Technical Death wobble
Discussion in 'Traditional Hot Rods' started by Hildy56, Mar 1, 2024.
  1. Hildy56
    Hildy56
    I am new to hot rodding in general and Model A's specifically. I have a 29 roadster with a V8 that I bought from a fellow who started building it but ill health and age forced a sale. When I received the car the ch***is and frame were already complete and the engine in place. I have been working on it this winter completing the body, putting seats in, that sort of thing. I recently took it out for a test drive and when I got up to about 35MPH the car really wandered all over the road. A friend suggested I check the caster and I found that it was at 0 degrees. I made a pie cut on the split wishbones trying to get it to 6 or 7 degrees but I overdid it and ended up with 9 degrees. Now when I drive it, I get a violent wobble at about 15 to 20 MPH. it has a Vega steering box with cross steer and no panhard. I did try a dead spring perch but that did nothing at all and I have removed it. All suggestions are welcome. Thanks
    Greg
    Tow Truck Tom likes this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    Photo's will help others be more helpful. "Dead Perch'But I removed it" WTH?,,,,= Yup,ya have no idea,so start reading up,and put up some pics,,,Most Death is just screw ups by builders,too much play n wrong setting,,but canbe bad tire , an, or balance> PIC PIC PIC's
    Tow Truck Tom, X38 and 427 sleeper like this.
  3. 427 sleeper
    427 sleeper
    Are the King Pins and all other steering component's tight? Check wheel balance. Are the tire's in good condition?
    9 Degree's of caster isn't really a deal breaker.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Doesn’t toe out get worse when rolling an axel back?
  5. Hildy56
    Hildy56
    Yes, I installed a dead spring perch but it caused more problems than it solved so I took it back off. That’s WTH
  6. Hildy56
    Hildy56
    Yes the kingpins and all connections seem fine. It didn’t do this before I adjusted the caster.
  7. 427 sleeper
    427 sleeper
    Did you check the toe, as Johnny Gee suggested?
    Tow Truck Tom and Unkl Ian like this.
  8. Kevin Ardinger
    Kevin Ardinger
    Panhard bar, 1/8 inch toe in and 9 degrees caster (at ride height) all suspension and wheel bearings tight and you should be good.
  9. Hildy56
    Hildy56
    I have not checked the toe in. I will have to research how to check and adjust that.
  10. Hildy56
    Hildy56
    I do not have a panhard bar, that is probably something I am going to need to do.
    flynbrian48 likes this.
  11. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I wouldn't even consider it, that's a bandaid for issues.
    Personally if the kingpins are tight, check wheel bearings, check tie rod ends, ANY play in anything can cause this. Bad alignment can cause it also. Loose steering box can cause it also... If its a cheap speedway steering box its likely a failure there also.
  12. X38
    X38
    Pictures, pictures pictures.
    It's the how it's put together that is important. Of course nothing can beat actually being there, but pictures can reveal a lot.
    hrm2k, kadillackid, mad mikey and 4 others like this.
  13. Hildy56
    Hildy56
    I’ll get some photos in the morning and post them.
  14. axel's40
    axel's40
    With my 40 Plymouth I'm also at about 8-9 degrees, works fine, till I tried raising the rear about 1"-1 1/2", intant wobble at 35 mph soon as i hit a bump, evidently does'nt take much to throw it off.
  15. wuga
    wuga
    If that is a Speedway Vega box, open it up and check the bearings. They had a bad run. I was talking to a buddy last night who has one and in the past few days he opened his and the bearings were turning to dust.
    Warren
    Driver50x and Unkl Ian like this.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    No
    AXLE
    Put a $25 steering damper on it & drive it .
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Stopping the axle from moving back & forth especially with cross steer is a bandaid ?? SMH.
  18. twenty8
    twenty8
    I'm going to go out on a limb here and guess that the scrub radius is way off. Usually is in these type of threads.
    We shall see............. when we get pics.
    26 T Ford RPU and Tow Truck Tom like this.
  19. Kerrynzl
    Kerrynzl
    What side was the "dead perch" on ???? [with cross steer it needs to be on the p***enger side or you get mechanical bump steer]
    Split bones and cross steer is a recipe for death wobble. [you're getting "shackle wobble" and the Axle and Bones are shifting sideways in a parallelogram fashion]
    Install a panhard bar so it Arcs the same as the drag link. [even a temporary clamp on to test it]
    There are many things to trigger wobble but you need to control it.
