History looking for model a Cdan w/ 32 gas tank pics???
Discussion in 'Traditional Hot Rods' started by 2FORCEFULL, Feb 8, 2024.
  1. ALLDONE
    ALLDONE
    well, that was short lived... took the back seat out and the cross member is right under the seat and to the top of the raised floor...so, back to the drawing board... so what I need to do is remove the valance on the rear and re try the 32 tank, also It will slide all the way in to the filler neck..
  2. Grandadeo
    Grandadeo
    My friend Davis A C-dan with deuce tank. 20230128_135717.jpg 20230128_135705.jpg
  3. lostone
    lostone
    from kansas
    I don't mind the look so much when they are full fendered.
    Anybody got pics of any without fenders ? Been kinda heading this way on my 31 Tudor but I'm thinking of running bobbed rear fenders or none at all....
  4. ALLDONE
    ALLDONE
    thanks for the post and pic... looks like the dagels kit install.... I can slide my tank to where the filler neck touches the body... not to keen on the look of the tank haning back there and sticking out so far as my look is to be a drag /street race banger
  5. ALLDONE
    ALLDONE
    I'm starting to think 30/31 is different on the rear of the Cdan
  6. ALLDONE
    ALLDONE
  7. Grandadeo
    Grandadeo
    David used the Duece frame rail ends to attach tank in stock '32 configuration.
  8. ALLDONE
    ALLDONE
    Well, so far I took all the rear interior (seat and floor) out...didn't come up with a way to put a tank inside the rear, so back to the 32 tank idea......looks like no problem to slide the tank in to where the filler neck is about 1/2'' from the body with the valance removed, puts the tank up about 4'' more.... so looks like that what we will do...not the best looking idea.... but it's the best we came up with...
    I'll be doing that shortly, and will post some pics along the way..using the 32 tank and frame horns and fabing up the rest...also moving the rear shocks to the front side as they where on the rear side...wouldn't be able to remove the shocks with the tank in, and they were also too long after the car was lowered...
    clem likes this.
  9. atch
    atch
    Just in case you'd like to see more 30/31 pix:
    This one looks like what you're trying to do
    Who knows what this tank and frame rails are? I'm guessing custom made for this car.
    Grandadeo likes this.
  10. atch
    atch
    Here's a 28/29 with 32 tank:
    ...and here's one with some kind of tank back there:
  11. dln1949
    dln1949
    How about t******* the valance above the tank and leaving some of it on the ends to fill some of the void be tween the tank and the fenders. Then shove the tank under the car till the fill tube is as close to the body as can be and still fill the tank.
    clem and 2FORCEFULL like this.
  12. Tim
    Tim
    from KCMO
    I think if you cut the verticals brace out of the body below the back window you could run a ford f-truck gas tank that would normally be behind the trucks bench seat. I’ve seen that done a few times. I think @flatout51 may have done that at one point with a filler out the side of the car
  13. ALLDONE
    ALLDONE
    wouldn't be able to run the rear seat... and it's a 4 door Cdan
  14. ALLDONE
    ALLDONE
  15. Tim
    Tim
    from KCMO
    He did his in a Tudor and still had the back seat. I was going to do the same in mine but went a different direction. Plenty of room to scoot that back seat forward
  16. ALLDONE
    ALLDONE
    and yes, this is how mine will look when done
    thats pretty much the plan right now...also looks like the rear fenders are bob'd about 4''???
  17. atch
    atch
    @2FORCEFULL ,
    Thank you for starting this thread. My '31 two door sedan is a half-finished project that was started over 30 years ago and has sat nearly all of the time 'til now. The car has '32 rear frame horns (on the "A" frame) and has had a '32 tank mounted. However the tank got lost. None-the-less, you're doing pretty much what I have envisioned. The way it's done now is pretty much the way that most of these pix show. I like your idea of shoving the tank as far forward as is possible. Ed removed the fenders for the highboy look but I've bought replacement fenders, splash aprons, running boards, etc. I'm anxious to see pix of yours when you get further along.
  18. atch
    atch
    Please forgive me for hi-jacking the thread.
    @2935ford; are those 38/39 Buick/Olds tail lights?
  19. 2935ford
    2935ford
    Those tail lights are Harley known as "tombstone".
    @2935ford; are those 38/39 Buick/Olds tail lights?[/QUOTE]
  20. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Full fendered A with a deuce tank looks unfinished without the deuce rear frame horn covers.
    dwollam and pprather like this.
  21. clem
    clem
    that is a fabricated tank, not a ‘32 tank.
    I had fitment issues on one car and considered mounting the tank under the top off the frame rails even packing it down, to make it work.
    On a stock ‘32 sedan the body is indeed shorter so it appears that the tank sticks out more than on a coupe or roadster.
    so looking at post 19 you are correct with your observation !
    2FORCEFULL likes this.
  22. ALLDONE
    ALLDONE
    I'm dealing with the aluminum head swap and and fine tunning right now and plan is to take it to my fab/muffler shop for the install , I made 2 welders 30 some years ago,... they'll be doing the install...
    but I will get pics...
  23. ALLDONE
    ALLDONE
  24. ALLDONE
    ALLDONE
    sooo. it's a reproduction 32 ford gas tank...correct???
    made to bolt on a 32 frame..???
  25. clem
    clem
    Not likely to be reproduction,
    looks homemade, different bracket to bolt to top of ch***is, curve’s don’t look the same as original, angle of filler cap looks different.
    (Sad really that I notice these things, but last year I spent a lot of time refitting / refurbishing 2 original ones…………..)
    I suspect that it is a one off made by owner to look like a ‘32 (or perhaps a reproduction one without the correct brackets)- looks close enough for most.
  26. clem
    clem
    Here are a couple of reproduction ones.
    vintique
    note no brackets at all on this one as some come like that
  27. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Top tank Vintique with side gussets. Bottom tank from Tank's no gussets. I think the Tanks tank is a better quality stamping so I always add the gussets.
  28. 19Eddy30
    19Eddy30
    from VA
    No tank kit,
    Stock A frame , coil over shocks ,
    Reproduction 32 tank , used cut off 32 frame horns , tucked tank in p*** the sending unit by 3 inches , with a slight angle down , tied 32 frame horns into A
    frame with 3/4 by 2 inch tubing
    Frame horns & metal $110 ish
    Tank @ time $150ish
    Just Gary likes this.
  29. ALLDONE
    ALLDONE
    thanks for the post a pic,... pretty much what I'm doing but I bought the frame horns, spreader bar and tank... I'm sliding my tank in to where I can just be able to get the cap off, so probley 4/5'' in farther than the pic you post...
  30. flatout51
    flatout51
    You don't have to remove the vertical brace. Just need to make mounts and a F1 48-52 tank fits pretty well.
    Tim likes this.
