Art & Inspiration Rubber hardness testers
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Feb 24, 2024.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    Does anybody else collect these? Meant for testing the durometer of your slicks
    C16881B6-50DA-4691-9CC9-5F045D955982.jpeg 64702E2F-9E18-4C88-8E27-C6299B5CE691.jpeg 2A70A0CB-BB6C-4E97-B317-2FC928D86F0D.jpeg 572093EF-5561-4D9D-9414-838F186C0CE8.jpeg D481D607-B9D9-4A4A-AC12-1EAD111F0F35.jpeg
    rod1, Jim Bouchard, Ziggster and 13 others like this.
  2. greybeard360
    greybeard360
    Those are durometers.
    They test hardness.
    The hardness isn't a durometer.
    It is for testing plastics and rubber.
    loudbang, SS327 and Tow Truck Tom like this.
  3. '51 Norm
    '51 Norm
    from colorado
    I didn't know that there was such a thing says the guy that tests tires with a hammer.
  4. alchemy
    alchemy
    I thought you were supposed to use your boots to test rubber?
    Tow Truck Tom and Sharpone like this.
  5. BJR
    BJR
    Moriarity, is there anything that you don't collect? :)
  6. Didn’t know those existed ?!?!
    Now I need one !!!!
    Do you want thin the collection ??? Ya got a couple to many of the moon ones !!
    dang you got all the toys , absolutely love it !!
  7. blue 49
    blue 49
    from Iowa
    If all of them are used on the same tire, do the readings match? Just curious.
    Gary
    19Eddy30, SS327, rockable and 3 others like this.
  8. Roothawg
    Roothawg
    No, but now I feel the need to collect them.
  9. bchctybob
    bchctybob
    I've only seen them in photos in HRM and other magazines.
    You probably just bumped up the value of your collection by a factor of ten.
    Driver50x, 427 sleeper, SS327 and 4 others like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I will try that tomorrow and report back
    19Eddy30, 427 sleeper, SS327 and 5 others like this.
  11. Dave G in Gansevoort
    from Upstate NY
    Had one in my dirt track days. Gave it to a friend when I went to college. Haven't used one since 1981 or 82. Nice collection
    Tow Truck Tom, Sharpone and Moriarity like this.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
  13. Bandit Billy
    Bandit Billy
    Rubber hardness testers in school were a lot less complicated. If you stretched them out and they didn't break, you were good to go.
  14. lumpy 63
    lumpy 63
    Damnit Mark ...now I need one .
    rod1 and Sharpone like this.
  15. lumpy 63
    lumpy 63
  16. jaracer
    jaracer
    I bought one when I was racing. We had a number of tire compounds with different hardness. At the time most guys used their fingernails to get an idea of the compound. Before Hoosier started making thin sidewall race tires, we ran Firestone wrinkle wall slicks (which we grooved). I remember buying a new slick which durometered the same as the old one I was replacing. However, the new one wouldn't touch the track like the old one. I guess it wasn't that the durometer lied to me, it that the hardness of the compound isn't the only thing that makes a tire work.
  17. Dave G in Gansevoort
    from Upstate NY
    Remember the craziness of those Firestones, just touch anything and the sidewalls were toast. So easy to cut thru the sidewalls. I don't have a clue how many plies the sidewalls were, but if it was more than 1, I'd be surprised.
    Here in the northeast, we had M&H Racemasters, then Firestone Indy car or formula one rain tires, Hoosier block tread, the drag slicks and finally got Goodyear dirt tires. The Hoosiers were too soft forbig block modifieds, but worked really good with the injected small blocks. I do remember what they durometered, 40 or under new, and didn't get too much harder with heat cycles, probably mid 40s.
    Yes those were the days...
    Desoto291Hemi and Sharpone like this.
  18. '29 Gizmo
    '29 Gizmo
    from UK
    Still use them for checking all rubber parts, hoses, motor mounts, bushings etc. The better "lab" quality ones have a calibration tool. s-l400.jpg
    rod1, Desoto291Hemi and VANDENPLAS like this.
  19. bobss396
    bobss396
    It all depended on how long it was kept in the wallet... :eek:
  20. wicarnut
    wicarnut
    I had one and thought it helped when purchasing new Hoosier tires as the numbers cast in tires varied from tire to tire, very useful at a track that required a certain tire compound. When I started in Midgets 1970 it was simple, 2 choices 5.50 RR Firestone ascot (digger for early ) 5.50 M & H tire we grooved up, LR same tires 5.00, M & H came in 2 choices soft/medium. 4 monroe shocks, same. I raced through 1991 finishing in wing Sprint cars, 3 different tire brands, several sizes/compounds, tires now sensitive to heat cycles. Shocks, too many choices/brands/valving and wing style/brand/ wicker bill sizes. A lot of choices AND a much larger budget required. In 21 years a $1500 race car with spares that I almost broke even $$$ wise to a $40/45,000 Sprint Car with spares that I Never got close to Even on the $$$ BUT what great FUN and MEMORIES, Priceless !
    rod1, Budget36 and jaracer like this.
  21. BJR
    BJR
    I put them on inside out for my pleasure! :eek::p:D
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    I tested the slicks on the Futurian, they are 25 year old Radirs all the gauges measured about the same at 70-72
    865E13A3-F585-4B51-82AC-7C56DF750AFF.jpeg CD7CC53D-A155-474A-BD03-6E8D8043F534.jpeg 8CCAFBDD-A337-40B3-A90F-0DDF50FFBA4A.jpeg 408223C7-42A7-43B5-B42F-945310BBAE66.jpeg 18285AB5-E457-46EF-9FEA-B188D9823AB5.jpeg 004498F7-1F9B-4EF2-9159-CBE88DAE466D.jpeg
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    Moon instruction sheet 8356BF00-35B2-4DA6-8669-0AEB51A634F3.jpeg AE53ADE6-AA86-49A9-B961-1F9C401E7DD5.jpeg
    rod1, ClayMart, akoutlaw and 4 others like this.
  24. theHIGHLANDER
    theHIGHLANDER
    I was a drag racer. We'd count rounds. Every 3rd or 4th weekend I'd swap side to side. Never tested hardness, intriguing little tool, thanks...
    Roothawg, Moriarity and VANDENPLAS like this.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, I don't collect any modern stuff.....
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Mid Century “Modern” is off the list as well. :)
    Moriarity likes this.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    Haha, I do have some of that stuff
  28. Marty Strode
    Marty Strode
    When we were racing Hardtops on dirt 20 years ago, the rule was no less and 50 durometers on the right rear. Hoosier mad a Medium tire that fell just over 50, and the Soft was around 38. One guy that was famous for cheating sanded the letters "Soft" off his tire, thinking no one would notice, so we started durometer testing the right rear tires, when the cars were staged up for the main event.
  29. amodel25
    amodel25
    I worked for a rubber molding company as an Engineer for nearly 40 years. I have one from my job. I keep it in a drawer with my slide rule.
    rod1, steeltappet and '51 Norm like this.
  30. theHIGHLANDER
    theHIGHLANDER
    So much of that stuff is off the hook kool, and really some of our unique car stuff fits. Think early 60s dealers.
    Johnny Gee likes this.