    Reverse Eyeing the front spring can also contribute to this by altering shackle angles[the Panhard is a remedy]
  20. Mr48chev
    I'm with 2old2fast on this one. The panhard bar is to stop the axle from being pushed sideways when you turn the wheel. Standard equipment on most every modern solid axle cross steer rig on the road for the past 40 years or more.
    True it isn't going to fix his current issue.
  21. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The first thing I always check. Are the donuts worthy? ( true running + balanced )
    2OLD2FAST, dana barlow and X38 like this.
  22. Kerrynzl
    Kerrynzl
    Steering Dampers are a Bandaid!! Not Panhard Bars
    With side steer any slight lateral movement does not cause steering angle change [bump steer] because the draglink and Bones move in a similar arc.
    As soon as a hotrodder reinvents the wheel with cross steer, any lateral movement will cause steering angle change.
    This is made worse with split bones AND /OR reverse eye springs which alters the shackle angle [more vertical]
    The best method is to allow the shackles and split bones to "float" so there is no binding and use a panhard bar [that mimics the drag link]
    There are always other issues like too much scrub radius, and/or too much caster [which "triggers" wobble when on an uneven surface]
    Usually caused by smaller diameter wider wheels.
    As usual , this will turn into a H.A.M.B psychic thread where we take multiple "stabs" in different directions adding to the confusion [without photos or clues]
  23. 26 T Ford RPU
    26 T Ford RPU
    Also check the perch bolts are tight and there is no movement with them in the axle, commonly overlooked and is a common cause of death wobble. JW
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    The " this worked for me so it's the only way to fix it " syndrome. Coupled with the " throw things at the wall till it sticks " diagnostics ! Always good for some eye rolling & cheap laughs , then deteriorating into a mechanic vs engineer conflict , but sometimes finds its way to a " who's is bigger " show down , sometimes popcorn worthy ! Oh , the drama ! Culminating in to a cl***ic "playground" skirmish ! LOL
    kadillackid, CSPIDY, Kerrynzl and 3 others like this.
  25. 282doorUK
    282doorUK
    Not trying to hijack this thread, just to illustrate how tricky it can be diagnose death wobble causes.
    After reversing my spring eyes the shackle angle was more vertical than the preferred 45*, but on first test run it drove fine, although carefully driven as it had no shocks and only two fingers between spring and frame.
    Then I fitted lever arm shocks which meant much more spirited progress on the next run with no spring/frame contact, but then I got bad death wobble 3 times when slowing from around 15mph which went on till stationary.
    My steering box is due for overhaul as it's not in the best condition, but it wasn't an issue before I changed other things. Stock wheels and tyres are at 35psi. 8* king pin lay back.
    Who would've thought it could be better without shocks? But it was, I'll get it sorted no doubt, just got to eliminate one thing at a time.
    dana barlow likes this.
  26. flynbrian48
    flynbrian48
    With a cross steer set up, you HAVE to have a Panhard bar. With a side steer, you're not pushing the axle side to side turning the wheels, and the harmonics are less likely to generate death-wobble. 9 degrees of castor shouldn't affect much but steering effort, and would, if the rest of the front end is in good order, make it track straighter. Worn or damaged tie rod ends, kingpins and bushings, will certainly exaggerate the problem, an will cause death wobble or shimmy.
    Checking the toe in (or out, which it may be if you haven't) is neccessary. Just use a tape measure. Should be 1/4" for bias-ply, 1/8" for radials. That's the first thing you need to check, then the condition of the tie rod ends, kingpins, and whether everything is tightened up properly. 89FCC897-E76C-48A2-9865-952D41E4B27C.jpeg
  27. 1971BB427
    1971BB427
    from Oregon
    Toe in is likely the issue. And easy to check. Get a couple small pieces of tubing or even wood sticks, and hold them at 3 and 9 o'clock on the inside of the front wheel outer rim, or tire sidewalls. Try front inside and compare to rear inside to see which is narrower. Adjust until the front inside measurement is 1/8"-3/16" less than the rear measurement. You can slide the tubing or sticks where they overlap each other to adjust until they fit against the tires. And loosen and double check until the rear measurement is that 1/8"-3/16" wider than the front side.
    Be sure the tires are sitting on the ground, fully loaded car weight when doing this! If the car is off the ground you'll get erroneous measurements!
    CSPIDY, 427 sleeper and ClarkH like this.
  28. Hildy56
    Hildy56
    What is scrub radius?
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    studebaker46, WilliD and dana barlow like this.
  30. Hildy56
    Hildy56
