Hot Rods 57 FORD Build #2... Glutton for Punishment.
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Oct 20, 2021.
  1. NoSurf
    NoSurf
    than some lonely country road..
    Like on your way to Oxford Maine...?
    Jeff Norwell likes this.
  2. chicken
    chicken
    from Kansas
    Hi Jeff-
    Is part of the problem the fact that the old clutch fork pivot is still in the bellhousing and won't let the line stay back away from the rotating pressure plate? Beautiful work by the way...love the cars!
  3. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Jay.. that's exactly the lonely road I speak about.... somewhere on those beautiful backroads in the Vermont Mountains!
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    chicken... you're 100% correct..... The fork pivot bracket in the Bell has a notch top and bottom to hold and let the original fork to swing..... if I would drill a small hole below and above the notches.. and secure the feed and bleed lines to that.. they will be away from the rotating m***.
    Just wasn't thinking.
    And thank you for the kind words!
    enloe, Thor1, loudbang and 1 other person like this.
  5. atch
    atch
    Jeff,
    I (and thousands of others on here) seldom post comments about your Ford build. That said, however, we all look every time you post up something. Love the car and the work that has gone into it.
  6. Oneball
    Oneball
    That looks fab!
    Did you run the heater hose from the intake straight back over the top of the intake or sideways and then down the inner fender?
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    The Latter Tim..... sideways and away from the engine as much as possible.. running along the inner fender to the the firewall heater location.
    Thanks Man!
  8. As I age, I'm aware that the only way to quit learning or making mistakes is to quit, period. I'm pretty sure the young people that hear some of my stories think I'm an idiot. I'm ok with that. Everytime we do something there is room for something different in outcome. I don't care if you did it 10 times before. We can't depend on parts or engineering to be the same. Of course, we know we didn't change. LOL.
  9. Jeff Norwell
    Jeff Norwell
    MODERATOR
    So.... as the never ending story continues..... 40 pages....
    I fixed the throw out bearing issue... completely and utterly my fault.
    When I installed a few years back(or was it last year?)... I had the lines on the wrong side.... leaving them to "bend "out towards the rotating m***(pressure plate ***embly)....
    I received my replacement line, installed with the help of my good friend Terry.....
    took the needed measurements from the bell attached to the engine....
    Back to the trans and bearing.. set up the needed space...... and ***embled the throwout bearing to exit out the fork window.... clean and tight..... being a paranoid person..... I made sure and made small brackets to firmly keep the top line(bleed line) very close to the back wall of the Bell.
    I also.. in the initial install.... ran the bleed line at the bottom.Another dumb Newbie mistake.Needs to be the Top Line.
    Lessons learned....all is ready for ***embly.
    As I mentioned before.. the warmed over 352 is Out..... and a nicely built bigger cube FE is installed...
    Dyno read outs put it around 425-430 hp.
    This will give me the street grunt I desire.
    I will keep the 352 as a spare.... as there is nothing wrong with it.
    Just waiting to get some free time to install the engine and get it hooked back tot he toploader....Then fire it.
    Back to the throw out bearing...I need to make a peddle stop against the clutch pedal arm.
    already got it figured.. just need to find the time.....
    Move forward.... or die trying...... ha ha
    Okie Pete, Nominal, 53 effie and 17 others like this.
  10. 41 GMC K-18
    41 GMC K-18
    "Perfection, cannot be rushed"
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I have an incredibly stupid question... Why not use the factory mechanical clutch linkage? you know, the ultra reliable kind.....
  12. warbird1
    warbird1
    'specially since hydraulics are just a leak waiting to happen, IMHO...
    41 GMC K-18 and Moriarity like this.
  13. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Not stupid at all Mark.
    I simply don't have another 57-58 factory linkage set up..... and the Tilton was brand new,.. and the most important aspect...... Free.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    I hate modern ****, even if it is free..... hope it doesn't bite you in the ***.....
