Projects 1931 Cobbled Roadster Build
Discussion in 'Traditional Hot Rods' started by glorydime, Jan 1, 2019.
  1. glorydime
    glorydime
    from Austin, TX
    I had been planning on running a set of Edmund heads and intake I sourced when i first started putting this project together, but now thinking I am going to change directions and source a set of the Canadian aluminum heads and intake for this motor and run the Edmunds on another healthier motor I have in the shop at a latter time. Not realizing those Canadian heads are pretty hard to find in good condition. Well long story short I found a set got a great deal upon delivery I realized they were not matching being that one was from a Mercury and one is Ford. This rang some alarms to me being that the Mercury would have a 4" crank and i ***ume a larger combustion chamber. So I went to the experts on the ford bard to find some answers. Turns out there is a difference, but seems as if its going to be fine because the difference is in the 15 cc realm. I was able to measure the difference my self by turning the heads over and getting them level, inserting a spark plug and filling the chamber with a solvent then ****ing it back out via a syringe and the difference was more like 10cc. So my plan is to move forward fingers crossed it will run ok. The heads themselves were dirty and needed a buff so I cleaned them with some mild degreaser and cleaned them with some wheels from PRYME which I cant recommend enough if you are in need of some cleaning and or buffing tools this company is amazing and provide some great items. I do not have a buffer so I converted my craftsman's bench grinder into a buffer. I purchased some arm extensions from PRYME and went to town. I was able to find an intake as well, it had some issues on the back side which look to be some sort of impact issue. I was able to deck it straight.
    89d6eede-9986-4dbe-aec6-371607b98f8d.jpg 1c51edba-097b-41b5-8120-4a8a4679792d.jpg 5aea539e-e67e-49a9-b017-a438acf47bba.jpg d2b16873-8aee-49c2-bb9d-7c8071833f65.jpg f6e6da07-797f-4be6-bc85-1c22af77d6a2.jpg fff95142-139a-4d03-8bdd-0d271fe32d41.jpg 1c328751-3b38-4ed3-80e5-b4b4c7efa338.jpg 9afcd99e-c6d3-48b2-b931-1b1284fd0372.jpg c7c7e46b-2bf3-4214-b5a1-256709f3a82c.jpg 76db289e-f984-48f5-9172-923cec339c50.jpg 8f6c536d-a3d3-4fee-b486-bc920fea7994.jpg 8648d8a0-ac9f-4d54-b299-32cfa5e3c329.jpg c2fed94d-68c8-448e-84aa-ed4c02d6bbb0.jpg ef58df07-073d-4268-bd37-9183c5d97f09.jpg 7c8c4606-7e73-46d3-a0f7-eb5b539cc261.jpg
    Jeff34, brEad and roadwarrior84 like this.
  2. glorydime
    glorydime
    from Austin, TX
    Mounted the heads last night love the look so far.
    622c45d9-d1e0-4b73-b727-77f7c8fbdd30.jpg 56673b82-f93e-46fa-a663-f85567b2d46e.jpg
    Outback, brEad, Jeff34 and 1 other person like this.
  3. glorydime
    glorydime
    from Austin, TX
    Added the fuel line in the last couple of nights after work. 5/16 nicopp line, carter inline pump, holley regulator. I used some of the permatex indian head stuff on the threads of the tank out just in case. I used soft lines from the tank to filter/pump/regulator then to hard line to the front. Thinking my regulator being at the start of the fuel run might be an issue, but ill see when its running. I wanted to hide all mentioned items as much as possible. I will need to insert some grommets around holes the lines goes through in the crossmember. I used the Eastwood Flaring tool again, and cant recommend it enough for this kind of work. I am planning on running a single carb with the Canadian intake got, but i will still use the fuel block up front so i can have a fuel presser gauge, mainly just for looks. Next i need to start plugging some of the holes in the firewall while the motor is back out of the car.
    9827f74c-15d7-4aa6-9a98-9d8bf06b8d09.jpg e03ba741-cb14-458f-a20a-1efd2f8893a2.jpg e9ee7e6a-53a8-49eb-ba9b-0922d3483f30.jpg 2c246b7f-7736-43cc-b45e-0e0bd7f8b1cf.jpg a081cd94-c667-4dec-ae2a-2a1c9aca2a61.jpg b8a01802-b178-4fb5-95b3-8a02a740d391.jpg
    -Brent-, brEad, OFT and 3 others like this.
