Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. GuyW
    GuyW
    LOL - that era of pickup steering boxes are the good ones that people use to replace older ones. But best of luck with your project.
    31chevymike, snoop74 and Six Ball like this.
  2. Six Ball
    Six Ball
    from Nevada
    The pickup is still a ***** if you are not rolling. It the early box doesn't work I'll uses a Little Rascal setup with ropes & pulleys. Thanks I take all the luck that comes this way.
    brokedownbiker and snoop74 like this.
  3. snoop74
    snoop74
    I think the one I sent is restored. I reached out to a guy about recasting mine but I may hold off on it for now. You know it goes though haha, people are selling those banjo horn ****ons for that now. For now I’ll probably keep with my 42-48 accessory wheel I redid last year.
  4. snoop74
    snoop74
    Why not a Vega? Just want it all period correct?
    31chevymike and Six Ball like this.
  5. Six Ball
    Six Ball
    from Nevada
    I'm keeping the parallel leafs in the front. The steering box mount is part of the forging for the spring perch. It will be easier to use the stock box if I can. I'll just have to see how it works out with what won't be stock.
    Shitbox, snoop74 and 31chevymike like this.
  6. That's what I'm talking about! That steering wheel will look awesome in your hot rod! Speaking of my own, my buddy Dale and his son David came over last weekend and we finished the brakes completely and very proud of them. When I straighten up my garage, I'll take some great photos to show here and on my thread!
    Shitbox likes this.
  7. snoop74
    snoop74
    Looking forward to it!! Did you end up using all the original components? I wanted to keep chev brakes but man I couldn’t find parts and if I did they were super expensive
    31chevymike likes this.
  8. snoop74
    snoop74
    Been waiting for these for a minute.
    Shitbox, Six Ball and 31chevymike like this.
  9. Unlike your hot rod, I needed to add front disc brakes and residual valves to my brake system to help stop with that m***ive hemi... I had all Chevy brakes in the beginning, mostly '53 Chevy drum brakes in the front and rear '63 Chevy drum brakes in the rear as well - along with a scary single piston '53 Chevy mc. In this day and age, you do whatever is possible for safety!
    What can be said more about running a big block 348/409 Chevy in a vintage Chevy hot rod? AWESOME!!!! Where'd you find those air cleaners? The parts you're purchasing and installing on your '35 continue to amaze me and others for sure!
    Six Ball likes this.
  10. Six Ball
    Six Ball
    from Nevada
    That looks great! It is right where it should be.
  11. snoop74
    snoop74
    haha that’s true, I’m trying to keep mine as a50-60’s style hot rod. Now if I had fenders I probably would have been subject to change it. My 65 gmc has drums all the way around and had some pucker moments with the one pot master.
    They’re grace & co, but hear drive remakes them now I want to say. I had those scoops on but wanted to set it apart a bit.
  12. snoop74
    snoop74
    Got some of the trans tunnel cobbled together(well the first part) and the panel for my pedals done and painted. Tank mounted as well as ground/hot cables ran. Made a battery box as well.
    floor will eventually have carpet so didn’t care too much how it looks. I should be getting my seat back from upholstery this weekend.
    Six Ball, GuyW, 41 coupe and 4 others like this.
  13. You're really making headway @snoop74! Forgot what you're using as a trans...
  14. Some photos of the brake system that was completed just recently...
    Passenger view of Complete brake assembly.jpg Rear view of detail of new brake lines  with x-member.jpg Winter's Quick Change view of new brake lines.jpg Body off with mock up hemi removed to finish new brake lines.jpg Detail view of MC with new brake lines, proportioning valve, residual valves, etc..jpg Front end view with complete disc brake system from So-Cal, new brake lines and front hoses.jpg Full frame shot with body off, showing detail of frame strengthening.jpg
    Six Ball, GuyW, snoop74 and 2 others like this.
  15. snoop74
    snoop74
    Muncie 4 (m21)
  16. snoop74
    snoop74
    Man that thing looks great, do you plan on painting the frame or powder coating? Are those rear ladder bars from rjays? I think I’m running the same one. I always liked how hairpins looked and wish I went with though.
    Whats the drop on that front axle ?
  17. Six Ball
    Six Ball
    from Nevada
    Bothe of you are doing Chevys proud!
    31, Rethink you drive system and mount the Hemi sideways with a big chain! :rolleyes: The breaks look grid. Usually I don't like things that look like other things or that have to be hidden but you pulled off the front brake thing. I am finding that I am having to make concessions to get the '26 like I want it.
