Hot Rods KingPIN Sleeve
Discussion in 'The Hokey Ass Message Board' started by craigibc, Feb 25, 2024.
  1. craigibc
    craigibc
    I want to build my own axle and I need a ford kingpin sleeve. In the attached blueprint it is called a BOSS.
    I can't find one yet on a Google search or here on the HAMB. I had a catalog from a guy many years ago that sold all the pieces and parts of a traditional build but I don't have it anymore.
    Craig
  2. manyolcars
    manyolcars
    Its just a piece of round stock with the right size hole. maybe off roaders supply have them
  3. gimpyshotrods
    gimpyshotrods
    Do you mean the ends of the axle themselves, through which the kingpins pass through?
    https://www.thompsonsgarage.com/hom.../axle_bosses_fit_1937-1948_ford_spindles.html
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Hepfner racing product...
  5. craigibc
    craigibc
  6. squirrel
    do you own a lathe yet?
    if not, are you ready to buy something you obviously need?
  7. 1biggun
    1biggun
    I cut the ends off a old bent drop tube axle once and used them on a straight axle .
    Other wise any machine shop could make these fairly easy
  8. craigibc
    craigibc
    yes I sure do!
  9. 32fenderless
    32fenderless
    I have a set that I would sell. I ended up not using them. These use a set screw to lock the kingpin.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  11. One of my good Friends grew up with Glen the founder of that company. Both now in their 80's and still friends.
  12. craigibc
    craigibc
  13. Fordors
    Fordors
    Neither of those will work, you need a boss that is approximately 2 3/8 tall x 1 3/8 dia. with a hole sized for an .813 k/p to pass through easily. Those HRP bosses use later Ford pickup .859 k/p's.
    I edited the height dimension ^, I forgot about the thrust bearing that goes under the axle boss.
  14. squirrel
    seems if a guy had some 1.5" dia steel bar and a lathe, he could have made them already
  15. seb fontana
    seb fontana
    from ct
    Maybe Scout [International] king pin dia/spindles as they were a thing for a while do to more kingpin angle for enhancing weight jacking in cornering.
  16. enjenjo
    enjenjo
    from swanton oh
    They are for sprint car axles based on International spindles originally. I have some stock Ford axles, I can cut the ends off one and send them to you.
  17. Dave G in Gansevoort
    from Upstate NY
    Like mentioned above, a chunk of 1.5 inch diameter weldable bar stock, a lathe, and a 13/16 drill bit (0.8125 diameter), and you can make them pretty quickly. Just a little hint, run the drill bit backwards at low speed and using a honing stone, remove a few thousandths from the od. Say 0.005 thousandths. Then get a reamer to enlarge the bores to get the size spot on. Or if you have access to one, a Sunnen honing machine just like used to hone the spindle bushings with. However, leave the finish sizing until after you have welded the bosses to the axle tube.