  4. glorydime
    glorydime
    from Austin, TX
    Been taking care of last little bits on this car recently. Needed to figure out how to gain access to the master cylinder so I made a very simple plate and used a router to recess the plate to make it sit level. Nothing fancy again, just good old garage built stuff here. I still need to seal the toe board and floor board. The list is getting smaller though.
    8a8ec900-0563-4534-89aa-def2cf123f66.jpg a0744754-ab94-469e-8bde-1ddce01762f3.jpg e80755ed-530c-4e25-ba44-e4cdcea33f5d.jpg 4e343fbd-2023-4f39-98b1-bfbd04a684c9.jpg f580fd89-58c0-4a55-a286-d47dca5870dc.jpg fa64236a-8f1d-4618-bfdc-4973bf0d5abb.jpg 6d2337bd-bbf9-42f8-83ba-e9869957a3a9.jpg d25ae6d3-101e-4702-aa4d-423425c08d60.jpg
    brEad, OFT, warbird1 and 2 others like this.
  5. glorydime
    glorydime
    from Austin, TX
    Last night figured I'd tackle the license plate and nerf/push bar and license plate light. I copied Holly Orel plate holder and nerf bar as best I could. I hate torch cutting and am honestly horrible at it. i spent as much time cleaning up the slag as I would have by just using a cut off wheel alone. My plate light is not Hollywood Brand. Its some other older maker that looks the same but it had this large riser space between the light and the holder so I cut it out and welded it back. All in all came out great.
    34df3da8-fb62-43d7-ab22-465f68f6bd94.jpg bcf5d56a-46f4-4d14-847c-20f36802bd8b.jpg d5ef461f-d336-40eb-928f-3b9a68d70a4b.jpg af5e750a-f511-4af8-9934-75460f2bb2be.jpg 05f7f0ec-06bf-445c-897a-00cf6481e305.jpg 9ffd3296-8233-4105-96b9-65d3c919995f.jpg d898c294-d68c-4967-af92-0589459d6883.jpg 042fe572-3565-49e3-93f9-e06c1d5d212c.jpg b55409d0-0be1-4c1f-bdb8-cbfdae83b873.jpg 63cdc78d-e4b5-4948-9aed-c6b45e03470d.jpg
  6. roadwarrior84
    roadwarrior84
    from Aiken, SC
    I used that Indian head on vintage mopeds years ago
    glorydime likes this.
  7. glorydime
    glorydime
    from Austin, TX
    It has a smell that is so odd and I love it.
    roadwarrior84 likes this.
  8. glorydime
    glorydime
    from Austin, TX
    Lots of updates to the car with little updates here. I was trying to make it to Lone Star Round Up this year, but sadly fell short. I will say this deadline lit the fire though because i got more done in the last three months than I thought possible. I was able to get the motor back in and run electrical and figure out all the small details to take my first little run in the car. Because of this quick last minute sprint my photo coverage was very small. My good friend built me a small 5 circuit panel for the electrical runs. I did use Brillman for all the wiring and used their asphalt loom as well.
    Shadow Creek and Squablow like this.
  9. glorydime
    glorydime
    from Austin, TX
  10. glorydime
    glorydime
    from Austin, TX
  11. glorydime
    glorydime
    from Austin, TX
    I also started playing around with the idea of painting the car with a rough patina style in mind. I basically took Rustoleum dark red flat and strayed the firewall. then took a bit of the green paint i used from the motor let that all dry over night then i used a black spirit wood stain the next morning and it looks ok. you can see it here in this photo prior to the engine going back in. Not sure ill stay with it, but it works for now. Also this is the little panel my buddy mark built. ad7b4dfe-ba5d-4a44-a41e-e81e8c064195.jpg 70654230-f58e-4387-a027-1b52d2d83cc9.jpg
    Shadow Creek, brEad, GordonC and 2 others like this.
  12. glorydime
    glorydime
    from Austin, TX
    Next i started tackling the accelerator. I needed a little more space for the s**** so I built a little step, but decided I didn't like the way it looked and s****ped it to just heat and bend the s**** to work. Took alot of adjustments but I made it work.
    0e44d645-9bc0-45ce-9c83-7949677ee403.jpg 2eb99f76-1604-44bc-85b7-f9cfb46ec7c1.jpg 10a3a583-739e-42b6-bb64-0f60db3f6968.jpg 49fbd7c9-8e25-496f-8ddf-e63cbc5a8819.jpg 66f4372a-9317-485e-b86f-123799de312f.jpg
    lurker mick, brEad, GordonC and 3 others like this.