    Snoop, that's a lot of progress! It is looking good. Very good proportions.
    My '53 pickup & '70 Blazer use the SAME 11"x 2" brake drums. They work better on the '53. With the 16.5 wheels & big tires that were dealer installed on the Blazer when I bought it at 60 mph you might as well have been dragging your feet! :eek: Just too much rotating weight & leverage. They were not on it long. I also installed a disc set that Vic Hickey sold. It was worse. I Think the '49 Huck brakes I'm using on the front are 11"x 1 3/4". I'm using a Dana 44 from a '68 GMC 4x4 (same as the Blazer) and I'm trying to figure not a 2 1/2" option finned drums for the back. I have to find the right backing plates. Shoes & drums are easy.
  18. snoop74
    snoop74
    Appreciate it, currently just trying to get it roll for lone star round up in April. Then I’ll come back and really tune it all
  19. Six Ball
    Six Ball
    from Nevada
    I made a 4000 mile round trip to the Roundup once.
    31chevymike and snoop74 like this.
  20. I'm leaving the body and frame bare steel for the time being, hoping I can use some polisher (Eastwood from what I heard from Dale's son) to give the metal that smooth, even "brushed look" that I've envied all my life... The rear ladder bars are from Millworks Hot Rod Supply in New Hampshire and are really *****in'! The Speedway Motors '32 Ford front axle has a 4" drop and MUCH MORE *****IN'! Remind me what front axle you went with on your '35.
    I'm glad that you feel approved about pulling off the front brake thing - thank you sir! Keep at it @Six Ball!
  21. snoop74
    snoop74
    I'm running a ford axle 33-36 axle. It's dropped axle I got at the round up last year.
    Dan Hay, 31chevymike and Six Ball like this.
  22. More old school traditional with the wishbones - killer look! You'll be one of the few Chevy hot rods at the Roundup - representing us in style brother! Wish I was there with 'ya!
    Six Ball and snoop74 like this.
  23. snoop74
    snoop74
    Maybe so but I really like the look of the pins. Ended up chroming them along with the backing plates.
    had to represent the chevys! Our paths will cross eventually. I plan on driving this thing every where.
  24. snoop74
    snoop74
    What’s everyone running for tail lights/headlights ? I think I asked this already
  25. Six Ball
    Six Ball
    from Nevada
    Those are some nice chrome pieces and deserve to be used.
    I found a 30-31? Chevy headlight bar that is solid and a lot like Ford to use for my headlight stands. I have another set form 34ish Chevy trucks that I may use. This all depends on if I use the 30-31 headlights I'm putting together and whether my 4 banger will push them through the wind. If not I have a smaller set. Some of these decisions will be made during ***embly when I cam actually see the proportions. I also found a set of tube shock mounts used on a '40 Chevy model that still had a beam axle. The are a lot like Ford F1 shock mounts. I'll try to find some pictures.
  26. snoop74
    snoop74
    Are the Chevy headlights the twlite’s? I was thinking of maybe using a pair of them as well. Are they seal beamed? I have some guide 682-C’s that I fixed up but it’s a common light so thought about changing
  27. Six Ball
    Six Ball
    from Nevada
    Yes I think they are. 10" or so. One of these were converted to sealed beams & looks like ****. I found good reflectors and am installing modern bulbs. If that doesn't look too ugly I'll use them. I have a set of smaller Guides with the park light bubble but these are on the side and the park lens housing is missing and different from anything I can find. If I use them I'll have to make or modify something.
  28. snoop74
    snoop74
    you have some 904A with the bubble on top? I've been trying to find a set of those for months lol
  29. Chrome plating these parts came out excellent! Any other front end parts for plating, possibly your axle, etc?
    Can't wait to see your interior pieces from the shop that you hired - surely will inspire me to get my buckets done in either white or white pearl with a Tangerine/Orange colored piping or sorts. I bought '59 Ford Thunderbird buckets that just barely fit inside my coupe, having only 42" or so between the door wood... Your progress is impressive - GO MAN GO Brother!
  30. snoop74
    snoop74
    I thought about chroming the axle but I didn’t want it too look too over the top. The next thing I will chrome will be the garnish molding. The car will have some rough spots like the grille, door handles and most of the body work lol.
    I ended up with a k5 blazer 3rd row seat that I had to slightly narrow. I really like white seats that something I thought about doing but I’m
    Always dirty lol. How much you think it would run you to get both buckets done?
    For now I’ll be the seat; I’ll go back clean up the inside before I get that done.