  15. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Respectively.....I completely disagree....... I was the reason it failed in the first place..... I have run several cars with this system and never had a failure.....
  16. warbird1
    warbird1
    Respectively.... I completely disagree.... your experience with hydraulics is obviously different than mine.
    50 years of working on mechanical stuff and hydraulics were always one of the biggest head-aches, regardless of what it was on. There's no way I would use one of these set-ups near a clutch, but that's just my way of doing things.
    And this was in no way intended to be a knock on you or the car... you're doing a great job with it!
  17. hotrodA
    hotrodA
    Thanks for the inspiration on an entirely different issue, the engine swap in my 40.
    It seems to bite my ****, at every turn, on things that should be simple.
    What would Jeff do? Keep Calm And Carry On.
  18. deathrowdave
    deathrowdave
    from NKy
    As many of those FE bellhousing and parts as I have seen and kicked around the garage floor , it is tough to think we are growing so old the parts are getting near used up .
    guthriesmith and Jeff Norwell like this.
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    all good… people today seem to get bent when others don’t agree or have a different opinion… seems to be a growing issue in today’s World
    Anyhow… all good my man.
    I continue to push forward.
    Silva, Just Gary, brEad and 7 others like this.
  20. About 6 years ago, I took a 58 Ford apart that had a 3 speed od in it. I saved the bellhousing, clutch, flywheel, pedal ***embly which included the strange power brake booster for years. I tried to sell it on various forums and places and struck out. I suffer from lack of space. A few years ago, it all went to the dump. I might have been able to help somebody but with the rising costs of shipping, I didn't think anybody would want it. That 58 came with a 332 4 barrel engine, the 3 speed and 4:11 gears. It should have been fun to drive when new. The guy I bought it from was a friend of my brothers. He never acted like it was special. :)
  21. RmK57
    RmK57
    Could always put a C6 in it and make it boring……like mine. :(
  22. bobss396
    bobss396
    My concern is the braided lines chafing against the fork opening, I'd like to see those padded or restrained to ward off taking it all apart too soon.
    Just Gary and Jeff Norwell like this.
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Oh.. yours isn't boring..post the pic of your 57 doing wheelies! hahaha..love that picture!
    enloe, brEad, guthriesmith and 5 others like this.
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well. we are in and ready..... Hopefully I can fire this weekend.... second time is a charm.
    Just dealing with a nasty tooth infection and Pain...
    I got nothing else.
    rod1, enloe, GordonC and 28 others like this.
  25. pwschuh
    pwschuh
    Looks beautiful.
  26. Just Gary
    Just Gary
    Bluetooth plug wires? ;)
    Seriously, this is a really cool build. If it were easy, everyone would have a *****in' '57 Ford.
  27. 57JoeFoMoPar
    57JoeFoMoPar
    Might be dumb, but I love the way the fuel line curves around the distributor. It's something like that that shows that despite the patina'd exterior, a lot of time and attention has been paid to the underpinnings.
    Just Gary, Thor1, porkshop and 3 others like this.
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes!. and invisible upper and lower rad hoses!... VERY hard to find!
    hahaha
    Thanks @Just Gary
    Thanks @57JoeFoMoPar
    Thanks @pwschuh
    enloe, Just Gary, Thor1 and 2 others like this.
  29. 41 GMC K-18
    41 GMC K-18
    Bravo @Jeff Norwell !
    That is amazing progress oh noble artistic/road warrior/purveyor of vintage (67 year old) Ford tin!
    It's cool enough to have one KICK *** 57 Ford, but to have two of those KICK *** rides, is simply the icing on the cake!
    Such a bummer about the HOT tooth, professional dental care, is indeed a necessity, and requires immediate attention !
    Your results may vary.
    Good luck on firing up the engine this weekend.
    Thanks from Dennis.
  30. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Where's the dirt and oil stains ? .......waiting.
    :D