  13. glorydime
    glorydime
    from Austin, TX
  14. glorydime
    glorydime
    from Austin, TX
    Next I tackled the floorboard insert to meet the toe and heel boards. I just used a piece of 16 ga flat I made a pattern and had to make the smallest little tunnel to bring the floor up off the Trans. I also went ahead and stained the floor boards as well.
  15. glorydime
    glorydime
    from Austin, TX
    Also upgraded my rear tires to 750 16 firestones. Really brought out the look of the car. 59a47ffe-50e5-4979-a45f-d5c0938d16ab.jpg cf284eb8-7183-46fc-a237-b85d59dd1102.jpg ee1e8f81-ad22-4967-bcca-5cfbe2f7f858.jpg
    lurker mick, brEad, Jeff34 and 8 others like this.
  16. glorydime
    glorydime
    from Austin, TX
    Electrical for this car has been something i have put off till the end. Very lucky i had my buddy mark ford build this little panel. I first just mounted the panel then started running one wire at a time and zip tieing them together. After i ran all of them i cut each tie and added friction tape, then i loomed and made the connections. I was in such a rush in this part i didn't take alot of photos but it came out really well.
    brEad and Algoma56 like this.
  17. glorydime
    glorydime
    from Austin, TX
  18. glorydime
    glorydime
    from Austin, TX
  19. glorydime
    glorydime
    from Austin, TX
    Shows how many zips i used and my view for 3 days of install just under the dash. 614dbbc5-750c-4cc5-a077-5bf7277629f6.jpg 4913e028-eb7a-45ee-b97c-4740b8275d7e.jpg 48099d81-b092-4759-82fe-d2d02ae02ccb.jpg f1308054-981c-4391-8945-4ff8da59f0bb.jpg fe448559-0f87-40e2-a432-1068dbe62078.jpg
    Tim, wandi harry, lurker mick and 5 others like this.
  20. glorydime
    glorydime
    from Austin, TX
  21. glorydime
    glorydime
    from Austin, TX
  22. glorydime
    glorydime
    from Austin, TX
  23. Little Terry
    Little Terry
    I am really enjoying this thread and love the look you are achieving with your car. Keep up the great work you are so close to the finish line.
    Outback and glorydime like this.
  24. glorydime
    glorydime
    from Austin, TX
    After I was able to get all the electrical under wraps I was basically at the finish line, or I thought. Once I got the car running again with the aluminum heads and intake I ran into all sorts of issues with fuel leaks, and coolant leaks. Once I got this all under control I took my first ride. Two blocks from the house I noticed lots of white smoke out of the p***enger exhaust. I came home and pulled the stick to find coolant in the pan. So either I didnt torque the heads down enough or the gasket broke, or I have a crack somewhere and or the heads are not flat. So I drained all of the oil and coolant and started slowing taking the heads up in torque and when I got to 45 i spun a bolt. It didnt break the bolt but it broke out of the threads. It is one of the head bolt holes I had to drill out cause one of the oringal bolts broke. I might have not tapped it well enough.? Either way I plan on installing a time-sert in that hole. I will go ahead and pull the heads and install new gaskets as well. I was told the aluminum heads should only go to 35 ftlbs, then I was told they should go up to 50. If you have an opinion id love to hear. Here is a vid of the motor after i got it running again, and a photo of the bolt that is turning. Didnt make it to LSRU with the car, but man it was a great year out at the show.
    Nailhead A-V8 likes this.
  25. glorydime
    glorydime
    from Austin, TX
  26. glorydime
    glorydime
    from Austin, TX
  27. Jeff34
    Jeff34
    Great thread! Looks and sounds awesome!
    On torque for heads, I have heard both. When I torqued my alum heads to 50ft/lbs, I cracked one of the heads at the bolt hole (F&%$). I would stick with 35-40 next time.
  28. Zax
    Zax
    You look pretty tall in the pic with your head under the dash. What are your plans for seat mounting?
  29. glorydime
    glorydime
    from Austin, TX
    I am 6 feet, I made a seat from a bus frame that I cut down and upholstered. I took about 2" out of the seat riser to allow for my long legs. Its tight but I fit. I came up in Minitrucks in the hobby, so I am very used to tight spots. I have a few photos pages back that you can see the seat installed and mounted.
    brEad likes this.
  30. glorydime
    glorydime
    from Austin, TX
    Zax i just looked back its between the end of page 6 and 7, so you dont have to go through all of my ramblings on this full build.
    brEad likes this.
