
  4. AHotRod
    AHotRod
  5. AHotRod
    AHotRod
  6. I bought the cheapest bias ply look LT tires I found in Europe. Fortune FSR112.
    Bad choice.
    7.00-16 12 ply and F load range.
    The are heavy and very rigid. Impossible to fit on my 4’’ wire wheels.
    All I did is scrtach the fresh powder coating.
